Question about Kenmore Elite 45986 Front Load Washer
Softener tray filling with water
When the wash cycle is complete, the softener tray is full of water.  This just started happening.  I have the Kenmore Elite Quiet Pak 4, front loading washing machine.
  • jovin5151 Sep 27, 2008
    mine too.
  • robrien21 Sep 29, 2008
    Pulling it out and cleaning it completely did help a great deal with the water.  Thank you.
  • 32 Answers
Open the dispenser all the way,place your finger towards the back left of dispenser.you should see a tab,depress the tab and pull entire dispenser cup out.the bleach and fab soft part of the disp has a removable tray.clean all pieces out including the long shafts on the insert.you will more than likely find a build up of softener,this breaks the siphon and does not allow the water to drain out.good luck
Posted on Sep 28, 2008
After wash was completed, there are water sitting in fabric softener tray up to the full line
Hello Warren, thank you for your post!
From what you have described there is water filling up the fabric softener tray in your Electrolux washer, EWFLS70JSS. At times water will fill into your fabric softener due to draining and siphoning action however, this is a normal operation within your washer. Hopefully this information is helpful to you. -Matt
Feb 26, 2016 | Electrolux EWFLS70JSS Washer
Softener tray won't fill with water; although it fills the bleach side tray just fine. No error codes, just an empty bleach tray but full softener tray.
I suggest there may be hard water mineral deposits in the hose or orifice to the tray. Try soaking it with some Coke (yes I mean the soft drink) overnight and see if the flow improves. Either that or you can try some CLR but Coke should be enough to gently remove any deposits there are in the tray, hose or line.
Dec 02, 2014 | Maytag Neptune MAH5500B Front Load Washer
Fabric softener premature release
In my case it was simply a matter of cleaning the nozzles that spray the water into the MAIN DETERGENT compartment. Turns our that when the washer was filling up, some nozzles were partially clogged and were directing water to the side where the softener compartment was, causing the fluid level to rise and therefore releasing the softener early. The washer was NOT spraying water in the softener side, what happens is that the dispenser tray is configured in a way that when the fluid reaches a certain max level in the softener/bleach trays, it completely drains. A way to test for this problem would be to completely dry the softener tray and start the wash cycle like you normally would (including detergent), only without adding any softener to the tray and see if after filling there is any water in the softener tray, this would prove that the water is coming from the other side.
Apr 13, 2012 | Whirlpool GHW9400 Front Load Washer
Fabric softener dispenser fills up with clear water after washing cycle is complete. I do not use fabric softener .
Purchase some fabric softener and place it in its normal location at the beginning of the cycle. At the end of the cycle check to see if fabric softener has been dispensed and whether there is water in the cup.
If the fabric softener is gone, but there is water in the fabric softener cup, then your problem may be with the water valve assembly. The water valve assembly (as one complete unit) has a separate solenoid for hot and cold water temperatures, bleach and fabric softener. The fabric softener solenoid on the water valve assembly could be defective (allowing water to fill the fabric softener cup).
Contact an appliance service company.
Feb 17, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Washing machine will not draw fabric conditioner
The Solution: Top up the softener tray with extra water so that it is up to the 'max level' mark.
The softener tray works by a siphon action. Thus, the reason the tray does not empty is that not enough water is added by the machine during the softening cycle, so that the machine does not completely fill the softening tray; only when the softening tray is filled beyond the 'max' mark does the siphon action works. A partially filled tray will never empty - it's impossible due to the siphon.
The reason that not enough water is added to the tray during the softening action is that the water inlet of the machine is partial blocked (you can try to fix that) but it is simpler to just added more water to the conditioner tray.
Thus, the easiest way to ensure that the softener tray empties every time (after adding the softener to the softener tray of course) is to top up the softener tray with extra water, top it up to the 'max level' line (keep a bottle of water by the machine). That way, even if only a little water is added to the softener tray during the softening cycle by the machine it is enough to trigger the siphon action and the tray will empty!
Works for me every time, and no need to remove any parts - I used to take the tray out, clean it, scrub the outlet holes that fill the tray etc, but they used to gum up again quite quickly!
Hope that helps
Aug 23, 2009 | Bosch Washing Machines
Bosch Washing Machine Softener Tray not emptying
You need to replace the cold water inlet valve. If the machine is older than one year it may be clogged on the side that moderates the cold water to the bleach and softener compartment. Replacing the valve fixed the problem. During the cycle when the softener dispenser fills it should fill quickly and no or little water should be seen in the soap dispenser area. If a lot of water goes into the soap dispense and little into the softener area the valve is clogged.
Feb 15, 2009 | Bosch Logixx WFT 2806 Front Load...
The softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
Dec 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My front loader Bosch washing machine is not draining in the fabric softener section.
Make sure it is the fabric softener that is not being added. Try running w/o fabric softener and see if the tray is still full. The reason I am asking is that after I run my washer the fabric softener tray is full, with water, not softener. The factory tells me it is because the water fill nozzles have realigned and overspray into the softener tray. Not a big problem, since my system is under warranty I am having them fix the nozzles and then I will know how to redirect.
If it is the softener that is not being added then check to make sure the line is not clogged. You can lift out the bleach / softener try and check for cloggs.
Aug 18, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Classixx 1000: Won't drain
Hope that helps
May 26, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
359 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
