Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman Garage door opener
My garage door will not stay "connected" to the trolly part. Sometimes it does and sometimes it does not. If not, the trolly moves back and forth and the light comes on just as it would if it were connected. I have tried pulling it back on with the hand pull but if it doesn't want to connect it just won't. Then one time you hit the button and it hitches on and works again. There seems to be no rhyme or reason to it.
Thanks for your help.
I couldn't get this to accept the correct model info. It is a Craftsman 1/2 HP Model no 139.53535SRT1
  • CrazyCelt59 Sep 25, 2008
    So far so good. Thanks for the help!!
ON BOTH SIDES OF YOUR UNIT IN THE GARAGE,TAKE A SCREWDRIVER AND TURN,THE PLASTIC SCREWS A 1/4 TURN TO THE RIGHT.ONE MAKES IT GO DOWN BETTER,OTHER MAKES IT GO UP FARTHER,GOOD LUCK.
Posted on Sep 24, 2008
Trolly on garage door opener not working
WE need to know the model number of the unit and more details about what is going on with the unit.
Jul 18, 2016 | Sears Craftsman LiftMaster Chamberlain...
Garage door send receive signal
Caution: do not use LED bulbs with garage door openers. They are a possible source of signal interference between the transmitter and receiver on the opener.
Mar 22, 2013 | Sears Craftsman LiftMaster Chamberlain...
My Liftmaster garage door light sometimes stays on all night after operating the door. If I turn off the circuit breaker for an hour or two, then the garage door opener light stays on for the normal 2...
I would just have someone come and check it out to see if it is the light or the electrical. Hopefully it is only a matter of cleaning it off and and replacing a piece or two. Good luck with the repairs and hopefully it is nothing to serious.
Jason http://goodrowdoorsolutions.com/products-and-services.html
Mar 02, 2013 | Sears Craftsman LiftMaster Chamberlain...
I have Craftsman ½ HP Garage Door Opener Model 139.18458D. It reopens immediately after closing. Sometimes it works normally, and sometimes gives this problem. I have tried adjusting the close force,...
It sounds like the door is traveling too far in the down direction. When it hits the floor the safety causes it to reverse to the open position. You need to adjust the 'down limit' not the force.
Sep 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door sometimes gets stuck and then goes
Don't tighten the chain. It sounds like you have either a broken door spring or the drive gear in the motor unit is going bad. Release the opener from the door and operate it by hand. It should be easy enough to raise that your wife can do it with no problems and it should stay put when released about waist to shoulder high.
Jul 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Have replaced drive gear on Craftsman GDO. Everthing engages and chain moves but door only opens 3 inches are so. Have ajusted opening cointrol on side to max and only 3 inches. When I unlatch GD from...
Loosen the chain enough that you can remove it from the pulley on top of the motor unit. Now with the door closed run the motor until the pulley turns in the clockwise direction and stops. Put the chain back on the pulley and tighten. You may have to tweak the up and down limits now.
Nov 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remotes quit working on Craftsman 53975 garage
It sounds like you have a logic board problem. If your remotes work at all it is not a programming problem. You could pull the logic board and check for loose connections especially around the small transformer. 18 years for an opener is very lucky. Their average life is about 1/2 that.
Oct 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door won't close!
If the main light flashes 10 times when the door reverses it is a problem with the door sensors. Make sure the small light on each sensor is lit and not blinking ever so slightly. If it doesn't flash it is most likely the RPM sensor which is a small printed circuit board just in front of the motor. There is also a possibility that the down force needs to be increased. This is a control on the rear of the motor unit near where all those white wires go. Increase it about a quarter turn.
Sep 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door does not open all the way stops @12 inches
You most likely have a broken door spring. Release the door from the opener and try lifting it by hand. Look above the door for the springs.
Mar 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door sometimes stops during run as if sensor is blocked
wipe off the sensor glass with a isopro rubbing alcohol; it should fix it.
Jan 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
51 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
