Question about Intel Motherboard
OVERCLOCKED IS THERE ANY WAY OF FIXING THIS?AND HOW DO I KNOW WHAT PART IS BAD? NEW COMPUTER ABOUT 6MOS. OLD. IT ONLY BEEPS,WON'T STARTUP.I TRIED TO TAKE OUT BATTERY FOR A MINUTE AND I ALSO TRIED DIFFERENT MEMORY.IT BOOTED TO BIOS ONCE AND SAID IT WAS OVERCLOCKED,NOW NOTHING,JUST BEEPS AND THE FANS WORK.IT WAS FINE TILL NOW. K9A2NEO BOARD/AMD PHENOM X4 CPU/OCZ REAPER DDR2 8500 MEMORY
What to do when i forgot the ''log on'' password?
Posted on Sep 27, 2008
Hi there
I think this is hardware issue and its issue with your ram. Please remove your current ram and try another ram. And see the results if beeps is still running. So its problem with your motherboard
thanks
Robert
Posted on Sep 23, 2008
4 Suggested Answers
SOURCE: My Intel D845EPI/D845GVSR MB processor does not boot up. No BIOS or POST is dispayed on the screen
vfsfsf
Posted on Oct 23, 2008
SOURCE: new asus m3n72-d motherboard bios will not post
If you don't already have a case speaker hooked up to the board, you might want to connect one since there isn't an on board speaker and you will not hear error beeps otherwise.
Also, if you have another non-phenom AM2 processor handy you should really update the BIOS to latest release. Many late model Phenoms will not work on motherboards that have earlier BIOS releases and you will not be able to post. You should then choose "Set Optimized Defaults" and save the bios without any changes then shut down (not reset). When you power on again it should post and you should be able to get into the BIOS.
A third thing you can try (after you get a case speaker hooked up) is using a cheap pair of ddr2-6400 RAM to get the board to post so you can get into BIOS and change the voltage to the correct settings for your RAM if it requires a higher voltage than the bios expects.
Posted on Nov 17, 2008
multilinkent
  • 739 Answers
SOURCE: I TRIED TO CHANGE SPD
Hi lesterwild
Your problem may be a coincidence. sound errors related to hardware problems. check and do troubleshooting on your display card and ram, it will resolve your problem.
thanks®ards
Posted on Jan 11, 2011
My toshiba laptop won't startup
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 29, 2012 | Toshiba Computers & Internet
Long beeps at startup and won't boot up
What is the pattern of the long beeps? one long beep or two long beeps, three long beeps?
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Mar 29, 2012 | Computers & Internet
I tried to upgrade the memory from 1 GB to 2 GB, but after that the computer's screen won't turn on, and i can hear three long beeps and two short ones
The beeps indicate memory issue.
Acer Aspire One Notebook supports upto 1.5GB of memory, so if you try to install 2GB it will not work.
Size 1.0 GB / 1.5 GB (max)
Technology DDR2 SDRAM - 533.0 MHz
Form Factor SO DIMM 200-pin
You can also Click Here to check the specs on the Cnet website.
Regards,
Shrey
May 30, 2011 | Acer Aspire One Netbook 8.9" Notebook
Hello. Tried to increase memory (same make and brand) on a nearly new self build. One of the little plastic hooks that clamp the memory in place came off but could be refitted. Upon startup, got 3...
Check and see if a drive connector got knocked loose on either end, and if so reseat it/them. Reseat all your cards also, just to be sure- the POST beep code (3 long beeps) normally has to do with drive electronics, but it never hurts to check everything.
What bothers me is that your memory will not work in your brothers PC- it is especially important in the winter months to follow ESD (electrostatic discharge) precautions. a spark that you would not even feel is enough to damage memory and CPU's.
Always touch a large piece of metal to discharge static before handling memory or any chips for that matter. Don't wear any "sparky" clothing such as wool when working on sensitive electronics like computers. The best practice is to wear a grounded antistatic wriststrap- they are inexpensive and offer the best protection.
I hope your memory is OK and will work after you go through the other stuff- start by putting your old memory back in and trying it.
Feb 03, 2011 | ASUS 3 Motherboard - M4A88T-V EVO/USB
My ACER ASPIRE laptop,series 5735 Model MS 2253
Because you have a new laptop, it should still be under warranty.
I would suggest a call to the computer company be your first way of fixing it.
Nov 16, 2009 | Computers & Internet
Dell Inspiron 531 (desktop) won?t turn on/boot
You've either got a bad motherboard or a bad processor (I'd lean to the motherboard being bad). I would honestly take this into a computer repair shop and have them check both.
Oct 22, 2009 | Dell Computers & Internet
Computer starts but does not post Athlon XP KM4M DDR
if the system made no beeps after the machine was booted with no ram its a bad board...sorry
Aug 10, 2009 | Computers & Internet
Wont Post get 9 beeps!
This problem is due to the mix of registered and unregistered DIMMs. 64Mb and 128 Mb DIMM's are unregistered memory technology 256MB is registered memory technology. A mix of registered and unregistered memory prevents the server from completing startup, and results in an error beep sequence and a blank screen
Oct 08, 2007 | IBM Netfinity 3500 M20 8657 Server
It wont stay on
probably bad memory, 256MB DDR (PC 2100)
Jan 21, 2007 | E-Machines T2642 PC Desktop
Gainward ULTRA 2400 GeForce 6800 GT
Check to see that the card is properly seated in it's slot. If not, it could be the card is fried...
Aug 25, 2006 | Gainward ULTRA 2400 GeForce 6800 GT, (256...
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
