I have a RCA D52W19 you turn on the Green light comes on but goes back off Tv will not come on.
  • Bassfishing Sep 23, 2008
    Yes it will start three time then goes out that is all. Bassfishing
  • 8,617 Answers
Does the set attempt to start three times then go out or does it just try once then powers down? Please reply to this same post and I will assist you with the problem.
Posted on Sep 23, 2008
  • Sonny Berry
    Sonny Berry Sep 23, 2008
    thats a very common problem for that model TV. You need to replace the flyback. Its flyback 259296 you can get one at the following link and they provide step by step instructions with pictures so you can easially do the repair yourself. Heres the link.
    http://servicemanuals.vstore.ca/
I have an RCA D52W19 rear projection tv that when you push the power button on the green light comes on then goes off and the tv does not turn on.
it is easy to fix. get your self a case of beer and a fifth of jack and then look for cp 150 cp120 and cp114 as i did after pulling the star shaped screws out of the back of the t.v. and then finally throw the damn thing in the back yard and shoot it
Mar 09, 2010 | RCA D52W19 52" Rear Projection Television
I have a RCA D52W19 52 in. Rear Projection Television. When I turn it on, the green power button light comes on and the tv sounds like it's coming on, then it sort of blinks...goes on and off a few times,...
The capacitors known as CP150 CP120 and CP114 often fail which causes that symptom. You can get the RCA repair kit by that same name from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Dec 30, 2009 | RCA D52W19 52" Rear Projection Television
I have hdtv rca d52w19 green power lights shows
Hello Chris this problem is coming from your high voltage circuit which consist of the flyback transformer and the horizontal output circuit, the most common problem when it is acting this way would be bad soldering on the flyback transformer or defective transformer but keep in mind it can also be caused by the horizontal circuit or a faulty lamp as well can cause this problem, what i would recommend is to have a tech come out to service your tv set this should not be an expensive repair since most of the time it is just bad soldering on the flyback thank you hope this helps.
Aug 27, 2009 | RCA D52W19 52" Rear Projection Television
TV will not power on. Button slowly flashes green several times
CP120, CP114 and CP150 need replacement. You can get replacements at the following link under the RCA parts catagory.
Aug 22, 2009 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52 in When my set is Immed, turned
WHAT ISTHAT WHEN MY TV MAKE NOISES THEN STOP FOR AMINUTE ONCE THE PICTURE IS THER THEN 10 MINUTES IS CUTOFF LIKE ITS TRYING TO COME BACK ON WITH THE SAME NOISES
Jul 15, 2009 | RCA D52W19 52" Rear Projection Television
Tv will not turn on
I turn on tv green light comes on and gos off and no picture.
Feb 04, 2009 | RCA D52W19 52" Rear Projection Television
52 inch rca big screen tv will not come on
ck capacitor cp150 if it is bad replace 2 other caps in same circuit 2200uf 16v -220uf35v cp111 cp114?
Dec 09, 2008 | RCA D52W19 52" Rear Projection Television
RCA = flyback?
I just posted a reply to you. Its most likely not the flyback causing that symptom.
Oct 05, 2008 | RCA D52W19 52" Rear Projection Television
Stil confused
Check 3 capacitors on deflection board where the flyback is but they are located on front of board cp150 2200uf 16v cp111 330uf 35v cp114 220uf 35v Look at top of capacitor cp150 if it looks like it is bubbled on top it is bad so replace all 3.
Oct 04, 2008 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
