Question about Mitsubishi VS-45605 50" Rear Projection Television
Mitsubishi vs-45605 with wavy lines
I have a Mitsubishi vs-45605 and when turned on the screen begins to roll vertically. In the past the set used to do this for about 30 mins when turned on and now has this "o so neat" effect permanently. I have read that the set could have a problem with the PIP module but after further research and wasting money i came to find out that this set is part of the VZ7 series and that this set does not have a PIP module. So im back to square one with a little more info. I have the service manual and know enough to get the job done myself, just need to figure out what to do. Any help would be greatly appriciated. thanks!
  • jmwoodward1 Sep 23, 2008
    sorry for the stupid question but are you talking about the wall that the tv is against? Because it is currently in the middle of my room..... best light.
  • jmwoodward1 Sep 25, 2008
    so are the filters replaceable?
    New Friend:
    Problem Solver:
  • 6 Answers
If you have a scope hang it on the tuner video output. If it looks like mine it's the black noise clipper in the Video IF chip removing the sync by mistake, probably a part changed value somewhere. I have the same thing in my VS-5002, works fine on EXT inputs but no sync from tuner, video and chroma OK, just nearly no sync. I have a post here looking for an answer short of changing the IF amplifier chip.
Posted on Feb 18, 2015
  • 4,234 Answers
The first things to check are the filter caps in the main power supply area. Usually this rolling is caused by 60 cycle hum coming from the wall. Try that first and update this with your results. Also, while you are in there, resolder any joints that appear grainy or have rings.
Dan
Posted on Sep 23, 2008
  • ABRsvcs Sep 23, 2008
    The power from the wall is AC 110 V. AC stands for alternating current which varies plus and minus by a total of 110Volts and cycles at 60 cycles per second. This is noise that is usually filtered out of the power suplpy as it converts AC current to DC (Direct Current). If the filters are defective, there will be interference in the later portions of the set that can show up as you describe.
    Dan
  • ABRsvcs Sep 25, 2008
    Yep. Look for capacitors with large values in the 4700ufd range in the power supply and check those.
    Dan
Screen rolls maybe vertical sync
II NEED TO RESOLVE A PROBLEM OF VERTICAL SINCRONICE I SALLBE GRETFULL TO HAVE ADJUSTMENT INFORMATION I SHALL BE GRATEFULL IF YOU COULD HELP ME
May 26, 2009 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi 60" I believe 1997 Model
You need a new PIP module. Surface mount capacitors have leaked out electrolyte and damaged the PIP PCB.
Barneyluc
Oct 01, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Veertical lines
Put a fan in it. Something is overheating in the unit and by placing a small fan in the back, inside the back cover, the lines disappear. Hope it works for you, it did for me.
Sep 07, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi #VS-45605
We had a blue cone on the screen. We have adjusted the sharpness, contrast, and cross hairs. The cone has almost completely disappeared, but we still have blue shadows. Could this mean a blown color tube?
Any suggestions would be greatly appreciated.
Aug 13, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-45607 45" Big Screen
Good Day, Delano1981;
It may cure the problem but I would suspect the 9 Volt source
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND
IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH
ARE ON THE SIGNAL PCB.
This should resolve your TV"s condition.
Good Luck, big IRISH.
May 27, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-60705 Large Screen Projection
thanks for your detailed description of what happened.
replacing the vertical output i.c will correct the problem.
the reason it failed was bad connections on it.
Apr 22, 2008 | Mitsubishi VS-45605 50" Rear Projection...
CS-27403
Older Mits TV's have a PIP circuit board that fails,upsetting the video....here is the solution....
1) Remove PIP PC board ..... discard
2) pull chassis... on underside of main board, locate VP plug
3) Using 22mf 50v NP capacitors, connect pin 5 to pin11
and pin 7 to pin 9......
large pix stable.....but no PIP box.....PIP PCB NLA......
.................T.
Jan 27, 2008 | Mitsubishi VS-45605 50" Rear Projection...
No parts
is it the clear cover protecting the lentil screen behind that you are talking about. if so you dont need this. more often by removing it you get a better picture.
the lentil screen can be brought in the states quite easily.
doing a web search there is a company that will cut you a new one of the roll.
Nov 28, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-45605 convergance
you will need to replace both convergence i.c.s as a pair
Nov 27, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Picture has horiz. lines
There is no vertical hold in the tv circuits now adays. You may find a vertical center or a vertical height. Your problem sounds like (if it has PIP Thats Picture in Picture) its in the PIP module and its a small module that stands up and most models of Mistubishi this module is no longer availabvle. The problem with the module is the small pana caps are leaking and ruins the PC traces. I have heard that theres a kit available on E-Bay to jump out this module. Now if its not the PIP model then it could be a few capacitors in the vertical sweep circuit. Also the B+ feed off the Flyback that supplies voltage to the vertical output IC could have a bad or leaky capacitor in the circuit. If your not a tech or solid state troubleshooter theres not much you can do and SHOULD take this set in to a repair center. Good Luck
May 21, 2006 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-45605 50" Rear Projection Television Logo
176 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
