Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrigerator The ice dispenser flap sticks and the light socket is broken. How do I get the dispenser apart and off the refrigerator in order to fix it?
  • 58 Answers
First, let us explore the problem with dispenser flap. open the freezer and look into the ice discharge chute. there may be an accumilation of ice impeding the proper operation of the flap. next, you have indicated the light socket is broken. is it just the bulb or the socket itself? if you wish to remove the ice/water panel, first unplug the unit,. then you may be able to unsnap the drip tray where one would sit their water glass. if you are successful in doing this then the panel can be removed with a star driver but it depends upon the fasteners used. Always keep in mind to disconnect power before working on unit. I hope this was helpful.
Posted on Sep 26, 2008
I have a Kenmore Elite side-by-side refrigerator with ice and water in the door, Model No. 106.58963701. The ice flap is staying open and letting warm air into the freezer and freezing up the ice maker...
Here is a large diagram and a PDF of the parts. Most likely you have a broken door flap spring broken or the hinge. Click Here=> 8201649 Dispenser Door Flap Kit
Click Here=> W10224328 Spring Here s a PDF of all parts related to your models dispenser=>
KENMORE_106.58963701_REFRIGERATOR_SIDE_x_SIDE_Dispenser_Components
Click here for=> 106.58963701 Dispenser Components
If you need instructions on how to take the dispenser apart please let me know. You really will not see the true problem until you have the dispenser disassembled. Hope this has helped answer your questions, Thanks, Sea Breeze
May 04, 2011 | Refrigerators
My ice and water dispenser sticks. I have to open
The door flap may not be opening and closing completely thereby trapping the ice. There is a solenoid that operates the door that could have stopped working. Can you hear it?
The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Feb 13, 2010 | Jenn-Air JSD2789GES Side by Side...
My GE refrigerator tfx25zp water and ice dispenser sticks for 2-5 seconds after removing a glasss.
most of the new ice dispenser flaps have a 2-5 second delay before they close themselves this is normall operation.
Feb 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser won't work, light won't work.ge side by side fridge
A GE uses a 12 volt bulb . It will not come on , if you went and bought a bulb with the same receptical end . HAS to be a 12 volt .
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser not working
it could be a stuck switch or broken part that operates the switch inside the dispensing unit. The only way to find out is to take it apart and see how it works. I found parts on www.partsdirect,com
Aug 18, 2009 | GE Refrigerators
Ice dispenser is not operating. will dispense ice occasionally. noticed the light in the dispenser opening gets dim. Water is dispensing normally.
When it doesn't dispense , do you hear the auger turning ? If so , then the dispensor flap is not opening completely . This is caused by a rusted plunger in the solenoid which opens the flap . If you use crushed ice often , then could be a build up in the ice shoot which has to be cleaned regularly .
Jul 19, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE profile Artica side by side. I am getting a frost build up
Sounds like the dispensor flap is not closing completely , pulling outside air in . Using a flashlight on the outside of the flap , look inside to see if any light is visible . If so , then the ice flap plunger and solenoid will have to be replaced . Also , excessive crushed ice can also cause frosting .
Jul 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker flap stay open
the solenoid is bad,next time send the full model number it says it's a ge so this should help you out,for now you can get a ball of paper towels and stick it into the shout where the ice comes out to stop the warm air from getting into your freezer
https://www.youtube.com/watch?v=jpXo0svta9s
Feb 07, 2018 | GE Profile Arctica Stainless Steel Top...
Broken ice machine on a jennair refrigerator
Took it apart, figured out how it works and fixed it
Nov 04, 2008 | Refrigerators
Ice dispenser flap won't close automatically
replace the flap spring and selenoid in the despenser area
call ge at 300-851-6200 with the model number and they will send you the parts about 40.00 dollars
May 07, 2008 | Hotpoint FFU00 Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
157 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
