Question about Sony Televison & Video
I turned off my dss reciever & now it will not turn on.
    Sergeant:
  • 300 Answers
Check Fuse
Thank you for selecting FixYa!
azkeyz@fixya.com
IEEE
Wizard Division
Posted on Sep 23, 2008
Reciever shuts off after turning the volume up
You will have to change the volume controller and its circuit board.
F150 Accessories
Aug 12, 2012 | Audio Players & Recorders
Evet time i hook my 1200 watt power acoustik and turn it up it cuts off
Usally When something like this occurs its because the amp cant handle the reciever. Meaning the reciever is pushing out more than what the amp can handle. As a safty feature to save you from blowing your amp or speakers the amp will shut it self down to minimum as you described. This also occurs when the amp over heats or doesnt have enough ventalation and once again as a safty feature to save your amp it shuts down. My first suggestion is to turn the "Loud ON" mode off on your reciever. As this feature can blow your speakers and can also cause this problem. Also do not use any factory settings on your reciever. It is almost always the bass in any given system that causes this so turn the bass down some on your reciever or on your amp turn it down and then adjust up and down from the reciever. Im sure you probably like the bump bump bump, I do to but your going to have to eiather buy an amp that can handle what your reciever is pushing, or turn it down a bit. You should also check the fuses for not only your amp but for the system under the hood near the battery. My own personal experience I have blown fuses when the system shuts down. Hope this helps
Oct 24, 2011 | Car Audio & Video
Im trying hook up a subwoofer to my reciever and its getting power to the amp, however the amp is not powering on.. do you have any idea?
did you hook up the power antenna or amp. turn On wire? make sure you should ha a wire that is to power an antenna and this is the wire that has 12 volts as soon you turn On your stereo and send 12 volts to your amp. but if you don't connect this wire, the amp will never turns On
Jan 04, 2010 | Kenwood KDC-MP438U Car CD/ MP3 Player
Yamaha rx-v461 not working
you have a faulty circuit somewhere, whether its in speaker wiring, or power source, i dont know, but your reciever has an automatic circuit breaker in it for protection, and a faulty circuit will trip it, i would assume it is a power source problem since it wont turn back on, check wiring, plugs and look around, and smell for burnt, or hot components.
Jan 21, 2009 | Yamaha RX-V461 AV Receiver
DS2 to DSS format
Dss Player Pro release 5 has the option to automatically convert to dss or wav upon download.
Dec 20, 2008 | Olympus DS-2 Digital Voice Recorder
Nec dterm80 light flashing green
For the green light, you can turn it off from DSS. On the bottom left hand side of DSS, it is a message button. You can press the button and then your extension button. The green light will go away from the DSS and on your phone. I hope this helps.
Mar 03, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Audio converter for dss audio files
You can convert DSS file into wav format with DSS Player 2000 or the latest version. it can only convert it into wav format. after convert into wav format then u can use any other converter to change it into any other audio format. u can use total video converter or Sonic record now multilanguage software.....
best of luck.....
Feb 08, 2008 | Olympus WS-100 Digital Voice Recorder
My reciever
go to www.dss/keys.com
Dec 27, 2007 | Fortec Star Lifetime ULTRA
Marantz SR-18 NO Sound No Data error for DSS (Directv) only
You need to check the connection of the lead that carries the audio from the DSS to the amp, move it to one of the other channels ie vcr and see if it can be heard when set to and switched to vcr. Then we know if we are dealing with the Amp or the source..
Dec 23, 2007 | Marantz SR-18EX Receiver
TX-DS575 reciever
Normally you hear a clicking sound coming from the inside when you turn on your amp. That's the sound of the magnetic circuit breaker (switch). If you tap your amp to turn it on, and if the amp gets turned on after you did it:), then I suppose the problem is on the relevant switch.
Jul 04, 2007 | Onkyo TX-DS575 Receiver
Televison & Video Logo
21 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
