Question about Photography
No film advance.
Film does not advance after pressing the button; flash works ok; It appears that the shutter does not open.
    Novelist:
  • 103 Answers
Hello drummer 37,   As I recall, this was a peculiar problem with all 35mm film cameras. Your canera could have; a bad battery or batteries, a short to the film advance motor, or corrosion, or bad gears to the film advance motors, or end of film, etc. You would need to open your camera in a darkroom bag and remove any film inside. If no film inside the camera, then do a circuit check from batteries to every electronic component and motor using battery power or bench check the camera's motors by bypassing the batteries with an AC/DC benchtop power supply. Wow - really expensive and time-consuming = complete stripdown and repair. Depending on the camera make, it would be your decision whether to compare repair price to camera value. If it is no longer in production meaning parts need to be cannabalized from another old non-working camera, the cost of repair would exceed the value of the camera. Look for another good used model or move on to a digital SLR camera as your tool.
Posted on Sep 27, 2008
I've just loaded the film into my Canon A-1, and I tried to advance it to the first frame, but nothing seems to be catching the film, and the shutter button doesn't seem to be doing anything either. Please...
What has probably happened is that you have not yet engaged the sprockets into the sprocket holes in the film. Open the back and make sure the film is being pulled by the take up spool under the wind on lever until both top and bottom sprockets are engaged. If there are any torn sprocket holes in the film, cut the damaged film off, cut a new lead in section to half film width, and try again. You will lose a few shots, but the rest of the film will be fine. Shutter won't start working until the film is properly advanced. If you need to get damaged film off the take up spool just press the film return button, the one you would press the rewind the film into the can at the end of the film. It is on the bottom under the sprocket shaft.
Jan 03, 2011 | Canon Photography
Just recieived a used Nikon N80 and it gives the message of open door.Frame counter and film indicator flashes when door is shut and no film is in in camera?
Confirm tht DX shows in LCD. If not then press and hold shift button then press ISO so "DX" appears.Open Camera Back. Insert film cartridge, pull film leader out to right and align with red index mark (inside film chamber on right). Make sure there is no slack in leader.Close camera back until lock release snaps closed. Fully depress shutter until film advances to first frame.
Confirm " 1" and film transport show in LCD. If Film is not loaded correctly, "ERR" show on LCD. Open cack and reload film.
Users manual can be downloaded from:
http://www.lensinc.net/manuals/Nikon_N6006L.pdf
Nov 03, 2010 | Nikon N80 35mm SLR Camera
How do i know when my battery is dead. Every time my pictures are developed, they come out black. how do i use the exposure meter?
The K1000 is all mechanical, the battery only powers the light meter. So even if the battery is dead, then you should still be getting images even if very over or under-exposed.
If the images are totally black on the negatives, then your shutter is stuck open and massively over-exposing your images. If the images are black on the prints, then the negatives have been unexposed and will be totally clear. The latter problem means that the film has not been exposed at all and is either due to incorrect film loading, faulty film winding, or a shutter which fails to open.
To eliminate the possibility of a shutter fault, hold the camera up to the light with the camera back open and fire the shutter at each setting. You should see light as the shutter opens and from 1s to 1/30s should be able to see and hear the difference at each speed.
To check film loading and advancing correctly, load a film and wind film on (remember this camera needs the film leader to be manually engaged onto the take-up spool). Use the rewind crank (do not press the rewind button) to take up the loose film and take a few shots. You should see the rewind crank turn each time you advance the film if it is correctly loaded and advancing. If not, open the camera back and visually inspect the film. It should be securely engaged into the take up spool. With the back still open, advance the film and take a few shots: the take-up spool should be advancing and the sprocket wheel (just before the spool, it's the wheel which engages the holes at the edge of the film) should also be turning. If it isn't, then the film rewind mechanism is faulty and the camera is behaving as if the rewind button has been pressed. It's usually easy to remove the bottom of the camera to check that the button isn't sticking.
If all checks so far are OK then check the film pressure plate on the inside of the film door. It should be able to give a little when pressure is applied and holds the film firmly in contact with the advance sprocket, if not then one of the seating pins on the flat metal spring may have become dislodged and it's usually easy to reseat it. Clean the plate after touching it as it must be grease-free and spotless.
If you try all this and still have a problem then please add a follow up comment and I'll try to respond asap, but bear in mind that as I'm in the UK I may be in a different time zone to you.
If I've fixed your problem, then please take a moment to rate my answer.
Aug 19, 2010 | Pentax K1000 35mm SLR Camera
FILM ADVANCE/SHUTTER STUCK
Start simple and go from there.
I don't know if you have film in the camera so I'll read the following and choose what works for you.
I will assume the battery is working if applicable.
As stupid as this sounds press the shutter release button. If the shutter is cocked it will hold the advance. I've had people come in with this problem.
Not it?
If the film rewind has been pressed in it will disengage the film advance and stop the shutter mechanism as a result. Open the camera and close the back again resets the release.
If there is film in the camera remove it.
It there are important photos on the film and your rewind is not working use a coat to make a light proof black box. Just turn the sleeves inside out and put the camera in the coat. Wrap it so as it is closed to light. Open the camera remove the film and roll the film back in by hand.
OK so now we have a camera open with no film in it.
Open the back and look just below the shutter. On one side will be a very small "lever". This tells the camera that the film has been advanced and the shutter is cocked. Gently move the lever to the right. It should click. Now try pressing the shutter release.
Note that without film in the camera some cameras will not advance the shutter.
It should clear the problem.
If not something physical in jamming.
The film advance system could be jamming. On the side the film advance is on there will be a plastic "gear" inside the camera. Try moving by hand it should turn. You can reset the shutter this way.
Give this a try.
Hope this is helpful, if it gives you some direction please rate this answer.
Thanks
Mar 14, 2010 | Photography
Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Feb 03, 2010 | Nikon F100 35mm SLR Camera
Loading the N8008 camera
1. Set the film speed manually or DX to do it automatically by holding down the ISO button and turning the command dial.
2. Slide the camera back lock releases toward each other to open the back.
3. Insert the film cartridge on the left.
4. Pull film leader over to the red index mark on the right.
5. Close the back, making sure there's no slack in the film, and the lock releases snapped close.
6. Lightly press the shutter button. The film icon will appear in the LCD panel.
7. Fully depress the shutter button to automatically advance film to frame 1.
You can download a manual from http://www.butkus.org/chinon/nikon.htm
Mar 23, 2009 | Nikon N8008 AF 35mm SLR Camera
Samsung Maxima 105 zoom
I have the manual. I'll scan it for you & email it. My problem is that the manual doesn't identify the batteries & I lost the ones I'd removed for storage.
May 26, 2008 | Samsung Photography
No shutter/film advance
with electronic cameras, it is the control circuitry. send it for service. your service agent probably will replace the complete pcb as they don't know or wouldn't care to diagnose which minor component went wrong.
pc-cook.
Nov 15, 2007 | Contax ST 35mm SLR Camera
Pentax MZ 50 film winding problem
Well, I'm not a camera repairman, but it sounds to me (and probably to you too) that the electronics are damaged or perhaps there's dust in the contacts inside. I also have an MZ-50. There's so many electronics involved and they don't age so gracefully. I would consider buying another one off eBay or you can get a ZX-30 (same as MZ-30) for $75 from Blue Moon Camera & Machine with a 1 year warranty (parts and labor). The best way would be, in my opinion, to get a manual, mechanical camera from the 1970s and put a good lens on it. Those seem to last forever. No electronics to worry about. Advance and rewind the film manually. You can use a digital camera as a light meter to set the aperture and shutter speed. I'm thinking of going this route when my MZ-50 finally conks out.
Apr 25, 2007 | Pentax MZ-50 35mm SLR Camera
Photography Logo
172 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Tony
Are you a Photography Expert? Answer questions, earn points and help others
