Question about Astar DVD PLR | DVX-6881 RT
Restore factory settings for dvx6881
I want to restore factory settings for a 3-year old dvx6881.
I factory reset my Wii and need my data back!
It's gone unless you backed it up before! That's what a Factory Reset does :>(
Have a read
Restore Wii U save data backup after factory reset ' IGN Boards ... > Boards > Gaming > Nintendo Lobby
  1. Cached
  2. Similar
Sep 12, 2016 - Title says it all. I want to know if it's possible to restore the save data on my Wii U from an external hard drive after factory resting it. I know that I can't transfer save data between systems via an external hard drive, but couldn't find anything on restoring save data back to the same system after a factory reset. Does restoring your Wii to factory settings lose all of your Wii ... 19 Dec 2014 Used Wii U Question! 12 Dec 2013 Im trading in my wii. How do i wipe all my personal data off it ... 14 May 2008 More results from
Resetting a Wii to factory settings - Arqade
  1. Cached
  2. Similar
Dec 20, 2014 - Remember, the answer is based on this official guideline by Nintendo. Basically, you go to the third page of settings of your Wii and then select 'Format Wii System Memory'. Then press 'Format' and TA-DA! Warm note: after you reset it all the data will POOF gone.
Reseting Your Wii To Factory Settings - YouTube
z? 3:48
  1. Similar
Jan 4, 2011 - Uploaded by GSCommander This is a video of me formatting my Wii to it's factory settings which is erasing all of its data. Some people ...
How to Restore Save Data ' Nintendo Support - Nintendo Switch
  1. Cached
  2. Similar
If you have backed up save data from a New Nintendo 3DS XL using a PC, then simply copy your folders back to the system using a PC. Please ... From the HOME Menu, tap "System Settings," and then "Open." Tap "Data Management." Tap "Nintendo 3DS," and then tap "Save-Data Backup." Image; Tap "Restore." Image ...
Jan 04, 2018 | We Video Game Consoles & Games
You have to donwload latest iOS version in iTunes, you have to upgrade, don't use a version of iOS old saved because iTunes block all restores with old versions.
Apr 05, 2014 | Apple Factory Unlocked I Phone 4s 32gb...
How to take laptop back to factory settings
Depending on the brand and year it was made there may be a factory partition that will restore computer back to factory defaults, if not then a reinstallation of windows will be necessary, If factory partition is available just do a search o Google with your make and model # such as : How to restore an Acer Aspire 7425 to factory defaults using recovery partition
Mar 15, 2014 | IBM ThinkPad T40 2373 Notebook
It just stops when you turn off and on agains sometimes the windows moving thing< lol because I do not know what it is called just stops also. Please help a 67 year old computer wannabe! Thank you...
It's great that you are a 67 year old computer wannabe ... I didn't grow up in the computer age, either.
Anyway, I think you are saying that your system freezes ???
If so ... either you have a memory issue or operating system problem.
First, disconnect all cables. Be certain to dispel static electricity by touching metal. Remove the battery and memory cover. Try reseating (removing and reinserting) your memory (try one module at a time to test).
If still a problem, boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
If you can't access System Restore by Safe Mode, try Offline System Restore:
1. Boot from the DVD
2. Select the Language
3. Click on "Repair your Computer" on the Install now screen
4. Click next on the System Recovery Options screen
5. Click on System Restore.
6. Choose the date to which you want to restore
If still a problem, the last choices are Factory Restore and reinstall. Accessing Factory Restore (restores to the factory settings and will wipe out anything that you have installed or saved on your PC), is dependent on your hardware manufacturer. Boot your system and press F10, F11, Alt+F10, or Ctrl+F11 to access Factory Restore. Follow the prompts.
If still not resolved, you'll probably need to reinstall your operating system.
And ... if I'm off the mark as far as your problem is concerned, please let me know.
Hope this helps.
Jan 03, 2010 | Toshiba Satellite A100-S8111TD Notebook
I have a J5780 which I set up in my las property and now I have moved to my new house I cannot receive or send faxes. What do I do? Is the J5780 registered to my old phone line number and if so how do I...
I have a newer model, and I don't think it locks to a specific fax number, but try this: (By reseting you will lose any stored numbers.)
Here's a link to the manual:
To restore the factory defaults
Press Setup.
2. Press 6, then press 4.
This selects Tools and then selects Restore Factory Defaults.
The factory default settings are restored.
To set the date and time
Press Setup.
2. Press 6, and then press 3.
This selects Tools and then selects Date and Time.
3. Enter the month, day, and year by pressing the appropriate numbers on the keypad.
Depending on your country/region setting, you might enter the date in a different
4. Enter the hours and minutes.
5. If your time is displayed in the 12-hour format, press 1 for AM, or 2 for PM.
The new date and time settings appear on the display.
Nov 10, 2009 | HP Hewlett Packard Officejet J5780 Laser...
Emachine restore back to factory settings
I had to restore my Emachine. I have Windows Vista
(1) Go to start menu
(2) Click on all programs
(3) click on Emachine
(4) click on Emachine recovery management
(5) Click on restore on the bar across the top
(6) click on restore to system factory default
It takes about 20 mins.
Sep 07, 2008 | Computers & Internet
Screened numbers
you can try restore the factory defaults by going to:
1- setting
2-phone setting
3-original(or factory)setting
then enter the security code which if not changed should be 12345 for all nokia phones.
Jun 22, 2008 | Audio Players & Recorders
Ipod hard drive
Try a restore from within iTunes. Will restore it to factory settings.
If that doesn't work you'll have to send it in for service or buy a new one.
Nov 28, 2007 | Apple iPod MP3 Player
Only red bulb working
Tried restoring to factory settings? Only blue was working for me and it helped *shruggs*. You can try... On the remote, press MENU then 1 2 3. Hit Enter. And it's restored to factory settings :]
Aug 24, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Astar DVD PLR | DVX-6881 RT Logo
29 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
