Question about HP w1907 LCD Monitor
When I switch on warcraft(or other games), the monitor shuts down but power light is on.
I experience this when the screen resolution is changing. any ideas?
    Problem Solver:
  • 14 Answers
This is normal. BUT it should only do this while launching, once it hits the main menu clearly. It should be fine.
2. If you alt tab while the process is running, you may see the resolution change. But if you close it properly than it should not change except for those reasons/times.
Contact me if none of those do work,
Regards,
Asitomani
Posted on Feb 22, 2009
I installed warcraft III frozen throne but when i launch it it says "input not supported". Help. thanks
It is because your game display setting is different from your monitor.
1st Step Check the screen refresh rate of your monitor and the Screen Resolution..
to see the Screen Resolution
Right Click on "Desktop">Properties>Settings
to see the refreshrate of your monitor. Right Click on "Desktop">Properties>Settings> Click "Monitor" tab. then you will see the screen refresh rate.
to fix this follow this steps.. Click "Run" > type "regedit" > go to "HKEY_CURRENT_USER" > SOFTWARE > Blizzard Entertainment > Video. and on the right panel Double click "refreshrate" > click "decimal" then change the"value data" to the same refresh rate of your monitor, then press "OK". then after that Double click again the "resheight" on the right panel then click "Decimal" change again the "value data" with the same of your monitor (see screen resolution) click "OK" do. the same on "reswidth". (see images below)
Hope this help.. Don Masta
Apr 29, 2011 | Blizzard Entertainment WarCraft III: The...
Warcraft 3 problem with monitor (turning to sleep mode)
Hello
If only monitors turns off it means that game is in higher resolution than monitor can support.
However, warcraft is preety old game and such things shouldn't happen.
Possible sollutions:
1. Download lastest Video card drivers from producent website
2. Install lastest DirectX
3. If still problem occurs:
Click Start->Run...
enter "regedit" -> press enter
open following directories: HKEY_CURRENT_USER -> Software -> Blizzard Entertainment -> Warcraft III -> Video
doubleclick on "resheight" -> check "decimal" and enter 640, apply with OK
then doubleclick on "reswidth" -> check "decimal" and enter 800, apply with OK
Run game and see if it helped.
Cheers,
Mike
Apr 21, 2010 | Blizzard Entertainment WarCraft III: The...
LG stuck in powersave mode
Connect it to a different computer, e.g., a notebook computer,
and set the screen-resolution to 800-by-600, and see if the monitor works.
Change the screen-resolution to 1024-by-768, and try again.
Change the screen-resolution to 1280-by-1024, and try again.
Connect a different monitor to your computer,
and set the screen-resolution to 800-by-600.
Then, disconnect the "alternate" monitor, and connect your monitor.
Nov 25, 2009 | LG W1942TQ-BF 19 inch Monitor
Lg 22' monitor was widescreen now has black bars!! Cant remove ?
the grpahics from wowc burnd the sides of your monitor. your pretty much screwed if you keep playing that game
Aug 16, 2009 | LG Flatron L1710S 17" LCD Monitor
My monitor cant display warcraft games
Check the setup in your game for a resolution that your monitor will take (Try 800x600)
May 10, 2008 | Computers & Internet
Samsung SyncMaster 17" LCD Blacks out
If you have a second monitor, you could use your computer until the monitor goes black... then plug in a replacement monitor. My guess is that one will display black too...
My gut feeling is that your VGA card is on the fritz... I'm not convinced it's your monitor. Do you have a replacement VGA card you can try? I'll bet that'll take care of the problem.
Apr 22, 2008 | Samsung SyncMaster 17" LCD Monitor
Monitor is off center
try using windows mode for WoW so youll be able to access the desktop..
Jan 25, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Monitor shut down
It is possible that you are playing the game at a higher resolution than your video card can support. Even if your computer is capable of displaying a high resolution during normal browsing activity, that doesn't mean it can support the same resolution during graphics-intensive use. Try turning down the resolution and the quality in your game options and see if the problem goes away. I ran into this same issue when trying to power a 1920x1200 monitor with a GeForce FX 5200 Ultra and discovered the solution is either a lower resolution or more graphics power.
Regards,
Javabytes
Nov 19, 2007 | Evga GeForce 7800GTX KO 256MB PCIE Graphic...
Dell 2407 a04 Turns on (for 2 seconds) then off
your pc may be set to a resolution that is out of range for the monitor. Boot into "Safe mode" reset the Display settings to 640 x 480. reboot into normal mode then change the screen settings to your desired resolution.
Sep 07, 2007 | Dell UltraSharp 2407WFP 24" LCD Monitor
Power switches off
Try changing refresh rate or resolution. You might be using one that your screen can't work with. good luck
Jun 09, 2006 | Philips 170C4FS 17" LCD Monitor
HP w1907 LCD Monitor Logo
87 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
