Usb pen doesn't works winxp
I have a notepad with winxp, but now the usb port doesn't work.
Please help me
jose beirao
jose.beirao@netcabo.pt
    Scholar:
  • 80 Answers
Hello did it detects the usb drive but you are not able to view in my computer ? if it is so than it show that usb port is locked by changing registry. so reply for the registry settings
Posted on Sep 26, 2008
Transcend 16 gb pendrive is not recognised
Right-click on COMPUTER. Select PROPERTIES, Go to DEVICE MANAGER. Under UNIVERSAL SERIAL BUS CONTROLLERS, check all the USB ports to see if they are working properly. If the USB PORT in which you have inserted your pen-drive, is showing an error, right-click over it and select PROPERTIES and make a TROUBLESHOOT.
If this troubleshooting doesn't help you, use another computer to check if your Pen-drive is working there. If the problem persists, go to the manufacturer's service center and ask for a replacement or repair.
Hope this helps, Mrityunjay.
Jun 25, 2012 | Electronics - Others
My transcend 4 GB works fine on my office computer but not on my computer at home. pl. help
Assumption your PC do have enhanced USB ports ie USB 2.0 and using WinXP OS.
If your home PC Operating System WinXP, you should at least have WinXP Service Pack 2 installed on your PC for the USB ports to function using Microsoft generic USB drivers.
If your USB ports are using VIA chipsets, sometimes you need to install the VIA USB drivers too.
Hope it helps.
Sep 19, 2010 | Computers & Internet
How to set up windows xp to laptop without using cd rom
HELLO BROTHER ITS VERY EASY TO INSTALL XP THREW PEN DRIVE PLZ CONTINUE THESE STEPS TO INSTALL XP THREW PEN DRIVE
STEPS:-
1.
http://files.extremeoverclocking.com/file.php?f=197/</code>
CLICK ON PRIMARY DOWNLOAD SITE & DOWNLOAD USB DRIVE BOOTABLE TOOL
2. AFTER THAT ON THE ABOVE OF THIS PAGE CLICK ON
http://files.extremeoverclocking.com/file.php?f=196/</code>
3. COPY XP FILES ON PEN DRIVE WITH FOLDER NAME(WINXP)
4. BOOT FROM USB
5. AFTER COMPLETE BOOTING U WILL SEE THE PROMP C:/>
6. C:/>SMARTDRV
7. CD WINXP
8. C:/WINXP>CD I386
9. C:/WINXP/I386>WINNT
10 NOW UR COMP START SOME FILES AFTER COMPLETING THIS UR COMP WILL RESTART
11. DOESN,T REMOVE UR PEN DRIVE BUT SELECT OPTION BOOT FROM HARD DISK
12. DONT FORMAT THE C: AND CONTINUE UR INSTALLATION AS A BOOTABLE CD
Thankyou
Amit Bhardwaj
May 08, 2010 | Microsoft Windows XP Home Edition
4 Gb pen drive can't poen
Your drive could be corrupt. The first thing I would do however is make sure you are plugging it into a good USB port. If you are using a desktop with USB ports in the front, and are plugging the drive in there, remove it and plug it in to one of the USB ports on the back of the computer. Many times the front ones will have issues with certain USB devices. If that doesn't work, you very well may have a bad usb drive. I would try it on another computer if switching the usb port doesn't help, to see if the drive is truly not working or just a driver problem on your computer.
Apr 20, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
BIOS settings to boot from pen drive
STEPS:-
1.http://files.extremeoverclocking.com/file.php?f=197/</code>
2. AFTER THAT ON THE ABOVE OF THIS PAGE CLICK ON http://files.extremeoverclocking.com/file.php?f=196/</code>
4. BOOT FROM USB
6. C:/>SMARTDRV
7. CD WINXP
8. C:/WINXP>CD I386
Apr 03, 2010 | Computers & Internet
Transcend JF v302GB doesn't work on Laptop
try on another usb port. this helps some times. U can check ur pen drive on another system. If it is not working there tehn get the pen drive replaced. If the pen drive is ok, reinstall ur o/s
Aug 12, 2009 | Electronics - Others
How to install drivers of pen drive
your pen drive is not recognize by the usb port onyour computer, remove the pen drive from the port and insert it to another usb port on your computer, if you still having problems, restart the computer and try again on a different port.
USB drives do not drivers for it to work.
Jul 03, 2009 | SanDisk 8GB microSDHC Memory Card with...
Genius g-pen 450 driver problem
Try to change usb port and reinstall driver some port on your PC may not regcognize it.
After I solve it , everything work fine :D
Apr 15, 2008 | Genius EasyPen (K9418400)
Usb problem
You shouldn't need the USB driver 2.0 from mercury because windows installs this with SP2. Suggest you un-install what you installed from mercury & update your version of windows (completley), through "Windows Update". Once windows is all updated & you have finished with a reboot. Plug your pen drive in a opened usb port. Open windows explorer. Scroll down & you should see an icon (left side of explorer), thats named like, Removable Disk. Give windows time to see the device. After a few minutes if your pen device does not show up try another usb port. One you know does work. If after a couple of minutes go by & you still don't see the device listed in explorer I would say the device is defective. Your Mp4 uses a cable to connect to the usb. Try connecting to another PC's usb port. It is possible the cable is dirty or bad.
Jan 13, 2008 | Mercury P4VM800M7 Motherboard
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
