Question about Garden
Need replacement bushing for ryobi cs30 17" curve shaft trimmer hopefully locally
I have a ryobi cs 30 model #ry30020b---serial #ah312068 trimmer looking for the upper drive shaft bushing (plastic). When the weed eater is running the shaft gets extremely hot and even melts the plastic of the handle. HELP.
pumpkinman
  • 1165 Answers
SOURCE: How do i replace a rewind spring in a stihl fs 45 weed eater
you have to kake sure u wind it the rite way there should be tension on the spring when it is wound and if let go should return if it does that u have it rite...the little plastic peice must be connected to the hooh on the spring
Posted on Jul 25, 2009
SOURCE: lost manual for troy bilt weed eater mod#tb514cs 4cycle
I didn't find that exact one either, but recently had to work on my Yard Man 4-Cycle Straight Shaft and used a Troy-Bilt manual for a similar trimmer - worked great.
If you don't find yours at this site, maybe a similar one will work. It looks like the difference is the TB525 receives attachments. If you're trying to fix something right now, here's the manual for that one until you find yours:
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/big_red_tb575ss.html
Posted on Sep 08, 2009
mrgauge
  • 17 Answers
SOURCE: Want manual for RYOBI 31 cc 700r weed eater
Try this link:
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/700r_1.html
Posted on Oct 01, 2009
Testimonial: "Thank you! Just what I needed."
SOURCE: how do I replace the pull cord on a ryobi #ss30 weed trimmer
You need a long skinny T25 torque driver (sold in a pack at Lowe's with 3 other sizes.)
Take off the 4 screws in the back to reveal the piston. Get a wooden dowel (or a wooden spoon if your wife isn't around) and stick it in to the piston to block it from spinning.
Now take that T25 and stick it in to the front pulley (cone shaped silver item that is preventing the housing from coming off) turn to the left and it should come off.
That should come off to reveal about a 1"x1.5" piece with a spring wrapped around it. That can also turn to the left and come off with an adjustable wrench or pliers.
Once that is off the housing should come away and you'll be able to get at the pull cord after removing 4 more T25 screws.
Posted on Oct 14, 2009
SOURCE: Ryobi 700r how do you replace flexible drive shaft
I have an Expandit Trimmer and i think the flexible drive shaft has become detached from the trimmer head ,isit possible to re -engage it
Posted on Jun 14, 2010
Excessive vibration in Ryobi RY30120 trimmer
the center bushings that holds the shaft center are worn and need to change. this damage is caused bu using a to heavy nylon and because of the damaged you will get vibration on all attachments used
Aug 03, 2012 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Is the Ryobi model CS26 considered a professional weed trimmer?
The Ryobi curved shaft trimmer is a consumer grade trimmer. Both the 26cc & the 30cc engines from Ryobi (Homelite) are pretty light duty. They have 1 piston ring and use an anodized aluminum piston and cylinder. A commercial grade engine would have 2 or 3 piston rings and the cylinder and piston would be chrome plated for longer life. Look for the emissions label on your trimmer. The emissions code of C would indicate a 50 hour emissions longevity (consumer grade). A code of B would indicate 125 hour emissions longevity (estate grade). A code of A would indicate 300 hour emissions longevity (commercial grade).
I hope this helps.
Dec 29, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I can pull my string from a ryobi cs 30 and it wont go back
Either the rewind spring is broken or the starting spool is stripped. Either way you have to open up the entire unit. Check those two things and good luck...Lee
Oct 11, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I lost my owners manual for my ryobi 700r weedeater. serial number-105123136
I would go to www.managemyhome.com and type in the model # and it will display the manual which you can download to your computer.
May 17, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
589 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
