Question about LaCie Ethernet Disk Mini, 500 GB Hard Disk Drive with Gigabit Ethernet & USB 2.0 Interface, 7200 rpm... IDE Hard Drive
Data recovery from a bad power unit
A few months ago my lacie etherdisk's power unit died. when you press the power button, it comes on for a few seconds and then shuts off. now, the hd is still intact as far as i can tell and i placed it in another maxtor external inclosure. my problem is, i need to recover my data from the disk. I have yet to find a way to do this because of the filesys lacie uses when it formats the drive.
i definately do not want to loose the some 5gb of data on the drive. how do i recover it off the hd without buying a whole new etherdisk and swapping drives?
Thanks for the help but it isnt a PC
Posted on Oct 01, 2008
    Problem Solver:
  • 29 Answers
Your data on the HD is probably OK, If the PC powers up and then shuts off it usually is a heat problem. If it shuts down quickly it may be a sensor on the motherboard that detects heat and may be bad and the motherboard will need to be replaced.
If it runs for a minute or two then shuts down there is heat somewhere causing problems with the processor and the motherboard is protecting the system. Check the fans inside the PC, specifically the small one on top of the processor, then the case fans. Also check the power supply fan and see if it is working, if not the heat may be cutting the power supply's power to the PC causing the shutdown.
rmatheson@wowway.com
Posted on Sep 30, 2008
How to restore to factory default
To perform an External Manual Reset of your handset to restore to factory settings, read instructions below and then perform.
  1. Power off the phone, press and hold volume down button, press power button.
  2. Screen will come up with "Fastboot", press Vol down key to cycle through choices until you get"Android Recovery", then press Vol up key
  3. Wait for the "triangle ! / Android" screen then go on to step 4
  4. Tap on bottom right corner of the screen (may take a few times). a menu will come up
  5. Tap on "wipe data/factory reset", and tap OK. Another Confirmation screen will come. Tap Yesand OK
  6. After userdata is cleared, the "reboot system now" option will be highlighted by Default. Tap OK.
  7. Phone will reboot to initial setup MOTOBLUR screen.
Tip: Once you've reset your device, you can use your existing account to sync your contacts back to the phone.
(Steps on Gingerbread 2.3)
Remove and remount the battery and power up
If the phone still does not boot up to the MOTOBLUR screen, then perform the following Factory Reset instructions:
  1. Power off the phone, press and hold the Volume down button and Power buttonsimultaneously while powering up the unit.
  2. Screen will come up with "Fastboot" at the top of the screen, press Volume down key to cycle through choices until you get "Android Recovery", then press Volume up key to boot in this mode
  3. Wait for the "triangle ! / Android" screen then go on to step 4 android_recoveryscrn.png
  4. Press both Volume up and Volume down key simultaneously. A Recovery Menu will come up
  5. Tap on Volume down key until "wipe data/factory reset" is highlighted, and tap Power button. Another Confirmation screen will come. Tap on Volume down key until coming to Yes and tapPower button
  6. After userdata is cleared, the "reboot system now" option will be highlighted by Default. TapPower button
To Perform a Factory Data Reset through settings menu:
  1. From the Home screen, press Menu
  2. Touch Settings
  3. Touch Privacy
  4. Touch Factory data reset (Read notes for other options)
  5. Touch Reset Phone
  6. Touch Erase Everything
Oct 20, 2014 | Samsung Cell Phones
I have a LaCie TB080LL/A 160GB Hard Drive, that performed flawlessly until a few weeks ago, when it started shutting down on it's own. I push the button to start and it fires up but then shuts down. I...
It's shutting down because the power board from the case overheats and fails. Basically this drive is dying - using it for archiving purpose is the absolute worst decision you could make since you can be absolutely sure it will die for good very soon. There is nothing you can do to fix it, it's normal wear caused by its advanced age.
Just junk it and get a new one.
Apr 23, 2011 | LaCie (300740) 160 GB Hard Drive
Lacie 2 big does,nt boot
Hmmm, reseting worked on mine. Identical symptoms except light stayed blue, not red. Unable to power down.
Before trying to get the drive working I got the data off using the procedure in the second post of this thread:
http://www.linuxforums.org/forum/peripherals-hardware/126831-reseting-lacie-2big-network.html
You need a linux system running. Maybe a live cd will do. I installed on an old IDE drive I had.
I then rest the decive using this procedure from Lacie and my drive is working again. Worthless though, because I can't trust it.
The procedure below will reset the 2Big Network to factory settings:
IMPORTANT NOTE: Following the procedure below can ERASE ALL DATA on the drive. Prior to following these directions, verify important data is stored securely on a different storage device.
Switch the drive OFF. Once it has shut down, ensure the power switch remains in the OFF position.
If the drive is in the SAFE mode, move the RAID switch to the BIG mode.
PRESS AND HOLD the button on the front. MOVE the power switch to the ON position. The light on the front of the drive will start blinking.
Once the light stops blinking, RELEASE the front button.
When released, it will begin BLINKING AGAIN. When it stops, PRESS AND HOLD the front button. The light will begin to blink again.
When the light stops blinking, RELEASE the button. The drive is now resetting itself. Switch the RAID selector back to SAFE if desired.
To restore data if it was lost during the process, recreate the shares and users on the unit prior to the reset. Any firmware updates applied will need to be applied again.
Sep 02, 2009 | LaCie 2big Network (2-disk RAID) (301257U)...
My mac is not recognizing my Lacie 1 TB, it started a week ago. It used to work fine for 2 months or so. I got this Lacie less than 3 months ago. I have fully stored my all my music there, but now I can t...
I had the same issue -- turned out that power supply was going bad so the drive wouldn't spin up all the way; this could explain the strange noises you're hearing. I put in a support ticket with LaCie at their website and they sent me a new power supply at no charge (I was within the warranty period, I think).
Mar 08, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Disk will not power down. Has vanished from my computer, but router IDs it.
Well according to LaCie's support when the power button is failing to work and the fan becoming inconsistent it is due to the power supply failing.
This is because the OS controls the power button and if it cannot boot fully because of a power problem, then functions of the drive are turned off, including the power button.
They are going to send me a new one.
Sep 23, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
How to recover data from lacie etherdisk when it does not keep a network conntection.
I'll have to look into it a little more but off the top of my head I would say that the nic may be going bad or some other component of the etherdisk. You can try opening it up and putting the hard drive into an enclosure and connecting it to a pc via usb to get the data, you can also then share the usb drive and use it over the network, however removing the hard drive may void any warranty you may have. If the hard drive is in fact bad then you should be able to replace it and then continue to use the device. I'll get back to you when I get more info about the device.
Sep 21, 2008 | LaCie Ethernet Disk (300788) 1000 GB...
Lacie 500 GB usb external hard drive clicking, and blinking....
had the same problem: (soft) clicking sound, orange/yellow blinking LED
Tried another power supply: nothing
Reattached that power supply back to the drive it was connected to: same problem there now as well!
Tried yet another power supply: working (all drives)
My guess is that the power supplies are the cause of the problem. Taking mine back to the shop next thing tomorrow morning...
Feb 18, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
I think I fried my LACIE 500gb drive
Sadly if you fried the drive with that PSU cord it would be pretty hard for a home repair. If you know its definatly dead, I would just remove the drive from the external unit and try to connect it internally to a computer. If the adaptor is different you could buy a cheapy online somewhere.
Jun 18, 2007 | LaCie (300740) 160 GB Hard Drive
Open Questions:
See all LaCie Ethernet Disk Mini, 500 GB Hard Disk Drive Questions
LaCie Ethernet Disk Mini, 500 GB Hard Disk Drive with Gigabit Ethernet & USB 2.0 Interface, 7200 rpm... IDE Hard Drive Logo
145 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
