Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Smells like burned
After the power outtage(IKE), turned refrigerator on and a strong electrical burning smell
it felt like cooling for a while but smell was too strong. turned it off.
did not take more than 15min.
  • francis rivero May 11, 2010
    were you able to locate where the smell is coming from? is it from the bottom or rear of the refrigerator? is it coming from the inside but more on the freezer section than the refrigerator section?
    was the refrigerator flooded?( from IKE )?
  • Whirlpool Master
  • 5,568 Answers
Since power outages aren't always polite and absolute, your fridge may have been subjected to low line voltages for an extended time and gee, Whirlpool still hasn't figured out how to protect their product from this kind of damage. We lost one the same way years ago in CA; we came home after being gone for hours, smelled the fridge, checked the line voltage which was wandering around 25 volts +- ~2 volts. Enough to burn the compressor windings but not enough to start it.
In that case, the electric company paid for the compressor replacement on our two-year-old Whirlpool. If you can dig up anyone who was noting the line voltage, maybe you can file a claim with your utility.
Posted on Oct 01, 2008
MIcrowave emits an electrical smell while cooking. It still cooks, but has started emitting an odor recently when in use.
Is the smell ionized (the outside smell of a cold winter morning air) or more of an electronic component burning??? if it's more of an ionized smell it could be normal, (if the smell is strong) it could be a leaking high voltage cable (electric arching) bad insulator, if it's more of an electronic component burning smell, it could be a overheating component, in both cases you should have it checked by a professional technician...
Cheers!
Jun 25, 2011 | Sharp KB-6024MS Stainless Steel 1000 Watts...
I have a burning smell coming from inside my kitchenaid superba side by side fridge. It smells like a burning plastic. The fridge still turns on and keeps things cool, but it started to kick out that...
Remove the power plug and move your fridge forward. Now look at the rear bottom side of the fridge to see if there are any parts that heats up. You can trace this to the smell emitting from the heated part and confirm. It can be the motor, contactor or the defrost timer.
Mar 18, 2011 | KitchenAid (KSRD22FKST) Side by Side...
The unit works as of right now...but there is a smell of something burning
Quite often, if you smell like a plastic burning smell, one of the capacitors is faulty, and should be checked immediately. Quite often the compressor start capacitor, will get hot and start to melt. Have it checked by qualified technician or electrician, as they are dangerous and can give a fatal shock if not experienced with handling them, even when power is shut off. $20-$30 part, and 1/2hr. labor should take care of it. The cover on roof unit, has to be removed to access the capacitors, so watch for bees, wasps, when you do so. Make sure power is off at breaker panel.
Aug 01, 2010 | Coleman Heating & Cooling
Maytag Neptune Dryer with strong "burned electrical wiring" smell
Sounds like the motor went out. Before trying to start it it needs to be inspected. If you are not comfortable opening up the cabinet then I would would recommend calling a service tech. If you need further assistance please let me know.
Ken
Mar 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Smelt burning smell in the morning stopped cooling
I suspect the start relay burnt on the compressor. Now the compressor can not turn on. You need to repalce the relay.
Sep 04, 2009 | Kenmore 53542 / 53544 Side by Side...
Maytag model (MTB1950GR) tripped off the power switch and smell
Hi, It sounds like the relay onyour compressor. They will smell when it goes bad. Remove the rear panel on the back of the refrigerator and see if the smell is around the compressor.
Please let me know If I can assist you further.
Vic
May 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Mar 11, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Strong burning smell
probably the defrost heater has shorted
Jan 17, 2009 | Whirlpool ET1FHTXM Top Freezer...
Oven light switch shorted out.
I scheduled a GE technician to make a home visit to replace the failed parts.
May 30, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
Whirlpool GC5SHEXN Side by Side Refrigerator burning smell
How long had it been plugged in when you started to smell the burn. What kind of burn do you smell, is it an electrical burning smell or a smoldering dust burning smell.
supertechks
Nov 21, 2007 | Whirlpool GC5SHEXN Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
387 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
