Question about Milwaukee 5321-21 Rotary Hammer
Spline drill bit won't spin
I have a Milwaukee 5321-21 roto hammer and the drill bits won't spin, it just hammers. What could be the cause of this?
  • 2,176 Answers
There a a few things to look for, first is the selector on top in the hammer only position or hammer with rotation. Second look at the spline bit, does the splines look worn excessively also try and look in the nose of the tool for spline condition and last the clutch mechanism might have come apart. Good news though this tool might be covered under warranty, some had a 5 year coverage.
Posted on Dec 18, 2008
    Problem Solver:
  • 17 Answers
It might be jammed check it
Posted on Sep 26, 2008
How can I fix my drill. I was drilling and it froze up on me. You can turn it one way but not the other
Place the drill bit in a bench vise with the whole machine on it together spray the chuck in with good enough wd40 and take a bench hammer and a great plastic hammer , place the angled tip side to the 3 claws of the chuck that are holding the bit and beat slowly and with care the machine from the bit some times switch inbetween the place to beat every claw of the chuck make a little time to do this but do not forget wd40 to spray after and if the machine is beat from the drill spray the whole chuck inside and try to unlock in the most cases it will function again , otherwise there must be an chuck replaced.
Jan 15, 2016 | Milwaukee Tool Milwaukee 18V 1/2 In Hammer...
Quick change clutch is locked
Push the rubber sleve off the drill bit and up the drill bit then the plastic ring. release the clip around the spindle. Slide the clip and chuck sleve forward and remove the ball sitting in the spindle. You should then be able to pull the bit from the machine. If it does not want to come hold the bit in a vice and tap the spindle off the end of the bit using a suitable punch. Rebuild chuck in reverse.
Jan 29, 2013 | Milwaukee Electric Tool Milwaukee 5359 -...
How to remove bit from the 5351
the parts are obsolete to replace in the most case if it will come out the driving guidance is often worn in the bit holder and a
lockup will repeat soon
Sep 09, 2012 | Milwaukee Drills
I have a hitiachi DH38ye drill and it won't accept the Bosch spline bits. they go in ok but the chuck won't lock. The drill accepts the hammer bits fine but won't accept the drill bits
you have me stumped on this one. The tool you have is a spline shank hammer and it should accept all standard spline bits and also hammer iron that is made for these. Is it possible that the Bosch bit has a burr on the splines not allowing it to lock? I have checked the Hitachi site and found no reason it would not work. I will continue checking though.
Apr 23, 2011 | Hitachi Drills
Stuck chisel
if you have access to a vise I would lock the chisel in it and pull on the release collar and then take a dead blow hammer and "tap" on the drill to try and pull it away from the chisel.
Jun 28, 2010 | Bosch 11265EVS 158 Spline Combination...
I need a parts manual for a milwaukee 5316-21 rotary hammer drill , where can I get one?
Go to Milwaukeetool.com and look under parts manuals. Type in the model you need and all the electrical/parts drawings will come up. You will need the serial number as well to get the most current drawing.
Feb 12, 2010 | Milwaukee Tool Milwaukee Hammer Drills 1 -...
My milwaukee 5316 rotary hammer drill wont spin,just hammers
Could be a couple things, do you have the selector in the rotation mode, also there is an internal clutch that might have broken or the splines on the spindle might be rounded. If it is the clutch you would have to take it in for repair, it is extremely tricky to work on. Take the bit out (make sure you are using the right bits for this tool) and look at the splines to check their condition. Let me know if I can help more
Aug 25, 2009 | Milwaukee Tool Drills
Stopped working in mid drill. squeeze the trigger, nothing happens
It could be a dirty switch connection in the trigger assembly , it happens to me on my electric sanders all the time , just open it up and try blowing it out with an air compressor
May 23, 2009 | Milwaukee 5318-21 1-1/2" Spline Rotary...
Milwaukee 5321-21 Rotary Hammer Logo
501 people viewed this question
Top Milwaukee Drills Experts
Jim Thurston
Mike
Are you a Milwaukee Drill Expert? Answer questions, earn points and help others
