LG washer/drier 7/3.5kg. WD-14331AD
I was wondering if this washer /drier was still under guarantee as it doesnt spin properly on any programme. I have had so much trouble with it.I have no paperwork as in moving it was lost i have had it just over a year from the previous person. his name was Mr Paul Moate. I was wondering if you could trace it back for me .
My phone number is 07714747573.
Thanking You
  • 1294 Answers
SOURCE: need a user manual for lg washer dryer wd 12331 ad
Click on washing machines, (below FIXYA) on this site, find your model, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Posted on Jan 21, 2008
SOURCE: Washer LG Model WD-8013F Noisy & vibrates badfly when spinning
I had same problem, the bowl is supported by (2) large springs from the top & two telescoping shock absorbers underneath.
I inverted the machine, found a large hollow retaining plastic bolt had falled out of the shock absorber,causing the bowl to be out of balance & the drive belt to be missaligned.
I reinstated the plastic retaining pin/bolt then tried the machine again.
Now the damn thing refuses to wash or spin.
I'm not happy.
Posted on Nov 06, 2008
SOURCE: drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Posted on Nov 22, 2008
  • 161 Answers
SOURCE: IE problem
This is a water inlet error. Shut the water off and remove the hoses. Look ito the valves where the hoses screw on with a flashlite. If the filter screens are obstructed pull them with needle nose pliers. Clean them and replace them into the valves. Re attach hoses and try machine. If it still shows the code you have a bad valve.
Posted on Jan 28, 2010
  • 67 Answers
SOURCE: How to replace bearings on LG WD-1019BD washer?
To get to the bearings you need to remove the rotor as you have done, remove the front, you need to push a card under the lip of the top at the front to open the top to get out the front. Then then you need to undo all the bolts in the middle of the tub, then take out the inner drum and then you can hit the bearings out with a drift, Don't just replace the bearings, you also need to replace the seal and spider which is the 3 legged part with the main shaft on it, otherwise if you don't replace all the parts listed it will not last long before the same happens again. The problem is caused by the seal letting watter into the bearings, the new seals are mdified to help stop this happening.
Posted on Apr 17, 2010
Hi, I have a LG Tromm WD-14331AD. At the start of the wash cycle, water will dispense, but not a lot. When spinning, there is hardly any water in the drum and water just stops dispensing.
A front loader only uses a very small amt of water. That's the point of front loaders. Make sure u only use a very small amt of detergent also. And use white vinegar in place of fabric softener. If washer is slow to fill you can check the filters in the supply lines. Take the water lines off the back of the washer and check the filters in the washer
Jan 01, 2017 | LG Washing Machines
Candy as108
IT has shorted out u will need to replace board
Aug 21, 2013 | Washing Machines
My LG intellowasher 7,5kg WD- 8016c is flashing the letters OE Can you please tell me what this means
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
LED display models LCD Display Models
Step 1: Check the drain pump filter.
Step 3: Confirm that the washer is leveled properly.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
NOTE: Perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | Washing Machines
Do I need a part to convert my Maytag gas dryer/washer combo back from propane to Natural Gas?
Yes you can, but whether you should is another matter. I purchased a new dryer and needed it to be propane need to get the proper orifice (which lets the gas in to the burners) changed out. Natural gas orifice has a larger hole than a propane orifice. In addition, the regulator must be modified. It may involve flipping an insert under the cap (typical of stoves) or it may require conversion parts packed in the conversion kit (order one specific to your drier). This regulator is part of the piping within the back of the drier.
Incidentally, conversion orifice(s) should be included with the drier and screwed to the body in a clip. When you change it over and label the equipment as converted to propane, put the old natural gas orifice in the clip and screw it back onto the body. Put the instructions in a paper envelope and tape to the outside of the body of the drier.
Apr 27, 2010 | LG WD-3243RHD Front Load Washer / Dryer
IE problem
Jan 27, 2010 | LG WD-16115FD Front Load Washer
Hotpoint BWD129 1200 spin - unwanted drying cycles
This is more a workaround than a solution. When you choose the washing programme (say "D") and push the on/off button, two lights will flash, the "door locked" and the "drying" one. Now turn the "drying programme" button until the "drying" light stops flashing (in my case, this is true when I set the drying programme to 40°C). Then start the washing mashine.
Seems like the function of the drying programme button has shifted against the settings written on the button...don't ask me why! Of course, no guarantee but works for me. Please let me know if it does for you.
Oct 13, 2008 | QuietLine WD-9900 Front Load Washer /...
I had exactly the same problem, found the answer on another website. The filter had a small sock stuck in it, stoppin the ppump from turning and draining the water out. Lever off the front panel right at the bottom of the washine machine, then unscrew the round black plug, lots of water will come out. Pull out the black thing and stick you fingers inside and pull out watever is blocking the pump. Turn off the electrics first. Mine now works fine again. :)
Mar 21, 2008 | Washing Machines
Washing Machines Logo
116 people viewed this question
Top Washing Machines Experts
