Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftmans remote garage door opener does not work
I recently bought a new garage door opener and it does not work at all. The light on it is red and I wonder if that is an indication of a dead battery. I have tried everything the manual says: push learn button and hold down open button on remote for 30sec........ It does not work. Is there something I need to do. It has never responded at all.
  • Anonymous Dec 31, 2008
    i purchased a new remote and it is the same as the one that i am replacing, however, it will not work...help
    Problem Solver:
  • 8 Answers
Most likely the battery is dying and needs to be replaced.
You can open the rear cover and replace it, they should have the battery you need at wall greens!
Once the cover is off make sure the switchs matches those of the Garage door sensor itself other wise it will not open.
It should tell you how to do this in the manuel that came with the unit.
If this does not work call tech support at the 800 number provided to you in the manuel and they will walk you through it. Most likely you bought this from Sears, craftsman is a Sears product.
Posted on Sep 23, 2008
How do I program my Sears Craftmans 1/2 HP garage door opener
Stacy, get a ladder and climb up to the opener. The directions are there, but typically you press a button for x seconds, and then press a button on the remote. This handshakes the two units. continue for other remotes.
Jul 06, 2015 | Sears Craftsman LiftMaster Chamberlain...
Genie garage door opener wont do anything. I just bought it today
Press learn on the ceiling mounted opener point the remote at the opener then press open three times then a light should blink test by pressing open if this does not work you should take it back to where you got it then ask for a refund
Nov 24, 2013 | Building Materials
Hi, I have an older garage door opener, Genie
If the opener doesn't work with the button on the wall the opener is defective, either the receiver board or the motor drive circuit or the motor itself.
May 03, 2017 | Transmitter Solutions Building Materials
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
I have a sears craftmans garage door opener that just stopped working all of a sudden are there batteries or soemthing I coul dbe checking?
There is a battery in the remote and wireless keypad but there are none in the opener itself. Check the outlet for power. Plug in a lamp or radio. Make sure the circuit breaker in your house hasn't popped.
Oct 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Where can i get new sensors for craftmans garage door openers
You can get these at Sears parts or any good garage door opener company in the yellow pages. Check around for the best price.
Jul 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Pressing remotes the door won't go u[
It sounds like you have the lock enguaged. When it is flashing it locks out all remote access. Hold the lock button for 3 seconds. The green light should go solid. On the issue of closing, it is most likely a safety eye issue. Hold down the wall button. If it closes it is the safety eyes. Holding the button overrides the safety eyes. Make sure that thelight on both eyes are both lit.
Jan 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door keypad & remote
You need to sync both. I have a LiftMaster. If you want to change the code on your keypad you need to open up the garage door motor compartment where the light is (mine is in the back). Press the learn button, within 30 seconds enter the new code on your keypad and hold down the enter button for several seconds until the light on the opener blinks to tell you it has learned the code. Test the new code to see if it works. If the new keypad code works, then try the remote. My remote will not work after I reprogram the keypad. If the remote does not work (check battery) then climb back up the ladder and press the learn button on the garage door motor again, press the remote button and hold down until the light blinks again and the opener has learned the new code. This process works when I need to sync my remote and keypad. Good luck, I hope this helps.
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
760 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
