Question about Hitachi 42HDS69 42 in. Plasma Television
42"HD PLASMA, No sound on Analog input
I have a 42"HD PLASMA, with no sound on Analog input. It had been giving me problem and we could shut- it off and turning it back on a couple of times and the sound would come back. As of last night there is no sound at all on the analog input. The other inputs seem to work or at lease they did before.
  • wes0067 Oct 27, 2008
    Thanks I'll check it out.
    Sergeant:
    Champion:
  • 223 Answers
I think the problem is dry solder joints on the tv. What makes be believe this is you turning it on and off may have been moving the component/s into contact with the board or the act of you turning it off let everything cool down enough to return to their original positions. It now sounds like the contact has broken with the component and the circuit. If you can check for this yourself otherwise find a competant technician. Hope this helps.
Posted on Oct 04, 2008
When i power on tv it say analog rgb searching/monitor going dpms
A guess here---turn on and with TV/video or source or input change the input until (say you have cable hooked also) you see the regular picture again.
The input by accident may have been switched to the RGB(red, green, blue) which is a component or HD input.
Start there and let me know what happens.
Dec 05, 2012 | Hitachi 42HDS69 42 in. Plasma Television
I dont see a coaxial to plug in cable
This "TV" is actually a monitor. It has no tuner and thus no coax connection. You have composite, S-video and component video inputs. You will need a set-top box. If you have cable, get one that is compatible with the type of cable you are receiving (CATV (analog) or QAM (digital).) If you are getting over the air signals, the basic digital to analog tuners will work but only provide SD out. There are some HD tuner options available.
I'm assuming you have a unit with the video input board installed. (Otherwise, it would only have VGA ports.)
The manual is available here: http://www.hitachiserviceusa.com:8080/CMP4201.pdf . If the direct link doesn't work, see the Hitachi support site at http://www.hitachiserviceusa.com:8080/Index.aspx . Use the drop down menus to choose your monitor (plasma monitor then model number).
I hope this helps and wish that I had better news for you.
Feb 26, 2011 | Hitachi CMP4201U 42 in. HD-Ready Plasma...
What is Monitor Out on 42'' Hitachi plasma TV (42HDT50)
Monitor Out connects audio and video signals to an external monitor with corresponding inputs as noted in the document.
Mar 07, 2017 | Hitachi 42HDT50 42 in. HD-Ready Plasma...
I have a hitachi 42 inch plasma tv about 4 yrs old. we watch tv on composite mode and recently it switches to analog every time i turn it off and back on. this is anoying because i have to switch back to...
Well, composite is still an analog signal format. What input does the monitor go to and is there anything plugged into that input? This is a fairly industrial model and has some features that you would not expect a normal tv to have. Check to see if there is some sort of default input selection in the menu or something along those lines. I have used these units before but I'm not familiar with the overall workings. I know there is signal sensing software on the monitor, for example it will turn itself off if no signal is detected for a while, 10 min is default I think. The issue is more than likely a setting that was changed. One other thing you can try, there are cards in the slots in the back. Put the signal you want to come up in the card slot of the input that it's going to automatically. This is a workaround of the problem, but it would do what you want it to.
Oct 28, 2009 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Esa 42 in plasma.....out of range?
i have a plasma tv (china brand) when i start the TV the remote control for other devices are not working, only working if the remote is too close to the sevices or by reducing the brightness to its minimum level (zero level..no brightnesss)
i need help strange fault
May 05, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Sansui 42'' HDMI problem
howto get the hdmi signal thro hdmi to dvi cable in plasma pdp42 sansui tv in dvi input
May 03, 2009 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Cant afford cable box need help
depending on if the dvd player has functions such as video input , but not likely
if the plasma only has certain video inputs and not the cable input you could use the vcr to get the signal
Oct 09, 2008 | Akai PDP4225M 42 in. Plasma Television
Hitachi 42"
Its impossible to say without knowing more than that. If the TV does not detect any signal on whichever input (other than CATV) your on, it will power down. Make sure you are getting an input signal and make sure you are on the right input on the screen.
More info on your problem and i could probably help you better!
Jan 11, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Setup
dvd and dish tv optical inputs from both dvd and tv if tv has opticl out or give optical out from hd receiver. or rc pins from hd or tv to dtv/cable input of yamaha
Jan 02, 2008 | Yamaha HTR-5830 Receiver
Hitachi 42HDS69 42 in. Plasma Television Logo
100 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
