Hello, all of the vocals are supposed to be coming from your center speaker,it may be turned off(check the units menu) speaker might be disconnected.,volume might be set too low as each speaker has a individual volume control in the menu.
You could record short "samples" to be used in building new voices, however, it does NOT appear that you can record a vocal song with the PSR9000. The Tyros II and III have the capability to record vocals but the PSR9000 and Tyros I do not..
When playing back an arrangement, you can re-sing the song and have the vocal harmonizer track the arrangement.
An old trick to remove vocals from a song was to rip the right channel, then the left, the combine them (since vocals are typically mixed in a third 'center' channel, though things like reverb or echo are applied to the right and/or left channels which sounds like what you are hearing).
I would play with the balance and mixer settings and see if you can get the vocals back. Also try other speakers or even headphones and see if you have the same problem.
If you simply want to overlap the voice, you can do that by recording using any free softwares available on internet (just google free recording softwares) you can try, cooledit as well, one track will contain your file with play mode, one track with record mode (for your voice) then start recording, it will play the song simultaneously with recording your voice. After then, you have to save the mixdown.
other long way is, you have to get KARAOKE for that song (karaoke means, no vocals only music track) then you'll get the recorded song in good quality.
it's not supported on that or any earlier sony software that I know of. have you tried running the program twice (simultaniously) and playing on one while recording on the other then mixing the tracks together after??
The easiest way to record using an external Lexicon effects unit (without an external mixer) is to connect your mic onto one of the 2488's inputs and assign that input to a channel strip (track). You should have the 2488 sends (output) going to the Lexicon's inputs. Then connect the Lexicon outputs back into another set of inputs on your 2488 and assign those inputs to two empty channel strips (tracks).
Then you will have to take that channel that has your mic input assigned to it and press send and set the levels there to send the signal out the sends (to the Lexicon).
Now you have a channel strip assigned to the mic input which contains your dry signal, and you have the two inputs returning from the Lexicon which contains your wet or effected signal.
You then have some options. You can control the amount of effected signal you hear while recording by adjusting the faders of the two wet tracks and you can either record the dry signal or the wet signal (or both) onto separate tracks.
Typically when recording the singer will want to hear an effect (say reverb) on his voice, but the engineer wants to record only the dry track at recording time (because effects can always be added later, but they can't be taken out). To accomplish this you would use the setup above, but only arm the mic input track for recording. In this way the singer hears the reverb, but only the dry vocals get recorded and the engineer can add reverb to that track again later as desired (and mix it back with the dry vocal etc).
On the other hand if you want to record only the effected signal you would simply arm the two channels to which the inputs coming back from your Lexicon are assigned for recording. This will get you a recording of the effected signal only.
Hope this helps you do what you are trying to do.
I'm not totally familiar with that Boss Digital Audio Workstation but it sounds like what you want to do is record both the music and vocal track at the same time. If that's the case I believe you can push both "Line" and "Mic" input buttons (perhaps not exactly named as such) at the same time to record both simultaneously. Otherwise I would suggest copying the music to it's own stereo track (or two individual tracks, each panned opposite from one another to maintain stereo) and then record your vocal track separately. That way you can record several takes and edit down the best parts to one final track.
I hope that helps.
Try this experiment: Record a click track on track #1. Record track #2 of the output of a monitor speaker playing track #1.
Now you have two click tracks which will probably not be cooincident (like they should be).
Measure the offset of the two tracks! You now know your latency exactly, and can compensate by adjusting settings or moving the vocal track back manually that many milliseconds!
I am having a smilar problem, I think the aux jack itself is messed up. I lose the sound out of the left channel, then I jiggle the connection a bit and get the sound back... Often when you can hear instruments and no voice you are hearing only a left or right track. Are you sure both the left and right is working?
