Question about Microwave Ovens
-ceramic at the bottom is broken,-Interier panel needs to be changed
Modle is RSF10SW2
  • Microwave Ovens Master
  • 9,086 Answers
That model would be RFS10SW.
You can order that glass / ceramic tray (part # AP4313544) here.
Posted on Sep 25, 2008
What material is the ceramic insulator at the antenna of microwave owen magnetrons?
Some are, yes. There are alternatives used, such as aluminium oxide.
Beryllium oxide is safe enough in a solid form, but is toxic and carcinogenic as a dust, so it is best not to handle broken pieces, and you must avoid trying to shape it.
Nov 08, 2015 | Microwave Ovens
I need to change the handle on my microwave modle khms155lss3. How do I get to the screws to take it off?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
May 25, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
We've owned this miscrowave for about 8 years. just recently, every time we've tried to use it pops and flashes light. It seems to be coming from the panel on the right
you may have exposed metal in the microwave so it arcs. You will need to cover the exposed metal with ceramic paint. Just sand the area down so its smooth, then apply ceramic paint. that should solve your problem.
Mar 27, 2011 | Frigidaire Microwave Ovens
How do i remove the plastic cover to change the light bulb in GE Microwave
Hi, I have a ge modle jvm1631 and mine has two scerws in the front of the cover (can be hard to see in dim light) on some modles you might have to have door open and screws will go in from bottom of cover. Then there is a filter inside that you take out and remove a metal plate that covers bulb.
Mar 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Have power but the microwave won't turn on but the timer counts down the time and have power and lights still work.r-1502
on the inside panel or bottom panel there is a fuse in there once you pull the panel you will see it, it is more than surly burned out and needs a new one thats all, but the company dont tell you that because you wont buy aother if you can fix the one you have ffor less than a buck
Apr 08, 2010 | Sharp R-1502 Microwave Oven
Replace light bulb on the Neff H7871 combined oven and microwave.
The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
Mar 17, 2010 | Neff H7871 Convection/Microwave Oven
I have Amana Radar Range microwave. The repair guy was just here (fixing my real stove) and told me to change fuse to ''20 amp 250 volt fast acting ceramic fuse.'' Where is the fuse on this microwave?
first unplug your microwave and let sit for awhile to drain any stored energy that may zap you. then, if it is an "otr" there are 2 screws in the vent slats on top that you remove. once removed, you lift up on the control panel and it tilts out. voila! there is your fuse. pop it out and pop in a new one. ceramic 20 amp is correct. check your old fuse to be sure it is 20, not 15 though.
Aug 26, 2009 | Microwave Ovens
Broken door handle on GE Spacesaver microwave
TIP: Go to the web and type www.partselect.com enter your model number then scoll down to your part. Panel,door (PANEL DOOR) click to enlarge exploded diagram on left. Veiw enlarged diagram at top of page. You can print the entire diagram for exact assembly by holding your pointer in the upper left hand corner of diagram. Select the print icon. Now you have what you need. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE advantium SCA2001FSS
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 24, 2008 | Microwave Ovens
Microwave went completely dead after changing bulb-
Nom...you probably blew the internal fuse. This time...turn off the power. Remove the button panel and search for the blown fuse. It might be ceramic or of some other type. If on a circuit board, there will be a xxxA with xxx indicating the amperage. Use a multitester available at Ace or Radio Shack to test. Replace with the same kind of unit. Your local auto store, appliance parts guy, Radio Shack or Sears parts can get you the part you need. Show them the old one.
Dec 17, 2007 | Whirlpool MH3185XP Microwave Oven
Microwave Ovens Logo
55 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
