Question about RIM BlackBerry 8800
Hour glass! my BB8800 is no longer working... once i insert the battery, it only displays the hour glass..then it will automatically turn off and then again, it displays the hour glass..as if its loading... how can i fix it? i think i need a software for it to be reformatted again... hope u can help me...thanks!
Thank u so much..i will try this solution u are giving me..whatever happens, i will then tell u...thanks!
Posted on Oct 06, 2008
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 84 Answers
Try taking out the battery and the microSD memory card, if you have one. If that still doesn't work, then you will need to wipe the operating system off the device and reload it. The links below show how to do this:
Wiping the Device with JL_Cmder: http://blackberryfaq.com/index.php/How_do_I_wipe_the_BlackBerry_using_Jl_Cmder%3F
Installing Operating System: http://crackberry.com/blackberry-101-how-install-or-upgrade-new-rim-operating-system-os
Posted on Oct 05, 2008
During an update, the hour glass just sat there spinning. Now, even after removing the battery, the hour glass just spins and nothing comes on
you need to reflash the OS on the phone you should take the battery out first then connect it via the usb cable to the laptop/pc you are using then open the blackberry desktop manager,click on the apploader, then install the OS.
pls not that when u click on the apploader the pin should be PIN:UNKNOWN you make need to do this like 4x before the pc sees the pin:unknown but it will work once it see the pin:unknown you can re-insert the battery and continue with reflashing the phone
Oct 04, 2009 | AT&T Blackberry Curve 8300 Smartphone
Wont turn on
www.crackberry.com will help, just search in the forums for "recover a dead blackberry"
Jul 30, 2009 | RIM BlackBerry Pearl 8100
LG Viewty battery discharges quickly .....
Charging duration does not connect to battery lasting duration in any way.Optimal charging time is 3 to 4 hours.your battery will drain soon if you keep your touchscreen pressed continuously in your jeans pocket.Keep bluetooth switched off. Reduce the brightness of your mobile display. Play music threw headphone rather than using loudspeakers.
Jul 19, 2009 | LG KU990 Viewty
My blackberry 8110 will not charge
this happened to me and i just shut the phone down took out the battery waited 3-4 mins put battery back in do not turn on phone but put it on charge and it should be ok.
Jan 25, 2009 | RIM BlackBerry Pearl 8100
Blackberry pearl wont go past the white screen with the hour glas
the only thing that you can do with this issue is try wiping the software clean and reinstalling fresh software. You would need the blackberry desktop manager first installed on your home computer. If you dont have the cd the program is more then likely available on your mobile providers website. Once the program is downloaded and installed follow these directions
To perform this procedure, follow the steps below:
  1. Remove the battery from the BlackBerry device.
  2. Double-click Application Loader in BlackBerry Desktop Manager while the BlackBerry device is not connected to the computer.
  3. Click Next on the Welcome to the Application Loader Wizard screen.
  4. When the Communication Port Selection screen appears, connect the BlackBerry device.
  5. When the USB-PIN option appears, click Next. The Device Application Selection screen should appear.
  6. Re-insert the battery and allow the process to complete.
Nov 13, 2008 | RIM BlackBerry Pearl 8100
Hours glass problem
I have had this problem a time or two after installing bad apps or the wrong apps. If I leave my phone on for an hour or longer and just let the hourglass turn, it will start up - then remove the bad app if that is what the problem is, hope that helps.
Oct 07, 2008 | RIM BlackBerry 7520 Handheld
Phone is not working
My phone had the same problem and it was a battery charge problem. I bought an external charger and another battery and now everything works fine but I have two batteries and an external charger, the phone doesn't charge the batties.
Aug 13, 2008 | HTC P3300 Smartphone
Blackberry Pearl
did it get wet? whats the sensor sticker look like?
Apr 02, 2008 | RIM BlackBerry Pearl 8100
Tungsten E
i have a tungsten e2 and it automatically turns itself on with out any buttons what so ever so the battery wont stay charged long enough for me to do any thing illput it up and come back an hour later to find the batter is already dead ill charge it unplug it and bring it to work with me to only find that when i get to work its on and the battery is draining what do i do
Dec 30, 2006 | Palm Tungsten E Handheld
RIM BlackBerry 8800 Logo
114 people viewed this question
Top RIM Computers & Internet Experts
Trisha
Trisha
Nataly Roberts
Nataly Roberts
SANTHOSH
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
