Question about Sony VAIO PCV-V210P PC Desktop
To compuguy4 my keoard won't work it my have gotton something spilled on the corner of it but all of it won't work what do i do
  • 706 Answers
If it got damaged ..simply pick up a replacement one at any electronics supply stores.. Best Buy, Comp USA, Targets and Wallmart all carry keyboards.. it should be a plug and play process ( meaning; unplug th eold, plug in the new) restart computer... It is NOT worth trying to repair since many keyboards are very inepensive..
Posted on Sep 23, 2008
Won open my sentry safe f3300 is stuck
The best way to break the rubber water proof seal is to push down on the left rear corner. That will pop open the front right corner need more help you can get my phone number here
Apr 03, 2013 | Sentry Fire Safe Waterproof Security File...
I spilled liquid on my HP Probook 4320S (with spill resistant keyboard). Dried it up straight afterwards. Now it won't power up
Take it to a service shop asp, key board will need to be replaced, and the laptop will need to be assessed for motherboard damage.
May 06, 2012 | HEWLETT-PACKARD ProBook 4320s C Notebook
Solidtek ask 4251 this is a wireless keyboard, I had to replace the batteries in the keyboard, but still won't work.
Does the battery light come on? Then it's still the batteries, try them in something else or a battery meter. Otherwise you have fried the circuitry of the keyboard (probably spilled something by accident on them). They're no good anymore.
Jul 27, 2011 | Computers & Internet
Westinghouse 522 fridge leaking oil from front right hand bottom corner
Hello, Thank You for using FixYa. I will be helping you today.The only thing that has oil is the sealed system. So if there is oil leaking you would have a leak and the unit will stop cooling.Are you sure something didnt just spill and is leaking out?
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Refrigerators
Zxcv keys not working
It is possible that something was spilled on the keyboard (like juice) and now they won't work anymore. In this case, if you have a normal keyboard you can open it up and clean it or take to a repair shop or just buy a new one. If you have a laptop it's a bit tricky because if you haven't done this before it's more difficult to open it and clean it. So if that's the case take it to a repair shop and they will clean it OR tell you what it's wrong with it.
I presumed there was something spilled on the keyboard. If that's 100% not the case you might want to provide more detail because I can't think of another reason for this to happen. Haven't found anything relevant on the internet either.
May 16, 2011 | Computers & Internet
I need to clean the inside of my remote control.
If it is dirt/dust etc then it won;t hurt it. If you spill a liquid on it then that is another matter. Depending on what was spilled it may be already to late to save it. Certain liquids such as coke contain acids that eat away at parts. Even if it is cleaned very quickly then the contact pads under the buttons may suffer damage and your buttons won;t work.
Basically you can disassemble to remote and clean/rinse with distilled water only. Then let dry for a few days and put it back together. Even tap water can contain things that will attack the parts inside so you need distilled water. A good bottled water will do.
9 out of 10 times the remote gets junked either from the spill or from the cleaning.
Oct 11, 2010 | Televison & Video
Blowing coil fuse when key is turn on
more than one thing can blow the fuse, unplug the ingtion ciol and the distrubutor and then install a new fuse and turn the key on if the fuse blows then there is still something in the computer system or wiring that is crossed. Next also unplug the ECM itself and see if it still blows the fuse if it doesn't blow the fuse with the key on then plug in the disconnected items one at a time till you find the item thats bad or the wires that have gotton into troble. The oxogen senser heater can be on this circuit and there may be two oxoxgen sensers unplug them both and check that there wires haven't gotton into trobleagainst the exhaust pipes or other hot parts. If it doesn't blow the fuse with the oxogen sensers unplugged plug one in at a time and check fuse It'll run with the oxogen sensers unplugged. The sensers sometimes fail but more often the wire getts against the hot pipe and shorts to the pipe. repair wire and ty off and it may work just like it's supposed to.
Mar 22, 2010 | 1994 Suzuki Sidekick
Logitech cordless keyboard not working properly - keys stick or are delayed
Did you spill something on it or is food lodged in unit if so take apart clean.
Fresh batteries would be good start.
Feb 18, 2010 | Logitech Cordless Desktop MX3200 Laser...
HP Compaq nc 6120 - it is stuck - curser is halt not responding anything. When pressing a little hard or lifting laptop above from one corner it starts working.
sounds like you have something stuck on your touchpad controller.
You could plug in an external mouse and try to shut off your touchpad while putting pressure on the case long enough to get to mouse file in your control panel folder.
You will probably have to take the cover off and look for stuck switches or maybe something spilled on the touchpad itself that is gumming things up.
good luck and be careful.
Jan 15, 2010 | HP Compaq nc6120 Notebook
I spilled a small amount of water on my wacomg intuos tablet.
ok its simple its happens a lot and people allway loosingthere mind over somthing like this ifyou have anything such *** a hair drier (sorry i dont know how to spell it) for a few secoond aim it on the usb port andon the place itgot wet thanwait a few mins it wont work it will say the same massge again so give hit one hard hit afther the massege is gone not to hardjust that it will work andthan yousee it turned on.
hope i helpd GL
Jun 23, 2009 | Wacom (PTZ930AC) Graphic Tablet
Sony VAIO PCV-V210P PC Desktop Logo
41 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
