Question about Gigabyte Computers & Internet
Display Monitor Use the tv as the PC monitor with GIGABYTE GA-MA69GM-S2H, but on connecting to either DVI-D & HDMI port the display was'nt initialised I need to pull it out of the socket and re connect it; but on the D-Sub port no problem. Consult the BIOs setting, tried changing Init. Display First setting notting happened. Seen this web page on the internet hope I can get help. Please somebody help.
My sound driver are not working
Posted on Sep 25, 2008
How do I connect a external monitor to my toshiba P55T-B5262 laptop
Ok I looked at the Specs on the laptop --- you have a HDMI port --- Same thing found on almost all tv's now days
-you need a HDMI to VGA or an HDMI to DVI converter --- very inexpensive purchase
Options #1
If the monitor you are trying to has this port:
-then you need a HDMI to VGA adapter
http://www.ebay.com/itm/like/350902230382?lpid=82
Options #2
-then you need a HDMI to DVI cable
http://www.ebay.com/itm/HDMI-to-DVI-D-24-1-Pin-Monitor-Display-Adapter-Cable-Male-Male-HD-HDTV-6-FT-/141210464113
Hope this Helps!
Sep 06, 2014 | Toshiba Satellite Computers & Internet
Tip
How to Connect PC to HDMI TV Step 1 Turn your...
  1. Step 1 Turn your computer off, and turn it around to view the rear of the unit. Find the cable that comes from the computer's monitor, and follow it to the back of the PC. The cable will be plugged into the output of the video card, which will be either a 15-pin VGA port or a 29-pin DVI port. If you are fortunate, there will be a second port directly next to it, of either the DVI or VGA variety. On the newest machines, you may even find a regular HDMI port on the card.
  2. Step 2 Choose the connection for video output. If your computer has an HDMI port, you can simply connect an HDMI cord of the correct length between the computer and the TV. Otherwise, you will need to make a few decisions. If your computer has only a single video output, and it will not be used solely with the television, you may want to invest in a new video card. Purchase one with either a DVI or an HDMI output, and install it in an available slot, according the instructions included with it. If you intend to use the VGA output on a single-output or dual-output card to drive the HDMI display, then a special device will be needed to convert between the formats, and the price of the converter is actually about the same price as an entry-level video card that will be easier to use with your TV. In that case, it may be a wise idea to upgrade the card in order to obtain a DVI or HDMI port. However, if your chosen output port is of the DVI variety, an inexpensive DVI to HDMI cable can be purchased to convert your computer's output into the proper HDMI input for your TV.
  3. Step 3 Connect the HDMI cable from your television to your computer. Install the correct adapter or converter for your computer, if necessary. Unless your computer has HDMI output, cords will also need to be connected from the sound card output to the HDMI video cable or adapter, because HDMI carries both video and audio signals.
  4. Step 4 Boot your PC, and configure the new display, by selecting "Control Panel" from the "Start" Menu. Then double-click the "Display" icon and click the "Settings" tab. The manual for your HDMI TV will list the screen resolutions it supports, along with the refresh rates. Configure the resolution in the "Settings" tab, and then click the "Advanced" button to set the refresh rate. If you are using the HDMI TV as the second monitor, you will also have to configure how it is used by Windows, according to the instructions pertaining to your video card. Most cards offer a "Clone" or "Mirror" mode, where both screens display the same content. Alternately, the "Extended Desktop" mode can be used, in which each monitor will operate independently.
  5. Step 5 Reboot your PC to apply the changes, if necessary, and prepare to relax on your couch and watch your movies on the big-screen HDMI TV.
on May 24, 2010 | Computers & Internet
Unlock password
How about looking at a screen?
Use an external monitor
Briefly;
Your laptop has an external display device port. (Connector)
I do not know what it is, because you didn't state the laptop manufacturer name, and model number; Elizabeth
It may be a VGA port, or HDMI port, or Mini-HDMI port; or DVI port
http://en.wikipedia.org/wiki/VGA_Connector
(Scroll down for VGA Cable example)
http://en.wikipedia.org/wiki/HDMI
(You can click on any photo, and it will enlarge)
http://en.wikipedia.org/wiki/File:HDMI_Connector.jpg
http://en.wikipedia.org/wiki/Digital_Visual_Interface
Laptop OFF, monitor OFF, connect the external display device to the laptop.
(VGA = Monitor. DVI = Monitor. HDMI, and Mini-HDMI usually = HDTV. They all compromise an external display device)
Turn the monitor/HDTV on.
Turn the laptop on.
By factory default settings, the display should show on the external display device.
IF not;
There are at least 3 display options. For this example I'm going to use a VGA monitor.
(For a VGA monitor you can use a CRT type of monitor. Looks like a small TV. Or you can use a flat LCD screen monitor, if it has a VGA Cable attached)
The basic 3 display options using a VGA monitor are;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down, and at the SAME time tap once on the Display Toggle-Over key.
Which key is that? Dunno. Laptop manufacturer name, and ......................
It will be one of the F keys at the top. F1 through F12.
The Function key will have a monitor icon on it, and usually an arrow on one side........Or perhaps two monitor icons sitting side by side.
(Empty rectangle is a monitor icon)
Still no display on external display device?
Hold the Fn key down again, and tap once more on the Display Toggle-Over key
[If memory serves for Display Toggle-Over key;
HP = F4
Acer = F5
Toshiba = F5
IBM/Lenovo = F8
Don't write that in stone, however.......]
Once you post the manufacturer name, and model number; then I can guide you step by step.
Post back in a Comment.
Regards,
joecoolvette
Apr 25, 2013 | Computers & Internet
I have a dell dimension 3000, bought a new HP 2310E monitor with 3 ports. DVI, HDMI & display port. Told to buy a cable with VGA to connect to dell and DVI to connect to HP Monitor display port....
Hi sshorne9780,
I see that you are having a check input error on the Monitor/LCD that your are connecting to your Dell tower, please see steps below.
  • On your HP 2310E make sure that your HP is set to the input/source that you are using and make sure that you only use one type of video cable for the issue.
  • I see that you mentioned that you have a VGA cable and a DVI cable, you can only use one type of cable for a video connection.
  • VGA would be the Blue tipped cable connecting to the tower and going to the LCD monitor.
  • DVI this is a black cable connecting to a white port much bigger than a VGA port and is rectangular in shape unlike the VGA
  • and on your LCD monitor check the input type to see video from the tower.
  • everything seems to be OK you just need to change the input of your LCD monitor for the video to show up on the screen.
  • also if you are using HDMI for the video u will need to change the setting of your Audio and set HDMI as the Default to have Audio come out from the HDMI connection together with video, the HDMI viedo will automatically be detected as long as the LCD monitor's input is set to HDMI.
I hope that this will able to help resolve your concern.
Thank you for choosing Fixya,
mvincentc
Apr 18, 2011 | Dell Dimension 3000 PC Desktop
Dear Sir, We have Toshiba REGZA 24PB1E LCD TV. I want to test our Gigabyte PC GA-G41M-Combo MB with VGA port (15 Pin Connector) Pls let us know how to connect & get the solution ASAP. For...
Hello
With either the PC IN or HDMI connection, you can watch
your computer's display on the TV and hear the sound from the
TV's speakers.
When connecting a PC to the PC IN terminal on the TV, use an
analog RGB (15-pin) computer cable and a PC audio cable.
To use a PC, set the monitor output resolution on the PC
before connecting it to the TV. The following signals can be
displayed:
Format Resolution V. Frequency
VGA 640 × 480 60Hz
SVGA 800 × 600 60Hz
XGA 1024 × 768 60Hz
Other formats or non-standard signals will not be displayed
correctly.
Note:
The PC audio input terminals on the TV are shared with the
HDMI-1 analog audio input terminals
Some PC models cannot be connected to this TV.
OK.
Mar 24, 2011 | Toshiba REGZA 47HL167 TV
I need to buy a new monitor. What kind of monitor will it support, GA, DVI, HDMI ? Thanks.
You should go for a Widescreen LCD ro LED monitor. They all support VGA and DVI. If you get a Full HD screen then it will have a HDMI connection also. Just make sure your Display card can handle it.
Mar 09, 2011 | Dell Dimension 4300 PC Desktop
HOW To Make MY TV WORK ON MY COMPUTER ?
Hi
Reboot your PC to apply the changes, if necessary, and prepare to relax on your couch and watch your movies on the TV.
Oct 04, 2010 | Computers & Internet
I just hooked up my HP Pavilion 9000 Laptop to my Vizio TV and put the TV on correct setting. It is not working on the TV, any ideas? I went on Display setup and kept trying to connect but it says the...
If your laptop has a VGA port, your Vizio needs to have a VGA port too so you can use a standard VGA monitor cable.
If your laptop has a DVI port, you hook it up to the Vizio using a DVI-to-HDMI cable.
And if your laptop has an HDMI port, you hook it up using a standard HDMI cable.
Hope this helps.
Oct 16, 2009 | HP Pavilion dv9000z Notebook
Nothing on the screen at startup
If you cant get into the setup menu then I would think the monitor is defective,you did not state if you hooked up the monitor to a computer that has a vga port that works.
Jul 21, 2009 | LG 22" FLATRON LCD Monitor
Help
Step 1
Shutdown your computer and look at the rear of the case to determine the type of video connections that your machine has. Nearly all computers will have the standard 15-pin VGA output port. In addition, you may also find that your computer has an S-video port, an RCA composite video port, a set of three component RCA video outputs or perhaps even an HDMI output port.
Step 2Determine the types of video inputs that are available on your plasma TV. There should be a standard RCA composite input, a three-jack RCA component input and an S-video input. In addition, you may also find a 15-pin VGA input, a DVI input or an HDMI input. Step 3 Select which type of connection you will use. HDMI and DVI represent the highest-quality connections, followed by VGA, Component, S-video, and composite. If your computer has only a VGA output and you will not using it solely to drive the plasma TV, you may want to invest in a video card upgrade. Most new video cards will offer dual monitor connections and possibly a separate TV connection. The first monitor connection is intended for the main computer monitor, and the second monitor connection, or the TV output, can be used for either a second monitor or a TV. Depending on the card, the TV output may be DVI, HDMI, component, S-video or composite. Step 4Purchase a video cable long enough to reach from your PC’s video output to your plasma TV. If the distance is over ten feet, you may want to invest in high-quality cables to ensure that the plasma TV receives a clean signal for the best possible picture. Cables over thirty feet in length, depending on the connection type, may result in poor video performance. Step 5Set your computer’s screen resolution to something that your plasma TV can accept, using the “Display” settings in the “Control Panel” in Windows. Refer to the owner’s manual of your plasma TV for the supported resolution and refresh rate. If you are using the S-video, composite or component outputs on your computer, this step may not be necessary. Step 6Connect your PC to your plasma TV using the appropriate cable. Start the computer up and it should recognize the attached display. In the “Display” settings, you will need to configure how the plasma TV is used if it is attached a second display. Most video cards support “Clone” or “Mirror” mode, which displays the same content on both displays. In addition, there is the “Extended” mode, where the second display will operate independently, and windows can be dragged from one screen to the other. If your plasma TV is the only monitor for the computer, you will not to configure the multiple display modes. Step 7Connect a cable from the sound output of your PC to your plasma TV using the appropriate audio adapters. Then relax on the couch and enjoy your videos on the big screen.
Aug 09, 2008 | Computers & Internet
Computers & Internet Logo
108 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
