Samsung TXK2754 27" TV
Problem for Samsung TXK2754 27" TV
NO POWER.
By BIGBENGAZ on Sep 23, 2008
DID I CHECK ALL POWER LINE AND PARTS, BUT WHEN I PRESS THE POWER BUTTON, NOTHING HAPPEN. ALSO, DID I CHECK THE 2SD1880, AND IS BAD. JUST SAY ME,IF I HAVE JUST TO REPLACE THESE PART TO SOLVE THE PROBLEM.
Solution #1
posted on Sep 23, 2008
Somewhat Helpful)
Azkeyz
Rank: Wiz
Rating: 83%, 163 votes
Yes you must replace any failed components before proper operation can be restored.
azkeyz@fixya.com
Wizard Division
Was this helpful?
Yes
No
Solution #2
posted on Sep 25, 2008
Not Rated)
Abrsvcs
Rank: Guru  Samsung Televisions & Videos  Expert
Rating: 88%, 1821 votes
Bigbengaz,
The 2SD1880 is the horizontal output transistor. These often fail as the only defective part. Make sure that you use plenty of heatsink compound on the new one when you install it. That should resolve the problem. If the transistor fails again relatively quickly, then the actual problem is likely to be a failing flyback transformer.
Dan
Was this helpful?
Yes
No
Popular Solutions for Samsung TXK2754 27" TV
Questions and Unsolved Problems for Samsung TXK2754 27" TV
Do you recommend Samsung TXK2754 27" TV?
Answer
Answer
My Samsung txk2754 has alot of horizontal lines (white lines) what could be the problem
Answer
On one of the channels it blacks out and say's "Current Rating/Received RatingTV14/Excessive... (More)
Answer
I tried 0711 and that didn't work......does anyone else know how to do this?
Answer
Someone gave me the TV since my old one died.  Can't hook it up, just has "AV1"... (More)
Answer
hlo tv lcd acer basic schematic acer 3201
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung TXK2754 27" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
