Question about Sharp AR-M208 All-In-One Laser Printer
Sharp ar-m208 message
What does the L6-10 meassage mean?
thanks,
Belinda Stevens
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
L6-10 means your will be replacing the Laser Unit.... or if you have a very very good tech, you might be able to only replace the polygon motor. Typically is it cheaper and easier to replace the Laser Unit.
Sometimes Simulation 14 will clear this for a short time.. if it this code does not clear, a new laser unit is needed..
The Polygon Mirror is what the laser in the machine uses to write the image with, the motor which spins this is dead? The machine will not work without this.
The polygon motor does not rotate.
Check the polygon motor operation with SIM 61-1
Posted on Oct 23, 2008
  • Sharp Master
  • 2,794 Answers
Polygon mirror motor not up to speed. Check the motor, you power supply, and the board the motor it connected to.
Posted on Sep 23, 2008
We have a sharp AR-M208 N fax machine. Error comes up F1-15 what does it mean?
Probably is a error referring to
Finisher Lift up trouble, on the sorter....
Tray that goes up and down, does NOT reach home position.
Jun 23, 2010 | Sharp AR-M208N Copier
Hi we have a Sharp AR-M208 displaying error code L6-10. Need to know what that relates to and some basic trouble shooting to resolve. Thanks in advance!
L6-10 Content Polygon motor lock detection.
Detail It is judged that the polygon motor lock signal
is not outputted.
Lock signal is checked in the interval of
10sec after starting the polygon motor, and it
is judged that the polygon motor does not
rotate normally.
Cause The LSU connector or harness in the LSU is
disconnected or broken.
Polygon motor trouble
Check and
remedy Use DIAG (SIM61-1) to check the polygon
motor operation.
Check connector and harness connection.
Replace LSU.
Jan 10, 2010 | Sharp AR-M208N Copier
Sharp AR-M208N with OFH4-00 error code
Hello sir; This code require simulation to reset the procedure as follow; press "#", "interupt", "clear", "interupt", then enter 14 press start. turn power off and back on, then all set.
Sep 27, 2009 | Sharp AR-M208N Copier
Sharp ar-m208 copy problem
Do you mean really faint and light or completely white, blank?
Jul 09, 2009 | Sharp AR-235 Copier
My copier AR-M208 won't pick up paper from tray 2 It starts too then nope it says its jamed but not really, we open side door and tray close both then it will copy one or two pages the stop again
It may be that either the feed rollers in that drawer are dirty or worn out and need replacement. You might also want to ensure that there is no dogeared paper in that drawer. Meaning that the edges of the stack are all nice and even, no corners bent over.
Jun 29, 2009 | Sharp AR-M208N Copier
Need to replace drum on photocopier.
You need a cleaning blade too. and after installation, you need to calibrate it within service mode. This should be done by a technician
Mar 16, 2009 | Sharp AR-M208 All-In-One Laser Printer
Sharp AR-M208 All-In-One Laser Printer Logo
320 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
