Question about Ricoh Aficio 1035 Copier
Circuit board need to obtain the circuit board for a ricoh 1035
  • Ricoh Master
  • 2,794 Answers
Contact Precision Roller. Their website is:
http://www.precisionroller.com/
We get our Ricoh parts from them.
Posted on Sep 23, 2008
Ricoh aficio 1035 copier gives error code 390
TD sensor defective
TD sensor not connected or disconnected damage
Poor connection between the TD sensor and IO board
IO board defective
Toner supply defective
* Insufficient toner in developing unit
Apr 16, 2014 | Ricoh Aficio 1035 Copier
Sc code 395 on aficio 1035
Possible Causes
• High voltage supply board defective
• Poor connection at the development
bias terminal
• Poor connection at the high voltage
supply board
Jan 23, 2013 | Ricoh Aficio 1035 Copier
Ricoh 1035 error sc 818
hi
this error happened when :
Incorrect Function DIMM installed in Slot #2 on Controller PCB. (Slot #2 is for PostScript Option only) so you can:
Reload System Firmware.
Replace Controller PCB
for fix that.
Oct 25, 2012 | Ricoh Aficio 1035 Copier
Tell me how to use my printer as a network printer
You need the board network, that comes like optional, contacts with a supplier to obtain it and to install it.
Nov 19, 2009 | Ricoh Aficio 1035 Copier
Ricoh aficio 1035 error code SC121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
Jun 15, 2009 | Ricoh Aficio 1035 Copier
Ricoh 1035 laser problem
sometimes the plastic of the laser is turned by the heat proves to relax and to fit the screw that holds the laser unit that is of the side of the drum while it raises a millimeter with a screwdriver, this sometimes works.
Verifies that the glasses and mirrors well be positioned correctly.
Other
Poor connection between the laser
synchronization detector board and
the LD unit.
Laser synchronization detector board
out of position
defective
LD unit defective
May 07, 2009 | Ricoh Aficio 1035 Copier
Networking at Ricoh 1035
does your 1035 have either a printer or printer /scanner option. If it does just hook s line up to the network connector on the back of the controller. hit user tools, system settings, interface settings, network settings and then select auto obtain. now exit from the user tools to the regular screen. wait about ten seconds to let the settings take effect. Now hit user tools , printer features, lists and hit configuration page. Take this page to the computers with you. Go to start, add a printer add a local printer, deselect auto detect, hit next. Now hit add port select tcp/ip from drop down button. in location where is it says printer name or ip address enter the printer name located on the bottom right section of the configuration page you printed. now go to ricohs website www.ricoh.com, americas, then at the top you will see downloads. then a screen will apper that says drivers and manuals. select black and white, 1035 and windows vista. create a folder on your desktop called printer. once in the folder, open it double click and unzip it into the same folder.now back to page after you have typed in the printer name and hit next. go to have disc, browse to the folder on the desktop and follow the prompts form set up, drivers, vista, pcl 5, english and the select if this is your default printer, do not select sharing and ask it to print a test page. once this has printed go to the properties tab on the drive itself and select accessories. and add whatever options your copier has ie. sorter, duplex or extra paper drawers. Now do this to all your copiers on the network. doing this allows you to print from any computer regardless if any other computer goes down
Dec 11, 2008 | Ricoh Aficio 1035 Copier
Ricoh 1035 Display Messages
Empty waste toner in transfer unit on the right side door.
Jul 03, 2008 | Ricoh Aficio 1035 Copier
Ricoh 1035 scanning set up
plase install the scanner board and software
Sep 13, 2007 | Office Equipment & Supplies
Ricoh Aficio 1035 Copier Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
