My account has been hacked into and i can't get into it.
    Novelist:
  • 84 Answers
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Posted on Apr 22, 2009
    Sergeant:
  • 300 Answers
Password Recovery.
Can't Log On to Windows XP?
If that’s your only problem, then you probably have nothing to worry about. As long as you have your Windows XP CD, you can get back into your system using a simple but effective method made possible by a little known access hole in Windows XP.
This method is easy enough for newbies to follow – it doesn’t require using the Recovery Console or any complicated commands. And it’s free - I mention that because you can pay two hundred dollars for an emergency download of Winternals ERD with Locksmith which is a utility for unlocking lost Windows passwords. See here http://www.winternals.com/products/repairandrecovery/locksmith.asp
ERD is an excellent multi purpose product, but you should know it is not a necessary one if you have a healthy system and your sole problem is the inability to logon to Windows due to a forgotten password. Not necessary because you can easily change or wipe out your Administrator password for free during a Windows XP Repair. Here’s how with a step-by-step description of the initial Repair process included for newbie’s.
1. Place your Windows XP CD in your cd-rom and start your computer (it’s assumed here that your XP CD is bootable – as it should be - and that you have your bios set to boot from CD)
2. Keep your eye on the screen messages for booting to your cd Typically, it will be “Press any key to boot from cd”
3. Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
4. When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
5. The Licensing Agreement comes next - Press F8 to accept it.
6. The next screen is the Setup screen which gives you the option to do a Repair.
It should read something like “If one of the following Windows XP installations is damaged, Setup can try to repair it”
Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press R to begin the Repair process.
7. Let the Repair run. Setup will now check your disks and then start copying files which can take several minutes.
8. Shortly after the Copying Files stage, you will be required to reboot. (this will happen automatically – you will see a progress bar stating “Your computer will reboot in 15 seconds”
9. During the reboot, do not make the mistake of “pressing any key” to boot from the CD again! Setup will resume automatically with the standard billboard screens and you will notice Installing Windows is highlighted.
10. Keep your eye on the lower left hand side of the screen and when you see the Installing Devices progress bar, press SHIFT + F10. This is the security hole! A command console will now open up giving you the potential for wide access to your system.
11. At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel.
12. Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without being asked for password. After you’ve made your changes close the windows, exit the command box and continue on with the Repair (have your Product key handy).
13. Once the Repair is done, you will be able to log on with your new password (or without a password if you chose not to use one or if you chose not to be asked for a password). Your programs and personalized settings should remain intact.
I tested the above on Windows XP Pro with and without SP1 and also used this method in a real situation where someone could not remember their password and it worked like a charm to fix the problem. This security hole allows access to more than just user accounts. You can also access the Registry and Policy Editor, for example. And its gui access with mouse control. Of course, a Product Key will be needed to continue with the Repair after making the changes, but for anyone intent on gaining access to your system, this would be no problem.
And in case you are wondering, NO, you cannot cancel install after making the changes and expect to logon with your new password.
Cancelling will just result in Setup resuming at bootup and your changes will be lost.
Ok, now that your logon problem is fixed, you should make a point to prevent it from ever happening again by creating a Password Reset Disk. This is a floppy disk you can use in the event you ever forget your log on password. It allows you to set a new password.
Here's how to create one if your computer is NOT on a domain:
Go to the Control Panel and open up User Accounts.
Choose your account (under Pick An Account to Change) and under Related Tasks, click "Prevent a forgotten password".
This will initiate a wizard.
Click Next and then insert a blank formatted floppy disk into your A: drive.
Click Next and enter your logon password in the password box.
Click Next to begin the creation of your Password disk.
Once completed, label and save the disk to a safe place
How to Log on to your PC Using Your Password Reset Disk
Start your computer and at the logon screen, click your user name and leave the password box blank or just type in anything. This will bring up a Logon Failure box and you will then see the option to use your Password Reset disk to create a new password. Click it which will initiate the Password Reset wizard. Insert your password reset disk into your floppy drive and follow the wizard which will let you choose a new password to use for your account.
Note: If your computer is part of a domain, the procedure for creating a password disk is different.
See here for step by step instructions: http://support.microsoft.com/default.aspx?scid=KB;en-us;306214&
Thank you for selecting FixYa!
azkeyz@fixya.com
Wizard Division
Posted on Sep 23, 2008
Hacking people
Hacking accounts of social media is a task that requires intense knowledge about software coding and designing.
But I am providing here the easiest tool that would help you to hack Instagram accounts without such knowledge.
You can learn more about the tool from the mentioned link.
Some of the features are provided below:
a. 24/7 support from the developer's team.
b. Comes with free updates.
c. The fastest way to retrieve the password and hack an account.
d. It is free of cost.Completely user-friendly.
e. You don't need the knowledge of software designing and coding.
Apr 12, 2017 | Computers & Internet
I want retrieve my emails
log into your email provider and your emails should be there.
Feb 28, 2017 | Computers & Internet
I've been hacked, what do I do??
How to Recover When Your Email Account Is Hacked - Norton
us.norton.com/yoursecurityresource/detail.jsp?aid=email_hacked
What's worse is that your online security and perhaps your computer have been compromised. How you proceed next can affect your life in more ways than you ...
My Email has Been Hacked - What Do I Do? - Webroot
www.webroot.com/.../beginners-what-do-i-do-when-my-email-...
WebrootSpammers use a variety of methods to send spam, but the use of hacked legitimate user's email accounts is booming. In the second quarter of 2011, the average ...
My account has been hacked - Outlook.com Help - Windows
windows.microsoft.com/en-us/.../hacked-account
Microsoft WindowsIf your account has been compromised (hacked) it means that someone stole your password and .... Email deleted from children's accounts can't be restored.
Top 9 Things To Do After Your Email is Hacked - ABC News
abcnews.go.com > Money
Jul 21, 2013 - For many people, the first sign that their email has been hacked comes when a friend ... 9 Things You Need to Do When Your Email is Hacked.
What To Do When Your Email Gets Hacked - Techlicious
Jan 31, 2016 | Computers & Internet
Hotmail hacked
Finding the proper solution sign in related issue is a difficult task because the exact tackling strategy is what can resolve this immediately. A non-technical person could not find this, but not for the technicians of Hotmail Customer Care Number UK. They are qualified and skilled in this field so that you can get the correct solution to the problem. Get Support on phone through dialing toll free number +44 (0)800-041-8264 (UK).
Useful link: http://www.hotmailemailsupport.uk/services.html
Jun 02, 2015 | Computers & Internet
Is it possible to hack facebook account?
Anything is possible with the developing technology these days. There are some individuals who have succeeded in hacking the facebook account. There are softwares available in the internet that enables you to hack facebook account. Facebook could be vulnerable to an attack but this does not last long as the security systems of facebook are tight and they are maintained often so it is hard for someone to get a way to hack them. There have been claims that it is easy for people who have Linux to hack but obviously there is nothing that can easily be hacked.
Oct 04, 2012 | Casual Collective Facebook Apps
I want to hack facebook account
u need to go to this website free pruduct key for microsoft 2010 and thaen under it would say on ce u have clicked in the tab it would say hack facebook passwords and all of these other hacking stuff go ther and this could be ur soluthon
Mar 19, 2011 | Computers & Internet
How to hack facebook password?
How To Hack Facebook Password?
You most likely reading this because you "want to hack into a foreign Facebook account". So in this post I decided to each Facebook account hack reveal the real and working conditions.
Nov 15, 2010 | Facebook Social Network
Computers & Internet Logo
181 people viewed this question
David Payne
David Payne
