Question about Gateway E-4100 PC Desktop
I recently started to have this problem with my gateway. The problem was gradual, but basically the computer seems to just shut off and the 3keyboard lights and the light on the power button blinks repeatedly like the computer is trying to turn back on but it goes off and back on then off again repeated. It's like if someone is playing with a light switch turning it on and off, on and off, on and off. I took it to Staples (because they say they fix computers) but they said they couldnt find anything wrong with it! They "said" they had it on over night and nothing happened. I pick it up after a couple days and it does it after being on for 5-10mins. Does anyone know what is going on with my computer?
  • Gateway Master
  • 5,568 Answers
Azkeyz has hit on the most likely problem; the power supply can cause all kinds of failures once they are on the road to complete failure in which it will not turn on at all.
If it is an ATX power supply (most common) you can buy these on eBay for under $10 US about any time:
You will have to check the one you now have for its power rating and it is wise to buy a higher rated supply, the cost difference is minimal. If you want to pay the extra cost, you can get these from any store that deals with PCs but they often mark them up by 400-500%
If you are not familiar with the guts of a PC, you might want to take a number of snapshots once the case is open if you are confused by the array of cables, most of which cannot be incorrectly connected and are of different types and the cables that appear identical, well, they are.  Drive cables in particular can be interchanged without problem but board and fan connectors can hardly be wrongly installed; just don't force anything.
Posted on Sep 23, 2008
  • 300 Answers
Power Supply Failure !
Wizard Division
I have a Gateway all in one model zx4931. When power button is pushed the blue light does not come on. The vanity light comes on & off as if its booting & shutting down. I have a green light at the...
Sounds exactly like a failing power supply. Hopefully you bought an extended warranty when you purchased the computer. You should look into having the PSU replaced.
Jun 02, 2014 | Gateway One Hd Zx4931 21.5" All In One...
Computer won't boot up
You have to give more information about the behaviour..You computer shuts off..when exactly ? Has it passed bios check? Are windows loading or windows screen appears..?Can you open bios setup while booting?
However..shutting off..seems to me that the Power Unit may have failed
Nov 11, 2013 | Gateway Computers & Internet
How do you know when the power supply is failing?
Actually its not the matter with the Power Supply,but with the CPU Cabinet Power Button.I recommend that you should replace the Cabinet.It will surely help,and for the freezing problem it's your Hard Drive problem,you can also try re installing Windows...!!
But for the Power Button problem you should definitely replace the cabinet
Aug 21, 2012 | ASUS A7V400-MX Motherboard
Computer required restarting due to problems with mouse. Once computer was restarted gateway monitor would not work
Not enough information. Please describe any monitor activity when
you turn it on, do this while the computer is still off, unplug monitor, then
plug back in. It should start automatically, then show the gateway logo, then
go blank for several seconds, then show no input signal box, then shut down on its
own. If it fails to do this it is probably that the power printed circuit board
is failing, not delivering the proper power to the main board and/or the back
lamps. One can have this board repaired inexpensively by a qualified electronic
Email me at
and we may be able to get your unit working properly again.
Have it repaired soon to avoid additional component failures
Dec 17, 2010 | Gateway FPD1975W 19" LCD Monitor
What are the symtoms of a failing power supply on Gateway GT4024? Thanks, JEL
Some symptoms of a failing power supply unit on this unit are, computer does not start automatically when power button is press, the place where the power supply is located is getting way to hot unlike before and then computer just shut down itself without any notice. IF you have these symptms you might want to consider already replacing the power supply on this computer.
Aug 12, 2010 | Gateway GT4024 PC Desktop
This monitor is great. Just recently, after 3
It seems so.
1. Change the monitor cable and see if this still happens
2. Attach this monitor to another PC and see if this still happens
If it is still happening, then yes, it seems that it is failing.
Mar 14, 2010 | Gateway FPD1760 17" LCD Monitor
My Gateway 700X PC (Windows XP) will not Shutdown/Will not Start.
Best to format and reinstall a fresh copy of your operation system.
Feb 24, 2010 | Gateway 700 X PC Desktop
Gateway GT4022 Motherboard failed
Well, I think gateway is just a computer manufacturer, so if you are still under warranty, you could possibly get a replacement. But before doing anything, and if you are comfortable with doing so, open up the side of the casing, and take a look around, see if any cables seem unconnected.
Jul 08, 2009 | Gateway GT4022 PC Desktop
Vista will not shut down, hibernate or sleep
It had to be sent in for service. Best Buy said it was a hardware issue after their diagnostics came up with nothing.
Basically it would act like it was shutting down, hibernating or whatever and about 15-20 seconds later, it would re-boot or resume windows.
Apr 17, 2008 | HP Pavilion dv6000z Notebook
Gateway E-4100 PC Desktop Logo
77 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
