Question about Hitachi 42HDS69 42 in. Plasma Television
Hitachi 42HDS69 I came home yesterday and tried to turn my tv on and it would not do anything, nothing happens when i try to turn it on, is there a fuse in these tv's that could have blown
  • 2 more comments
  • rdubya864 Oct 10, 2008
    42hds69 will not turn on. very posible that it may be a fuse, where is the fuse located
  • Jay Abed
    Jay Abed Oct 29, 2008
    Have the same problem. No Power. No Power click.. nothing.
    all fuses are ok. but no standby voltage. Found Q102 and D 012 shorted. Replaced. but still dead.
    Will look into a little further into it. If no luck will send
    power supply board out for repair or replacement.
  • Anonymous Jan 02, 2009
    I have the same problem I came home turned the tv on and it cut right off. Cut it on again, cut right back off. Then it would not turn on a all. I have a monster cable to prevent anything electrical happening, and it is on, but no power going to the tv.
  • Lori Otten Jan 06, 2009
    My Hitachi 42HDS69's Standby light is on. No picture.I can't get the standby light to go off, can't get the tv to go on!!
    Sergeant:
    Champion:
  • 223 Answers
Yes there is a fuse in most of the sets for protection that might either be a glass fuse or a fuse soldered to the board. If the fuse is intact suspect a fault on the power supply board where you located the internal fuse. Hope this helps.
Posted on Oct 04, 2008
Tv turns on but stays on standby
Have you checked the manual? Here is a link http://www.manualslib.com/manual/419601/Hitachi-42hds69-42-Plasma-Tv.html
May 15, 2016 | Hitachi 42HDS69 42 in. Plasma Television
I am trying to upgrade firmware on a hitachi 42hds69, using a 2 sd card, I formatted the new card before uploading the file, I did unzip the file on my desktop. The tv won't do the upgrade. any Ideas
I had an issue (OTA no audio in channel 2-1 and 11-1) on my Hitachi 42HDS69 so I tried to upgrade the firmware. The manual as well as the instructions on TV all state to use a MMC card. Someone on an internet forum also stated that a 7-pin MMC is needed. I tried exactly that but it did not work. Finally I tried a 128MB SD card and it worked like a charm. The firmware upgrade fixed my OTA audio issue. I went from V0108 to V0125.
All you need to do is to extract out the .F02 file and place it in the root directory of the SD card.
BTW, I did call Hitachi customer support. They refused to help due to the TV is too old (about 10 years old).
I guess it all depends on who you speak to at Hitachi?!
Feb 09, 2011 | Hitachi 42HDS69 42 in. Plasma Television
I have a Hitachi it is stuck on stand by. Cant
Hi I have same problem as you but with different brand of tv, now is all good, if you open your back tv see there board connect to your on /off button on tv or find where is on/off button on your tv, try follow where is the wire going to the board,there is 3 cappacitor in mt tv said 470 uf 25 V your tv could be different size. the capacitor doesnt look bulge or bad but i just change it cost me aus $ 2.10.and work straigh away. hopely this help.
regards.
Apr 30, 2010 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi ultravision model number 42hds69 cable problem.
Usually you need a decoder to receive "Cable" With your "Cable" usually you connect the Cable antenna, to the Cable "Box" form the "Box" to the Audio Visual EXTERNAL inputs, in the back of the TV. Now IF your TV can receive the "Cable" directly, then you would have to connect the Antenna, into the rear of the TV, now you would go to the "Tuning" section, and, the TV, would automatically "Search" for any available channels. They would then, be displayed at the end of the scan. Please find a user manual below, this will help you tune in, IF you can. If you cannot, you will have to get a cab;e "Box" and a remote. Hookup to the TV, from the "Box" to the TV, via, Audio and Video cables. You use the "Box's" remote to change channels and volume. You first must set the TV's Volume, & picture setting, the TV, is basically just used as a "Monitor" for the "Box". Hope this helps..
http://tv.manualsonline.com/manuals/mfg/hitachi/42hds69_55hds69.html
Apr 23, 2010 | Hitachi 42HDS69 42 in. Plasma Television
HItachi Model 42HDS69 Stuck in Standby
Tv problems?. any warrenty on the set? how old is the set?
Mar 18, 2010 | HP Televison & Video
Hitachi Plasma Model PD32-A3000/AVC-A3000
vertical red line on screen - I have a Hitachi plasma 42HDs69
Jul 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Tv will not come on
Try to replace the Power Supply board of your tv.
Jan 19, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Hitatchi tv problem
A fuse has probably blown inside the TV, I had something similar with a panasonic TV a number of years ago. Open the back up and use a continuity tester across your fuses till you find the right one...................dont forget to unplug it first !!
Dec 10, 2007 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi 42HDS69 42 in. Plasma Television Logo
520 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
