Question about Pioneer Televison & Video
Pioneer SD-P55A3-K Proj TV will only stay on if I run a fan behind it...
My TV shuts down without warning and goes into standby mode. Sometimes I can get it to come right back on, other times it won’t come on for hours. I’ve sent it out twice for repairs already; the first time they just replaced the fuse, the second time they replaced the fuse and re-soldered the connection. Since the last repair, I’ve replaced the fuse myself a couple of times, but it eventually will blow again. I’ve found that if I place a small fan on the floor behind the TV so that it blows air into the back of the unit, the TV will stay on. The interior temp of the house seems to make a difference too as it tends to stay on longer in the evenings when the house is generally cooler. I’m guessing something is overheating and need to be replaced. I just don’t know where to start and I really don’t want to send it out again for several weeks only to be told the fuse needed to be replaced. Any suggestions you could offer would be greatly appreciated. Thanks!
    Sergeant:
  • 300 Answers
Thermal issue !
A component inside the set has a thermal issue !
This may require hours of trouble shooting to find the components responsible.
Once the component(s) are found they could be serviced.
azkeyz@fixya.com
Wizard Division
Posted on Sep 23, 2008
No picture on my pioneer TV model SD-582hd5
The problem is on lamp try to replace it to get back the picture..
Feb 23, 2012 | Pioneer SD-P55A3-K 55" Rear Projection...
I have a Pioneer SD-P55A3 and i was wondering if it can be taken apart for moving purposes?
No,don't this tv is a delicate equipments inside.Tv CRTS R,G,B TUBES guns are easily to be broken if dosen't have the outer frame to protect it.Also the Tv CRTS R,G,B TUBES guns have coolant chemicals inside it,could also damage ur tv even if the CRTS R,G,B TUBES guns are not broken.Tries to put it on the cargo pallet,put a heavy blanket on.Ties it with a heavy ropes tightly and firmly.Than put it in a moving Rider truck or a personal truck.Now firmly sacures the tv for good not to make any movment.Now u can tranport it anywhere.
Dec 06, 2010 | Pioneer SD-P55A3-K 55" Rear Projection...
My pioneer sd-p55a3 projection tv stays on for 5 minutes and then fuse for projector burns out
probably the solder connections on the convergence board.. solder it up good and it will usually stop blowing that fuse..
what is the fuse #?
let me know if i can be of further asistance
Jun 08, 2010 | Pioneer SD-P55A3-K 55" Rear Projection...
Sd-p55a3-k/kc this tv does not turn on
Th convergance amps have failed you will half to replace them, or have it done parts are around 70 dollars not and easy fix on a pioneer time consuming
Dec 10, 2009 | Pioneer SD-P55A3-K 55" Rear Projection...
Tv shuts off go on standby wont power back up
make sure it is pluggen in all the way to the source of video or may need new cord
Nov 24, 2009 | Pioneer SD-P55A5K 55" Rear Projection...
My Pioneer 55 inch screen tv SD-P5553 has a solid black horizonta
This sounds like a picture mode issue. You maybe in a ZOOM mode. Try adjusting your set to FULL mode. If you are using a Sat receiver or cable box, some of these may have picture viewing mode as well, wich may need to be set in FULL or NORMAL viewing mode.
Good Luck!
Jan 18, 2009 | Pioneer SD-P55A3-K 55" Rear Projection...
Pioneer 58" SD-582HD5 1080i -Rear Proj TV
Like most problems with this model, check and re-solder the connections on the power supply board on the right rear of the tv, just behind where the main power cord goes in. Most problems are around the upper left corner where the white connectors E-12 and others. Check all of them from loose and cold solder solder connections on the board. Hope this helps.
Jun 02, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer tv
This is a common problem with pioneers. try resoldering the vertical output Ic that should remedy the problem. if not the vertical IC may be faulty
May 27, 2008 | Pioneer SD-P55A3-K 55" Rear Projection...
Pioneer P50A5-K goes to stand by mode
1) Pull chassis---remove power/convergence PCB==the one
with the large heatsink on it.
2) Remove solder from pins of four regulators on heatsink.
3)Clean board/pins w/ toothbrush & alcohol.
4)Re-solder, also solder both Stk's for prevent.
5)Re-assemble
Oct 10, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Televison & Video Logo
125 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
