Question about Olympus SP-350 Digital Camera
Black lcd & photos
Black lcd with camera & lens opened , photos taken but black & just out of 2 year garantee
:) janadoo
  • furbee40 Nov 09, 2008
    I have a FE-290 and have the same problem:(
  • twistoffate Nov 26, 2008
    I also have an sp 350...I dropped mine in a puddle now it only takes black pictures although I can view photos taken before the incident perfectly...any ideas? I want to take it apart to have a look..I've removed all the screws but the back still won't come off :S
    Tracey
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
Press the monitor button.. if still black then repair.. should be around $150
Posted on Sep 23, 2008
Canon A530 black spot on LCD which is visible in the photos tried to clean the lensa but was in vain canyou help pls?
A blck spot on your pictures, means there is something blocking light on the sensor. Could be dirt, but more lightly is there has formed some mould.
Because you can't open a compact camera to clean the sensor, I think you can't solve this problem. Opening the camera is no option, because without skills, tools and manual, you won't be able to put the camera together. A repair shop most likely won't start the job, because the repair will cost more than a new camera.
Sorry I can't bring a more positive story.
Jan 26, 2014 | Canon PowerShot A530 Digital Camera
I have a Cannon PowerShot S2 IS digital camera, about 5 years old. The LCD Monitor and Viewfinder both only show a black screen with some of the Dispay Icons across the top and bottom, and after a few...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 06, 2011 | Canon Cameras
Its a Panasonic DMC-TZ3. all on a sudden, LCD is not working. Monitors remains dark when I press 'On' button and the photo taken are also dark. However old photos on the SD card I can in the screen...
Hello
If you can view the pictures previously taken with the camera on the camera LCD, but the new photos just come out black, this is most probably a blown ccd.
This is a expensive component to replace, and you will also need specialized equipment to do this yourself.
I would suggest that you take your camera to your nearest repair shop and let them test the ccd.
Hope this can be of help.
Kind regards
Andrea
Aug 12, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
LCD monitor is not working ( the photo taken is not displayed on the LCD screen whereas other details like AUTO, S/L/M, no of photos can be taken are displayed) pl. help
One of two possible things. First try pressing the DISP or DISPLAY button on the back of your camera. This manually turns the LCD screen on and off to save batteries. You would then use the optical viewfinder in its place. If this doesn't fix the problem...
Aug 08, 2010 | Canon PowerShot A580 Digital Camera
I cannot see anything when in camera, film, or view mode. When I snap a photo, it sounds like a picture was taken and the flash still goes off, but nothing is displayed on the screen. Only when I attempted...
Does it show pictures on the computer or is it black images, if they are black, your cameras lens cover could be stuck, it opens up when the lens is fully open, dirt-sand and dust or old grease causes the problem. otherwise your LCD on the camera could be off by mistake, (Do a camera reset) or a bad LCD
Oct 27, 2009 | Canon PowerShot SD600 Digital Camera
Problem with canon a420 digicam
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Note that your camera will not be able to take 15 second exposures, as per the above "fix". Instead, place the camera in manual mode, turn off the flash, and take the exposures in a darkened room. This should give you a couple seconds, just enough time to open the battery door while the red and yellow lights are flashing.
Sep 21, 2009 | Canon PowerShot A420 Digital Camera
Black screen
Try cycling through the Display button until you're able to view photo to be taken.
May 06, 2009 | Sanyo VPC-S500 Digital Camera
Lens cover problem leads to LCD problem
If the pics show up on the memory card, it's just an LCD issue.
Jul 27, 2007 | Canon PowerShot S30 Digital Camera
Olympus SP-350 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
