Tv shuts off on on its own. It takes 1/2 hour of constantly hitting the on button and it finally stays on. Once it's on it's fine.????
    Sergeant:
  • 300 Answers
Consult your owners technical namual as your set may require you to reset it's sleep timmer.
azkeyz@fixya.com
Wizard Division
Posted on Sep 23, 2008
Zenith tv, trouble turning on and staying on
There is a problem in electrolytic capacitors, probably the 300V one in the primary section of the power supply.
You should measure if there is a stable 300 V available in the primairy section...
Jul 07, 2009 | RCA F27450 27" TV
Does Not Stay On
When you insert the card and get the CHA Flashing error, remove the card and format it. Reinsert it again.
Should work.
Oct 16, 2007 | ViewSonic VPW505 50 in. HD-Ready Plasma...
Sansui tv shuts off by itself after being turned on.
the relay on the power board needs to be replaced; if you feel confident to do this:unplug the tv wait about a 1/2 hour then remove the tv's case carefully look for a small black or, brown box about 1/2" x 1" x 1/2" this relay should have a designation such as Rly 1 printed on the circuit board it must be unsoldered and, removed the numbers on the relay can be entered into a search engine to find a replacement
May 03, 2009 | Sansui TVM1316 13" TV
Sabre 42 in plasma tv stuck on component 1
remove the power from the wall and leave the TV off for at least an hour, the static charge may have shorted the circuit board for the pront panel controlls.
after an hour or so plug it back in to see if has reset itself
hope this helps
regards
Nov 27, 2008 | Televison & Video
TV Turning on and off by its self
You have problems with a condenser that allow the power supply to maintan an acceptable level of voltage in order to keep the TV on. take to a tech to be fixed. unfortunatelly, this problem needs a tech to take measures in the circuitry to find the component that causes the problem.
Nov 06, 2008 | Philips Magnavox TS3260C 32" TV
Need Help big screen turns on thens goes off
a tv has two components, firstly a power supply produces high voltage to trigger a line transformer, in turn a transformer produces smaller voltages. firstly check if the ht is constantly been produced from a supply, if this is there than go to a line transformer, and check voltages at the output.
Sep 10, 2008 | Panasonic PT-61HX40 61" Rear Projection...
Monster remote by tv tech codes
Hit code search ... then the TV button .. then turn it off and on alot of times .. until the tv shuts off .. then hit enter ...
it takes me like 10 trys of doing this to get mind to program ... because i always hit the on/off button atleast once more after the tv shuts off because its such a shock when it does finally turn off...
I have to do this once a month because the kids always drop it and knock the batteries out
Sep 01, 2008 | Universal Remote Control Remote Control
My RCA D52W20 will not stay on
Clicking sound is power relay engaging. If all systems are not functioning properly, unit will shut down to prevent further damage and/or fire hazard
Apr 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Need RCA univeral remote control code for Magnavox 27MS343S
Push in and hold code search button until it stays lit, then pushed the TV button, it flashes quickly. Then hit the number zero once, then hit channel up button until tv finally changes channel. Hit the mute button once to get it to store the code.
Feb 20, 2008 | Philips Magnavox 27MS343S 27" TV
Need codes!!!
1. Go to http://www.urc.philips.com/ 2. choose US URC modles 3. choose US2 4. choose US2-P63S. Really dumb but the owners manual states PH601S but in Philips web site its called US2-P63S -
Sep 07, 2007 | Televison & Video
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
