Question about GE (PSS26MSRSS) Side by Side Refrigerator
Noisey ge side by side
My ge side by side howls like a wolf looking at the moon. the blower in the freezer compartment seems to be the source of the noise, also the water dispenser works when it wants to. please help the noise is so irrtating.i purchased 3 years ago.
  • billdebi123 Oct 11, 2008
    Same problem. My GE side by side "GSS221BPHWW" howls as well. Fan seems to work fine at times but somewhere between the defrost cycle and normal operation the fan becomes intermittent. By intermittent I mean the volume of air being moved varies. This is when the howling occurs.
I changed the control board. This made the most sense to me based on the symptoms (Howling, fan speed variation) I was experiencing and the suggestions given on this Web site. I have not heard the howling or fan speed variation since. Cost of the Control Board was around $80 and the repair was easy to do. I must admit, initially I thought it was the fan motor. But the fan speed variation seemed more like a control (Voltage regulation problem). My thanks to everyone for all the help.
BillDebi123
Posted on Nov 03, 2008
Replaced fan computor board . it eliminated the howling from the fan mtr ramping up and down, i can watch my tv now
Posted on Oct 28, 2008
  • 120 Answers
Well it could be the switch but you have to check it with a meter to check for volatge it be a voltage drop from your board try switch first but no luck try checking board
Posted on Oct 12, 2008
  • 943 Answers
Hi thanks for the question that noise is the fan in the freezer.you replace the fan motor the water disp problem is the little switch inside the freezer door difficult to get at please accept with a positive feed back thanks the appliance doc
Posted on Sep 23, 2008
Gsh22kgrecc freezer compartment howls
Check to see if fan is loose also check to see if there is ice buildup inside and blade is hitting it
Jan 24, 2018 | General Electric Refrigerators
My GE Fridge PSS26SGRD has a moaning howling
The fan is hitting on ice buildup...unit is not defrosting...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Howling noise from freezer fan, GE side-by-side
Replace the fan, Remove the evaporator cover in the back of freezer, and probably another cover for the fan. Unplug your refer first. Usually their are two screws holding the fan bracket to the wall or mount. disconnect the wires, and replace. Their is a newer model evap fan motor that does not have wiring terminals to disconnect, it is hard wired together and you have to practically remove everything in the freezer compartment to get at it. You have to cut wiring and splice the new fan motor in. Fairly tough job. Usually an evaporator fan motor bearing fails from the refer being moved or in storage for a few days at least with the doors closed and the unit unplugged. This allows all that moisture that was in the freezer to get into the metal parts of the fan motor and cause this problem. To prevent this always block the doors open if your refer is going to be off for a few days. This will allow the unit to dry out without damage. Sometimes it was just a bad motor from the factory. Good Luck, Appliance Specialists
Dec 17, 2009 | GE GSF25XGR Side by Side Refrigerator
G E side by side refrigerator is not working properly....
Could be the start relay device on the compressor. Does it try to start every minute or so?
Sep 10, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Whining/howling on freezer side
Need to unplug the refrigerator and remove the cover inside freezer compartment. Sounds like the evaporator fan is hitting something and we need to resolve this as soon as possible. Thanks Sea Breeze
Mar 26, 2009 | GE Refrigerators
GE GSL25JFR Freezer fan noise.
Replace the fan motor is my guess to cure the noise.
Mar 01, 2017 | GE Profile¿ 42" Built-In Side-by-Side...
It is very common for the fan inside the freezer to develop a loud noise as it runs. Its in an environment that is hard on them, cold, wet. Its a small and simple motor, and you are right in believing there will be more problem in the future, as the stator is probably touching the housing. It has a sleeve type bearing, and its probably worn a little causing the shaft to wobble. Eventually it will stop completely and the freezer will get warm.
Mar 07, 2008 | GE DSS25KGT Side by Side Refrigerator
You are correct in believing the fan is going to be a problem. The evaporator fans inside the freezer compartment are common at going bad. I believe it is due to the extreme temperature and moisture conditions inside the application. The noise is the stator or bearing equivalent going out, the speed should remain constant. It may eventually make a screeching noise upon start up, or just lock up completely. The good news is replacements are relatively cheap and easy to find. If you do replace it yourself, make sure the fan blades are blowing in the right direction. If possible, remove the old one and bring it with you to the local appliance parts supplier and he should be able to help you get the right one, it will probably be a kit of some sort with multiple mounting brackets, screws, and maybe even a couple of blades. don't let this intimidate you. Most of this you will not use.
Dec 17, 2007 | GE GSL25JFR Brushed Steel Side by Side...
Howling - Which is the correct fix
I think I have the same problem. The unit is also about 2 years old (GSH25KGRBB). I have an extended warranty. They already replaced the controller card. I see it is the exact part number you have mentioned. It seemed to help for awhile but I think it has gotten worse again. The noise is more consistent after they changed the board. Less revving up to "turbo" mode. Howling is a good description. I can hear it now, on the other side of the house. I would change the fan out. I think they did the board first because it probably is easier even if the part cost is higher. I will probably call them back again. This will be the third time. The first time they just changed the little flapper on the ice dispenser. Otherwise the unit cools and runs flawlessly.
Aug 11, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
258 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
