Question about Microsoft Windows Vista Ultimate Edition
Files "lost" using exPressit S.E. 2.2 and Vista
I've found if I don't start exPressit with the RUN AS ADMINISTRATOR option, that any work I create during that session is "lost". Can't even find the files during a search etc. Only way to see or pull them back up is to start the program again - and not with RUN AS ADMINISTRATOR. How can I make all the files I create in this program viewable? Many thanks!
  • troubles2222 Sep 23, 2008
    thanks for the reply - but sorry, doesn't help.
There might be some instractions added as a manual. please look and check that not out but smart.
Posted on Sep 23, 2008
Error Code BIOHD-4
Remove any external devices connected to the computer except the mouse and keyboard to check if it boots normally.
This error can usually be fixed by following the steps below. Doing all this requires a certain level of computer skills. You know yourself best and whether taking the machine to a competent local computer tech (not a BigComputerStore/GeekSquad type of place) is the better solution for you.
1. Log into another user account with administrative privileges. If you neglected to make an extra administrative account do Steps 2-3. Otherwise continue at Step 4. Also see the general information about setting up user accounts in Vista at the end of this post.
2. Boot into Safe Mode. Do this by repeatedly tapping the F8 key as the computer is starting up. This will get you to the right menu where you can use your arrow key to select Safe Mode [enter]. The built-in Administrator account is disabled by default in Vista. However, if no other administrative accounts exist on the system it may be enabled. If it is, you will see an icon for Administrator on the Welcome Screen in Safe Mode. Log into Administrator.
3. If If you don't see the icon for the Administrator account in Safe Mode, then the built-in Administrator account is still disabled and you'll need to do some more work. If you have a Vista installation DVD (not a recovery DVD) you can boot the system with it. Select the default language, then choose "Repair your computer". Then select "Command Prompt". At the command prompt type:
net user administrator /active:yes [enter]
[Note: Do not type the brackets!]
If you don't have a Vista installation DVD (only have a recovery disc), the computer mftr. may have given you the Vista System Repair option (not a System Recovery!) on the diagnostic menu. This diagnostic menu is the same one where you can choose Safe Mode. Or you can make a bootable Vista Repair DVD from the file at this link:
http://neosmart.net/blog/2008/windows-vista-recovery-disc-download/
which will cost you $9.75
Note: All the Neosmart recovery disc downloads are torrent files. There is a good explanation of torrent files at the Neosmart website. You will need a torrent client such as muTorrent to get the files. The torrent client will download the .iso file with which to create the bootable DVD. You will need third-party burning software such as Nero, Roxio, or the free ImgBurn (www.imgburn.com ) to burn the .iso as an image, not as data.
Now remove the rescue CD/DVD you made, reboot the system into Windows, and log into the built-in Administrator account you enabled.
4. Try a System Restore to when things were working. If you can log into your own user account, you're finished. Otherwise continue at Step 5.
5. The critical files are under %systemdrive%\users\user-account\ntuser. The ntuser.dat file is actually a registry hive. Run Regedit elevated and select HKEY_USERS and "load hive" from the menu. Now navigate to:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
There is one line for each profile. If a profile is bad, check:
a) That the key name doesn't end in ".bak" (remove .bak if there)
b) That the RefCount value is 0 (change it if different)
c) That the State value is 0 (change if different)
Make any necessary changes, close Regedit and try to log in as that user.
6. If that doesn't fix your profile, it is corrupted. At that point you should make a new Standard user account and copy your data to it. Do not delete the old account until you have retrieved the data you need!
Once everything is working, log into the extra administrative account you will make per the suggestions below and disable the built-in Administrator account again for security purposes:
Start Orb>Search box>type: cmd
When cmd appears in Results above, right-click it and choose "Run as administrator" [OK]. Now you will get the command prompt. At the command prompt type:
net user administrator /active:no [enter]
Exit the command prompt.
General Recommendations For Setting Up Users In Vista
You absolutely do not want to have only one user account. Like XP and all other modern operating systems, Vista is a multi-user operating system with built-in system accounts such as Administrator, Default, and Guest. These accounts should be left alone as they are part of the operating system structure.
You particularly don't want only one user account with administrative privileges on Vista because the built-in Administrator account (normally only used in emergencies) is disabled by default. If you're running as Administrator for your daily work and that account gets corrupted, things will be Difficult. It isn't impossible to activate the built-in Administrator to rescue things, but it may be more work than you want to do. Best not to get into a bad situation to begin with.
The user account that is for your daily work should be a Standard user, with the extra administrative user (call it something like "CompAdmin" or "Tech" or the like) only there for elevation purposes. Running as a Standard user is best practice for security purposes and will help protect your computer from infection. After you create "CompAdmin", log into it and change your regular user account to Standard. Then log back into your regular account.
Apr 16, 2012 | HP Pavilion Elite m9500f PC Desktop
Tip
How to Reset Gateway Password?
How to reset Gateway laptop password? I forgot my PC password Gateway Windows 7, I want to unlock laptop password urgently! Can you help me recover my lost power on password for Gateway? Now, we together share some ways to remove Gateway admin password.
Optional 1: DIY a CD/DVD/USB password reset disk instantly to recover lost Gateway password
The method is the most effective solution to get out of Windows password problem. It just needs burn an .iso image file to one of these media. Now, take one of most popular Windows Password Recovery tool as example:
A. Download Windows Password Recovery and burn its .iso file into a blank CD/DVD or USB Flash Drive on an accessible PC;
B. Boot the burned CD/DVD or USB Flash Drive from the PC lost password;
C. Reset a new Gateway password.
Whatever for Gateway Windows 7, Vista, XP, Server 2000, Server 2008, etc. the above Ainorsoft Windows Password Recovery has its different versions to suit for these OS.
Optional 2: Gateway password recovery disk helps remove lost laptop password
It is the most convenient way to retrieve Gateway PC password and while, is maybe suitable for little part of computer users. The Gateway recovery disks should be created once our Windows account is created. Also, one account password responds to one password reset disk. Take Gateway Windows 7 as example:
A. Insert a CD/DVD/USB Flash Drive into the driver.
B. Click Start - Control Panel - User Accounts and Family Safety - User Accounts.
C. On the left pane, select "Create a password reset disk" - "Forgotten Password Wizard".
D. Click "Next" and follow the Wizard to create password reset disk.
Now, the Gateway Windows 7 password recovery disk is created. When we need break Gateway Win 7 laptop or notebook password on the login screen and input an incorrect password, click "Reset Windows Password" and insert the password reset disk. The Password Reset Wizard will help you create a new password to override lost Gateway password.
Optional 3: Reset Gateway password by accounts with administrative privileges
Accounts with administrative rights or the default and built-in account can help us to remove Gateway password. Take Gateway Windows XP as example, there is a default Administrator account. We can use it to unlock locked account if this built-in account is still blank or accessible.
A. Press Ctrl+Alt+Del twice when PC starts and then input "Administrator" in the username field and leave the password filed blank at the classic login screen. Press Enter and login PC.
B. Start -> Control Panel -> Administrative Tools -> Computer Management -> Local Users and Groups -> folder Users
C. Right click the account user name which password was lost, and then click Set Password -> Reset password -> keep New Password and Confirm Password blank.
D. Right-click locked account and select Reset password.
E. After finished, restart PC and login.
Optional 4: Ophcrack Windows Password Recovery software
Ophcrack is a free Windows password recovery tool which only works for passwords with less than 14 individual characteristics.
A. Download the Ophcrack LiveCD and burn its .iso file to a CD on an accessible PC.
B. Insert the CD into the locked computer and restart it.
C. When computer starts, we have to press the correct key to enter the boot menu.
D. After select the drive that the CD is in at start menu, do as the following instructions.
If we forgot Gateway laptop password and need Gateway password reset, we can easily reset Windows 7, XP, Vista password on Gateway PC or netbook with the above 4 optional methods.
Source: http://windowspasswordrecovery.net/article/gateway-password-reset.html
on May 06, 2011 | Computers & Internet
Tip
6 Free Solutions is Behind You for Windows Password Recvoery
<span>When you forgot your Windows login password, what would you do? Take your computer to a PC repair shop or buy an expensive<span> </span><a href="http://www.passwordunlocker.com/windows-password-recovery.html">Windows password recovery</a><span> </span>tool? Well, sometimes it costs you no penny to get back or reset your lost Windows password actually. Don't believe it? Just have a try of the following free Windows password recovery solutions if you forgot Windows password to your computer.<br /> 1. Ophcrack LiveCDMany free Windows password recovery tool are supposed to help you get back in computer if one<span> </span><a href="http://www.passwordunlocker.com/knowledge/forgot-windows-password.html">forgot Windows password</a><span> </span>for your computer. In reality, some users resort to free Windows password recovery tool to unlock their PC, like Ophcrack. Ophcrack LiveCD is a completely self contained, bootable version of Ophcrack. Ophcrack LiveCD is the easiest and most effective Windows password recovery freeware that I've ever found to "crack" your forgotten Windows password.<br />Since you can't login your Windows PC because you lost the password, so first you'll need to visit Ophcrack's website to download ophcrack LiveCD. Please make sure that if you've forgotten Windows 7 password or Vista password, click on ophcrack Vista LiveCD. If you've forgotten XP password, click on ophcrack XP LiveCD.<br /> 2. Cain & AbelUnlike Ophcrack and other popular Windows password recovery programs,<b><span> </span>Cain & Abel</b><span> </span>requires access to Windows under an administrator account. In fact, Cain & Abel is a bit more complicated to use than other password recovery tools which is usually unavailable for Windows Vista as is said.<br />If you have no way of getting in to your Windows PC, you will not be able to use Cain & Abel to recover your password. Moreover, before you can use Cain & Abel, you'll need to download a rainbow table. These large databases of passwords are required so Cain & Abel can reset the forgotten windows password.<br /> 3. Available Admin AccountIt's well known that Windows administrator users have rights to change password of other user account on the same computer. So if you forgot password of the user account, just enter your administrator account and do as follows:<br /> <ul> <li>1. Press F8 to enter the<span> </span><b>Advanced Boot Options</b><span> </span>when booting your PC.</li> <li>2. Select<span> </span><b>Safe Mode</b><span> </span>and enter your computer with an Administrator password.</li> <li>3. In Safe Mode, click<span> </span><b>Start</b>-&gt;<span> </span><b>Run</b>-&gt; Type<span> </span><b>control userpasswords2</b>-&gt;click<span> </span><b>OK</b>.</li> <li>4. On the coming up Users screen, click the name of the user account that you want to reset the password for, and then click<span> </span><b>Reset Password</b><span> </span>to process.</li></ul> 4. Windows Password Reset DiskIt is considered the easiest way to reset Windows password when you are forbiddened to access your laptop with protected password. However, many of us haven't enough consciousness on creating a Windows password reset disk before they lost the password.<br /> <ul> <li>1. Type a wrong password on the Windows logon screen.</li> <li>2. Click<span> </span><b>OK</b><span> </span>when Windows displays a message that the password is incorrect and "Reset password" link will appear.</li> <li>3. Click<span> </span><b>Reset password</b><span> </span>to pop up Password Reset Wizard screen, and then click<span> </span><b>Next</b>.</li> <li>4. Follow the steps in the Password Reset Wizard to create a new password.</li></ul><b>Note:</b>This solution takes effect provided you have created a Windows password reset disk for your Windows account in advance.<br /> 5. Typing Ctrl + Alt + Del (Only Under Windows XP)This option is only for Windows XP. Furthermore, the default administrator account on Windows XP is enabled and not password protected by default, which is disabled by default on Windows 7 and Vista.<br /> <ul> <li>1. Turn on your Windows XP machine and go to its logon screen.</li> <li>2. Press<span> </span><b>Ctrl+ Alt +Del</b><span> </span>twice to pop up the classic logon box.</li> <li>3. Enter<span> </span><b>Administrator</b><span> </span>in the User name box and then click<span> </span><b>OK</b><span> </span>to log on your Windows XP machine.</li> <li>4. Click<span> </span><b>Start</b><span> </span>button to pop up the Run box, and then type<span> </span><b>control userpasswords2</b><span> </span>and click<span> </span><b>OK</b>.</li> <li>5. On the coming screen, click the name of the user account that you want to reset the password for, and then click<span> </span><b>Reset Password<span> </span></b>for password recovery.</li></ul> 6. System Recovery OptionYou can use system recovery options to reset lost Windows password by using Windows installation disc or access to the recovery options provided by your computer manufacturer. Also you can create a system repair disc as below:<br /> <ul> <li>1. Click the Start -&gt; Control Panel -&gt; System and Security -&gt; Backup and Restore.</li> <li>2. Click<span> </span><b>Create a system repair disc</b><span> </span>on the left pane.</li> <li>3. Insert a blank CD/ DVD into your CD/DVD drive and click on the Create disc button. It will start creating the System Repair Disc.</li> <li>4. When it's finished, click the<span> </span><b>Close</b><span> </span>button, and then click<span> </span><b>OK</b><span> </span>to finish.</li></ul>Of course, if you cannot resolve your problem with these free Windows password recovery tools, you can create a password reset disk with<span> </span><a href="http://www.passwordunlocker.com//windows-password-recovery.html"><b>Windows Password Unlocker</b></a>, which allows to burn a password reset CD/DVD or USB flash drive to bypass lost password on Windows 7/Vista/XP/2000/2003/2008 in a short time.<br /></span>
on May 04, 2011 | Computers & Internet
I have forgotten my password
If you have forgotten the password of your user account there are only two options which can be used.
1)If you have two or more user account on the this computer you can try to access other user account of other user and access user accounts in control panel.
Remove your user account password and log off and try to access your account.
2)If you don't have any other user account then only option is to perform the system recovery.
** you can access recovery manager from the F11 option or Use the recovery cds.
while performing the recovery you will get the option to back up your data please back up your data before performing the recovery or you will loose all your files.
this will resolve your issue.
Thanks.
Aug 20, 2010 | Compaq Presario CQ60-220US PC Laptop
Forgot Vista Administrator password !
There is a way to reset the password and it doesn’t involve reformation and reinstalling Windows. The solution is called Windows Password Recovery 6.0. It can reset almost all Windows passwords in seconds. If you want to know how to use it please visit it on http://www.recoverlostpassword.com/products/windowspasswordrecoery.html
Jan 15, 2010 | Microsoft Windows Vista Home Premium with...
Tip
Learn more about Windows Vista Administrator Password
Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:普通表格; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
In your daily using with Windows Vista,you may occur such problems and feel fowerless.
I Forgot my Vista Administrator Password!
What to do when you realize you have lost Windows Vistal Password?Here I will show you how to do ,There are many ways can help you.you just pick up one and solve your lost windows password problems.
1.The User Accounts applet in Control Panel features the Create a password reset disk wizard.
Using this wizard, a floppy disk or USB flash drive can be created that allows the password of a specific user account on a specific Windows Vista computer to be reset by the user. Possession of the reset disk is considered to be authorization to reset the account’s password. The reset disk can also be reused to reset the account’s password multiple times. However, you need to know the password of the account you want to create the reset disk for, and you must create the reset disk before you forget the account’s password.
2.To use the Vista password reset disk:
1. Insert the floppy or USB reset disk in the computer
2. Click the Reset password… item on the Vista logon screen to start the Password Reset Wizard
3. Click the Next button
4. Enter a new password
5. Reenter the new password
6. If prompted, enter a password hint
7. Click the Next and Finished buttons
8. Enter your new password to logon to the user account
I don’t know how to make a Password Reset Disk!
As the method 2 metion above,you may quite puzzle about the Windows Password Reset Disk!In fack Password Reset Disk is a software which burnt to a CD/DVD drive and then can be inserted into the locked PC and remove or reset windows password.
Here I will show you how to make a Password Reset Disk
1. Download the Windows Password Key for the the official website and install it. Note: there is a .ISO file. Burn the .ISO file to a CD or a USB flash drive.
2. Burn the ISO file on to a CD/DVD or USB flash drive.
3. When you have forgotten the password,you can insert this Windows Password Reset Disk to your locked PC and then remove the lost password.!
With this article you will have the ability to reset forgotten passwords and gain administrator access to your computer and can be a great time saver.I think now you have leran more about Windows Vista Administrator Password.What is more ,you can reset your password when you have lost windows password,Great!
on Jul 06, 2010 | Computers & Internet
Copying to c:\ in vista using batch files..
You need to left click the batch file and "Run as Administrator".
Nov 01, 2009 | Microsoft Windows Vista Ultimate Edition
Vista don´t remember my own keyword. Can´t start Vista.
It's very easy and useful to reset local administrator and user passwords on Windows Vista system.
Website: http://www.windowspasswordsrecovery.com/
Get started with the download - 3 simple steps:
Step 1 - Download http://www.windowspasswordsrecovery.com/
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
Hope it helps.
Sep 09, 2009 | Microsoft Windows Vista Home Premium with...
Forgot administrator password
Dear Mutt,
if you are using XP then please boot in safe mode then create a new user through control panel. it will solve your problem.
regards
Aug 05, 2008 | Computers & Internet
Did you forget the system password or the Windows password?
Jan 19, 2008 | Compaq Armada 1700 Notebook
Microsoft Windows Vista Ultimate Edition Logo
123 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
