Question about Evesham Emedia Ebox (EBOXAPR04) PC Desktop
XP Media Centre Edition 2005 drivers
I have just re-installed XP MCE 2005 after a crash and have a drivers disk . What are the recommended drivers to load after a fresh install?
  • 1 more comment
  • andyp275 Sep 23, 2008
    I am work at present and I will respond when I get home. Many thanks
    Evesham E-Box (no model number on the box) Part Number is HCISTKKPCMS3-EBOXA
  • Steven Brown May 11, 2010
    Please specify the correct Model Number of your Media Center PC.
    azkeyz@fixya.com
    Wizard Division.
    Problem Solver:
  • 6 Answers
Ususally the vga or graphics drivers,lan drivers,chipset and audio drivers are enough. If you are using more than one harddrives in raid 0 or raid 1 then you will have to install the raid drivers too.
Posted on Nov 10, 2009
Installation of XP MCE won't finish
You need to set the pc to boot from the install disk. Then it should detect the failed install. Either select a new location or over write or format the disk and install.
Trying to recover from a failed install is usually far more trouble than its worth. You usually end up with a unreliable install and nothing but headaches.
Mar 23, 2010 | Microsoft Windows XP Media Center Edition...
Media center does not work on my windows xp
You should reinstall it using the installation cd because there is no downloads on the net for this.
Feb 22, 2010 | Microsoft Windows XP Media Center Edition...
Am trying to reinstall windows xp media centre ediition following reformatting hard drive. I get the message `boot manager missing. So cannot reinstall my xp media edition os.
Where and when do you see that message?
Windows need to be installed on one of the primary partitions (not logical ones). What's more - the partition they are installed on needs to be active. More info on disk partitioning can be found here.
One way to fix boot manager problems is to start recovery console - it is described here. Next you need to log into your installation and type to commands: fixboot and fixmbr.
Oct 12, 2009 | Microsoft Windows XP Media Centre 2005 for...
Is there system restore downloads to make CD for Gtwy MCE?
Well a restore CD/DVD can be created by you and kept for your use in case any crash(system) and anyway you can keep on working and save your work as we normally do. You can also create the restore CD now if you want to!............sodeep
Apr 10, 2009 | Microsoft Windows XP Media Center Edition...
Windows xp media center error occurs when trying to record programs
When that happens you usually need to backup your data, and reinstall the system to fix Windows corrupted files.
Try first doing a system restore to the most recent date before you started having the problem. If system files are damaged this will not help.
The media center is part of the WMC operative system. You can also reinstall media center alone using add remove programs, then Add remove windows components. Often that does not work, and you need to use a Windows MCE setup disk to fix the problem.
Apr 03, 2009 | Microsoft Windows XP Media Center Edition...
Corrupt files in MCE 2005 XP home
try uninstaling your windows media player then reinstaling it
it seems thers error in your media player files
hears a link 4 re download
http://www.microsoft.com/windows/windowsmedia/player/download/download.aspx
hope i was helpfull
goodluck
Mar 20, 2009 | Microsoft Windows XP Media Center Edition...
Need to download Toshiba RAID/SATA driver package for Windows XP MCE 2005 installation.
go to www.google.com put Toshiba RAID/SATA driver package for Windows XP MCE 2005 u get a link select and download or else try from www.Toshiba.com website or else from www.driverguide.com
Aug 02, 2008 | Toshiba Computers & Internet
XP Media Center: Tuner Hardware not found
go into the drvice manager
right click and select scan for hardware changes
this should popup the tv tuner and automatically install the drivers..
If that fails
turn off the system
remove the tuner card
boot the system and using the device manager scan for hard ware changes
shut down
replace the tvtuner
restatr and in the device manager scan for hard ware changes again
Also in Mce insure you have the correct imaging device and tuner device selected, this will be located in the setup options
Jul 10, 2008 | Microsoft Windows XP Media Center Edition...
Windows xp mce
Do you have tv tuners installed and setup properly? Media Center 2005 is just the software, the computer needs to have hardware tuners in it and hooked up to external antenna or cable.
Feb 15, 2008 | Philips TV Tuner Video Capture PCI Card -...
Canon Scanner n650u
Try re-installing the drivers , your crash could of corrupted the installed drivers causing your issues. I have installed Media Center on my Father in Law's cpu and found that it is very unstable at times and also many of his installed programs that worked fine under Win XP SP2 either crash frequently or wont work at all. Driver support is an issue for Media Center IMO. I would recommend if you cannot get the scanner to work after you re-install them , think about changing your OS. Good Luck.
Apr 24, 2007 | Canon CanoScan N650U Flatbed Scanner
Evesham Emedia Ebox (EBOXAPR04) PC Desktop Logo
130 people viewed this question
Top Evesham Computers & Internet Experts
Lakshman P
Anwarul Haque
Anwarul Haque
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
