How to reset my epson stylus dx5050 printer - Office Equipment & Supplies
  • maxscon Sep 23, 2008
    thanks for you help but the software does not have my model epson stylus dx5050.
  • Anonymous Dec 25, 2008
    the Epson Stylus DX5050 has no display to see init eeprom and has also no load eject button
  • 1,031 Answers
If your Epson printer needs resetting you can download the latest software Version of the SSC Service Utility (V4.3) from this link.
Install it and run it, click on configuration, select your printer from both lists ('x' is replaced by a number), close the program with the red cross. The program will run in your task bar, click your right mouse button on the icon for a menu. You can use the appropriate utility for your needs, if your printer needs maintenance due to ink pad being full, select Protection Counter and Reset Protection Counter. If your printer has locked out because you ignored the warnings and continued printing, first select Protection Counter and Clear Counter Overflow, then select Extras and Soft Reset, wait 5 minutes, then select Protection Counter and Reset Protection Counter.
Posted on Sep 23, 2008
  • 1 more comment
  • Starnley Johnwells
    Starnley Johnwells Sep 23, 2008
    hope this helps pls appreciate by rating it
    How to unlock your Epson dX5050 printer
    If your printer has stopped printing and can't be reset, you will usually see either a steady red light or alternating red and green lights and the printer will not respond. There may also be a message in your computer status monitor saying "communication error" / "printer requires maintenance".
    This is caused by built in software / firmware which counts the amount of prints you've made and stops when the protection counter reaches a predetermined limit, also giving the message that your ink pad is full. You will be allowed a certain amount of overflow prints to the protection counter limit, after which the printer will completely stop.
    There is software online that will normally reset most Epson printers that have reached this limit and is used by Epson Service Engineers called SSC Service Utility (sscserve.exe), however this does not reset the Epson dX-5050 protection counter / firmware.
    All is not lost, you can manually reset the firmware using the following sequence of actions:
    Close down all Epson programs
    Exit all Epson printer programs that may be running in the background or on your task bar.
    The quickest way to do this is to press Ctrl, Alt & Del on your keyboard and release, which will open your Windows Task Manager.
    Click on [Processes] and a list of all processes running on your computer will appear, look for any in the list that say Epson, highlight it and select [End Process]. Carry this out for any Epson programs running.
    Now to reset your printer.
    Switch off the printer using the power button.
    PRESS and HOLD all following printer buttons: Power, Load/Eject, Stop, B&W, Color and continue to hold until "Init eeprom" appears on the printer screen, then RELEASE ALL BUTTONS.
    Next press the Color button to clear the protection counter.
    Follow any other instructions given by the printer.
    If there are any further problems.
    At this point a variety of events could take place, such as the printer software may have switched to offline, the printer buffer could be holding unprinted tasks and many other hardware and communication blocks, which may still stop you continuing with normal use of your printer.
    If so, simply just;
    [Shut Down] your Computer, [Switch Off] your printer with the power button, [Unplug] your printer by removing the power lead from the back of your printer, [Wait] at least 2 minutes, [Reinsert] the power lead into the printer, [Switch On] the printer using the power button, [Start Up] your computer.
    The printer should now work as normal, but for printers with LCD displays, still follow any instructions your printer gives you on the LCD display [Printer Screen].
    hope this helps
Hi, it doesn't matter.
I have the same printer: Epson DX5050 it just stopped printing properly one day.
I changed the inks, cleaned the heads many times, tried resetting the printer, everything, nothing worked.
I downloaded the SSC software (from elsewhere as this link isn't working) & picked it automatically
picked the Epson C60 model, even though this wasn't my model, I tried using all the features
in the software, ie the resets & stuff.
It magically started working straight after.
Thanks to the original person who mentioned it.
Anon.
Posted on Jan 12, 2009
5 Suggested Answers
CoquiBiz
  • 103 Answers
SOURCE: how to reset printer epson stylus CX4500
First, install the driver on to another computer and try.
Looks at the picture for the computer having problems. If it there listed. Try make the printer properties default or uninstall and reinstall.
Posted on Jul 30, 2009
Fixe_You
  • 1800 Answers
SOURCE: need instructions for epson stylus dx5050
check this page and choose :
http://esupport.epson-europe.com/ProductHome.aspx?lng=fr-FR&data=lkuCfcvA9cyi42VCIyIYAnLNxHSpFL17&tc=5
Posted on Jan 30, 2009
aicaxz
  • 511 Answers
SOURCE: DX5050 epson printer.printer won't come on when swtched on.
Try to check the switch button at front panel board. And mounted fuse and printer main board.
Posted on Oct 19, 2009
  • 191 Answers
SOURCE: My printers is flashing all buttons and a E is
Unplug the printer from wall socket and wait a full 15 seconds. Plug it back it. Sounds simple but really is different that just pushing the power button.
If this does not work, please post back.
Posted on Nov 12, 2009
Repair epson dx5050
where i can find the manual book. Because i can not make a copy the papaer comes white out
thanks a lot
May 29, 2012 | Epson Stylus DX5050 All-In-One InkJet...
Looking for manual for EPSON stylus DX5050 inkjet printer
You can view the online manaual by clicking this link
Hope this helps. Thanks for using FixYa.
Sep 20, 2010 | Epson Stylus DX5050 All-In-One InkJet...
My stylus dx5050 doesn't recognise third party ink cartridge but i have used this type before
Maybe it did before, but if it updated, now it doesnt.
These printer have a Chip that will detect if it is Genuine or Generic. If you're using Generic, then disable ink monitor. If you find this information helpful, pls rate. me
Good Luck..............
Mar 06, 2010 | Epson Stylus DX5050 All-In-One InkJet...
My printers is flashing all buttons and a E is showing on the led screen on epson DX5050, how do i reset it or fix it?
Nov 12, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Oct 18, 2009 | Epson Stylus DX5050 All-In-One InkJet...
Epson Dx5050 blocks any printing once it has claimed that any ink cartridge needs replacing. How can I overcome this so it keeps printing with the warning, like Canon printers do, until the cartridge...
Unfortunately you cannot override this behaviour without installing a valid cartridge in the printer.
Epson printers do not have this sort of functionality as it would leave the printhead open to damage and foam clogging.
Sorry to be the bearer of bad news.
May 18, 2009 | Epson Stylus DX5050 All-In-One InkJet...
Need instructions for epson stylus dx5050
Here is guide for CX5000, that is same model as DX5000
User's Guide
Below you also find assembly instructions:
EPSON STYLUS CX5000 / DX5000 / DX5050
Jan 30, 2009 | Epson Stylus DX5050 All-In-One InkJet...
Compatable inks
The easy answer is yes, but Epson's are notorious for clogging up when you are not using epson genuine ink. Everytime I have used anything but an epson cartridge im my printer it has cost me more to clean it then if I spent the extra $ on epson ink. Hope this helps.
Jan 09, 2009 | Epson Stylus DX5050 All-In-One InkJet...
Dx5050
RX500 or DX5050?
Download a manual for the EPson site to learn how to operate printer.
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?oid=-10237&infoType=Overview
May 07, 2008 | Epson Stylus RX500 All-In-One InkJet...
Epsom Printer DX5050 Language selection
I need to change my Epsom DX8400 printing instructions to English please instead of German or Dutch. Please help
Apr 11, 2008 | Epson Stylus RX500 All-In-One InkJet...
11,406 people viewed this question
jasbo
jasbo
