Orange Light permanently on motherboard. PC won't start
I cleaned the fans of my Dell Optiplex GX260 desktop PC's fan and power supply unit. Thereafter I turned the PC on and it worked fine. I then replaced the hard disk and the PC didn't start again. When I checked inside, I observed an orange light on the motherboard. It stays permanently on but the PC won't start. HELP!
Good Day.
I'm experiencing orange light on motherboard and my PC"Dell" wont start anymore.
May i know what is the solution to resolve the problem on this?
it was just turned off accidentally while i was still on my work.
Your answer on this is greatly appreciated.
Thanks.
Mac Mundale
Posted on Feb 01, 2009
  • mac_mundale1 Feb 01, 2009
    Good Day,
    I really need the mediate reply on this below.
    thanks..
  • 778 Answers
If all you did was change hard drive
I suspect the hard drive has been installed wrong
Ensure blue or red stripe goes to the number 1 pin on M/board and the stripe goes next to the 4 pin power supply on hard drive
Posted on Sep 25, 2008
Have a Dell Optiplex 740 desktop. Power button is lit solid orange. No diagnostic lights on. Fans still blowing. Replaced power supply unit still nothing. HELP!!!!!
before replacing main board,try replacing individual hardwares like ram,processor and if still not working,try resetting the bios by alternating the jumper on the labelled CLR CMOS
good luck
Mar 28, 2013 | Dell OptiPlex 740 PC Desktop
Dell optiplex 330 flashing orange on the power botton
Try to clean the RAM and place it again in the motherboard.
May 31, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
Optiplex gx 260 steady amber light - done all things on dell website - still doesnt turn on. got a new PSU and it still has the same problem. theres a whirring sound which is the fan and the power supply...
Steady Amber Power LED generally indicative of a failed MB. Remove all Memory, Expansion Cards, peripheral items, if still same, replace the motherboard. If you get a Green LED with jusr RAM in system, then an expansion card or peripheral might be the issue. 95% sure it is mothebroard
Sep 15, 2009 | Dell OptiPlex GX260 PC Desktop
Orange power switch light Dell Gx260
Gx260-Gx280 have a known issue with the motherboard capaciators. Take a look at the capaciators on the motherboard and check if any look like they have bludges at the top particularly around the memory banks. If any of them look like this the motherboard most likely needs to be replaced.
Dec 29, 2008 | Dell OptiPlex GX260 PC Desktop
Dell PC Desktop Optiplex GX260 Doesn't boot
Open up the case and remove any add in cards and memory modules. Try to start up by adding these back one at a time until the unit stops booting normally. The light combination is not one recognised in the user manual so I am guessing you have a non-descript fault with one of your components. Be careful when you open the case as to not disturb the ribbon to the motherboard which controls the power, I have had a very long experience trying to get one of these reconnected!
Dec 15, 2008 | Dell OptiPlex GX260 PC Desktop
1. motherboards for atx form factor pc's are powered even when the computer is off, particularly if you leave the computer plugged in to wall outlet... you better do not work on you computer while power cable is still connected to both, your pc and the wall outlet..
2. I found this thread that may be helpful, it may be the motherboard may have gone bad, cmos is corrupted or something may not be seated properly...it could also be one of these: Bad CPU, BAD ram, Bad power supply.. read the thread for details:
http://www.dellcommunity.com/supportforums/board/message?board.id=oplex_other&message.id=23925&c=us&l=en&cs=&s=gen
Sep 24, 2008 | Dell OptiPlex GX260 PC Desktop
Dell optiplex won't Boot-up.. Orange light on motherboard
its going to rather your power supply or your motherboard has died, id try a different power supply first
Aug 04, 2008 | Dell OptiPlex GX520 PC Desktop
Optiplex GX260 won't boot
I had the same issue and accidentally discovered a temporary solution. Unplug the power from the back of the machine, open the case and unplug the ATX power connection from the motherboard. With the ATX cable unplugged, plug the power cord back in. When you try to turn the computer back on the power light should turn orange and fans should be spinning, with it powered on plug the ATX connector back in. That should turn the computer off. Turn it back on and it should boot fine. You can even shutdown and restart, but when the power is unplugged you will have to go thru the same process to get it back up. This sounds crazy but it worked on mine. Good Luck!
Nov 01, 2007 | Dell OptiPlex GX260 PC Desktop
Gx260 pc wont start
Have you checked the post lights located in the back of the system by where the keyboard plugs in? There are is a row of 4 lights; either yellow or green. If the systems gets stuck at a particular post location, the lights will tell where. Good luck
Aug 16, 2007 | Dell OptiPlex GX260 PC Desktop
Computers & Internet Logo
916 people viewed this question
David Payne
David Payne
