Question about Rinnai RHFE-431FAIII 16,700 BTU Direct Vent Furnace Energy Saver Heater - Natural Gas
Rinnai gas heater
My Rinnai has been functioning for a couple of years now, I cannot figure out why it intermitently makes a sputtering sound (quite loud) when it cycles on. I installed a pressure regulator and it still sputters when it turns on sometimes. Any thoughts?
I am not a plumber, but I know that if you don't clean it annually you will get build up. The way that the pipes wind back and forth through the system lends to build up on the copper piping.You may want to make sure that you get it serviced.
Posted on Sep 24, 2008
My rinani 85 heater has not been used for couple years, now I go to start and ithe burner will not fire, I can hear it make some noise like it is going to fire up but nothing?
Here is the Rinnai website to look up your model's manual, so you can go thru the trouble shooting section or call them directly for help. Your particular model # will start with either a "C" or an "R". http://www.rinnai.us/customer-care/manuals-literature
Apr 15, 2015 | Rinnai Heating & Cooling
Clicking noise Rinnai Avenger Gas heater
Is sounds like it could be the automatic ignition. If the sound only happens when you are pressing or turning the knob, I would say that is all that it is. Most gas heaters have an ignition switch under the knob. This triggers the ignition to try and spark. light the gas when the knob is depressed.
Apr 09, 2014 | Rinnai Heating & Cooling
I have a Rinnai RCE-329H gas heater that keeps turning off.
Check..for gas pressure creep.....2 lb sys....big problem...change to green hat....pig tail line.....rinnai gas valve problem being fixed....
May 31, 2012 | Heating & Cooling
Extremely annoying humming sound coming from our rinnai RCE-318H gas heater. sounds like a bearing or wheel spinning noise. please help?
The humming you hear is from the gas pressure or lack there of. Check the inline gas shut off valve, to make sure it's fully open. If that checks out OK, turn the unit OFF completely and wait five minutes, before turning everything back ON and relighting the heater. If the noise is still there, contact your Rinnai dealer for a service call.
I hope this helped you, Arthur. Thanks for choosing FixYa. Cheers!
Aug 27, 2011 | Rinnai Heating & Cooling
I have a rinnai gas heater and it has 2 broken burners and im tryiny to find new burners
Rinnai spares are available from the company through service agents depending on where you are. Let me know the model, approximate year you bought it and where you live and I might be able to find out who is closest to you or at least a number to ring.
You could try Rinnai.com.au on the web
Jul 08, 2010 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Rinnai RCE-606A vent free space heater, the Lock
Hold the lock button down for approximately one second to switch between locked and unlock. If it is locked when you turn it on you will need to do this first
Mar 13, 2010 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
When the temp drops below 10degrees our Rinnai
rinnai has a technical bulletin out on this condition #28. It instructs the technician to adjust the gas pressure. You can get a copy of this bulletin by contacting rinnai at 800-621-9419 (US). or at rinnai.us
Feb 02, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai gas water heater wont heat the water hot enough even though we have turned the thermostat up to 185.
your temp control is bad and you will have to have a tech to service the unit, contact rinnai and they will give you info on a quilified repair person,, not just any one should be allowed to work on it,, depending on the age it may still be under warranty,, they come with 5 year parts 1 year labor 12 years on heat exchanger this is on all rinnai units
Feb 18, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
No hot water - Rinnai tankless hot water heater
sounds like the water line is frozen before it gets to heater. You can take a blow dryer and try to thaw the line.You should be able to hook up a hose on the hot side of water heater. turn valve off so it wont flow into house.You can turn on hot water valve on in kitchen but you will have to thaw cold and hot line. Make sure you know where water shut off is to the house just in case a line breaks.
Jan 16, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Rinnai RHFE-431FAIII 16,700 BTU Direct Vent Furnace Energy Saver Heater - Natural Gas Logo
251 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
