Question about Dell Inspiron 5150 Notebook
Laptop freeze when in ac charger
I replace the battery and ac power charger a couple of weeks ago , since then when i run the laptop (inspiron 5150) on battery everything is fine . When i put the charger on the mouse its freeze and the monitor flickering ? ? any ideas ?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Dell Master
  • 1,001 Answers
14W Foldable Solar Charger with 2-Port USB Charger Build with High efficiency Solar Panel Cell for iPhone 6s / 6 / Plus, SE, iPad, Galaxy S6/S7/ Edge/ Plus, Nexus 5X/6P, any USB devices Chornic 14W Foldable Solar Charger with 2 Port USB Charger Build with High...
Posted on Dec 30, 2016
  • Dell Master
  • 5,568 Answers
You really should have a cheap multimeter to help in this case.
There are three possible failures; the new battery pack has a shorted cell, the charger is defective or a regulator internal to the laptop is failing.
With meter, you can check two of the three areas; the battery pack and the charger. Depending on which kind of batteries are used in the pack, if it is charged, you can determine if it is completely functional by checking contacts on the case of the pack. The most common type of battery used is the nickle-metal hydride type (NiMH) which has a nominal voltage of ~1.2 volts.  If the pack is rated 6 volts, you could measure either 4.8, 6 or 7.2 volts with the last one the most likely. If it measures 4.8 or 6 volts, it probably has one or two cells shorted, making it useless.
The charger could measure all over the map; many of them are unregulated and if they are rated at (for example) 9 volts, they could easily put out 14-20 volts when they do not have a load on them.
If those two items seem to check out OK, then the regulator in the system has gone bad. This might be on a separate board inside but to check it out, you really need some technical experience, otherwise you don't really know what you are seeing or looking for.
Posted on Dec 01, 2008
Inspiron 1525 charging problem
Try the following steps to solve it:
it of googling on the web and finally found the solution here.1 Turn off laptop.2 Unplug AC power.3 Remove battery.4 Replace AC power.5 Turn on laptop, allow OS to boot.6 Once logged in to the machine, perform a normal shut down.7 Unplug AC power.8 Replace battery.9 Replace AC power.10 Turn on laptop, allow OS to boot. The battery should once again be charging as normal.If it can't still resolve this problem, try a new laptop charger or repair your laptop dc jack.
If you plan to be on a budget for your dell 1525, you may try the following third party charger:
Replacement Dell Inspiron 1525 AC Adapter 65Watt 19.5V 3.34A
Oct 20, 2012 | Dell Inspiron 1525 Laptop Midnight Blue
I own an Acer Aspire 8930G, and as of a few weeks ago, it will not power on. At first I thought it was the AC adapter at fault, as the wire on the side that is inserted into the laptop had a small cut in...
This is a long shot but take out the battery and leave it a couple of hours then replace and place it on charge overnight then retry next day, you have maybe already tried that, the only other thing I can think of is get a multimeter or someone who knows how to use one and check that the voltage is kicking out 19v DC from the charger
Mar 02, 2011 | Acer Aspire 8930G Laptop Charger...
It turns on for a few seconds then shuts off
Since you have already replaced the ac adapter. The problem is still there. the most likely cause of the failure is bad motherboard. Remove the battery from the laptop and disconnect the ac adapter . Press the power button for 10 seconds. Reconnect the ac adapter and try powering on the system. If the same doesnot work
Try the steps in the link
http://tinyurl.com/yd842up
Thanks for using Fixya
proton
Mar 15, 2010 | Dell Inspiron 1318 Laptop Computer PC...
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
Laptop won't turn on, battery and power lights keep blinking
Looks like you are having a no post situation, generally a failed motherboard. Replacement motherboards are available on Ebay for around $100
Apr 06, 2009 | Dell Inspiron 5150 Notebook
Dell inspiron 6400-runs slow on AC power but not on battery
uninstall any energy management software provided by dell and then check.if the issue is not resolved then the issue is with the converter board as it is heating up.
Jan 29, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 system responding very slow on ac adaptor
FIRST REPLACE YOUR BATTERY, THEN ALSO CHECK VIRUS WITH AN UPDATED VIRUS CLEANER.
Nov 20, 2008 | Dell Inspiron 6400 Notebook
Mouse problem when running on ac power
Might be a driver glitch. Try uninstalling the drivers for the touch pad, some times refered to as synaptic pointing device, from the devic manager, then plug the power supply in and reboot. The machine will find the touch pad, and reinstall the drivers. Try this and let me know.
Aug 15, 2008 | Dell Inspiron 5150 Notebook
Can't charge battery or run off AC
You may have a problem in the DC charge circuitry. These parts are located on the moatherboard directly and can't be bought separately and repaired. You must send your Dell to a specialised service to have it fixed by them. Sorry, I can't see no other way for this problem to be solved.
Jan 20, 2007 | Dell Inspiron 5150 Notebook
Dell Inspiron 5150 Notebook Logo
168 people viewed this question
Alun Cox
