Question about Visioneer OneTouch 8600 Flatbed Scanner
8600 scanner won't power up
My always reliable 8600 scanner refuses to power up. It won't come on at all. Far as I know, it hadn't been moved, just one day it quit working. Could this be a power cord issue? I tried plugging it into different outlets and it still won't come on. I'm running Windows XP and haven't had any issues with it previously.
  • doughall Sep 25, 2008
    Same problem, no power up, driver still ok as confirmed - I think the problem is a failed lamp, if so seems like a dustbin job!
  • 490 Answers
Pls check the power adapter. If you have a multimeter, pls check the output voltage of the power adapter.  S. Mohan
Posted on Feb 06, 2009
How to print labels
Use Avery Label sheet.
Set correct paper size on Word and the Operating system.
Use label from Sheet feed tray only.
According to the printer specifications for the Officejet 8600 Pro Plus, the following label sheet sizes are supported;
HP Officejet Pro 8600 All in One Printer series N911 Manuals
Mar 15, 2016 | HP Officejet Pro 8600 Plus e-All-in-One -...
I have a Spirit of St. Louis turntable that won't turn.
This model of turntable automatically stops when the needle reaches the center(the end) of the record. The motor should turn back on if you move the arm to the far right of the player, past its resting spot.
May 02, 2013 | RCA Spirit Of St. Louis Radio/Cassette/CD...
I have a 2006 Pride Maxima. Problem comes and goes.
Hi Alex. Does this problem happen when you first turn on the scooter, or does it happen while you are riding the scooter.
It might possibly be that the speed lever ( wig wag ), is not correctly adjusted, or is worn.
Test the lever is correctly adjusted by sitting on the machine with the key on. Slowly move the lever in the forward direction, until you hear the brake click. Take note of how far the lever moved. Now move the lever in the reverse direction until you hear the brake unit click. The distance the lever moved, should be the same in both cases.
Also while you are driving your machine try moving the ends of the lever slowly up and down. If this makes the machine change speed erratically, then you probably need a new throttle pot, or speed lever assembly.
Does your machine show any fault codes or flashing LED's.
Hope this helps. Neil.
Jul 09, 2010 | Pride Luxury Line Maxima Scooter - 4 Wheel...
Engine Calibration?
If it is a 1500 this is a half ton and will be under 8600 lbs.This info is on the drivers door.There is a sticker that tells you the GVW.As for the throttle actuator controls.I am not sure if the scanner wants to know if it has electronic throttle or what.Just look at the gas pedal and see if it has some wires going to it or if it is just a normal pedal.I don`t believe they had electronic throttle controls in 03 yet but I`m not sure.You can try one or the other depending on what you are trying to do with the scan tool.Just get codes or something else.Hope this helps.Good luck.
Apr 06, 2010 | 2003 Chevrolet Suburban 1500
My Visioneer 8650 flatbed scanner with auto document feed gives a message when I try to scan a document, telling me to move the switch on the bottom from the "locked" to "unlocked" position. The lock is...
Actually a very common problem. Try the following:
1. Power down then re-power up the scanner.
2. Try slightly moving scanner. Sometimes a small change works to fix.
3. Change one of your scan setting to flatbed scan (not adf). Do a test scan under this setting. This will usually kick start scanner unit to unlock.
4. Last resort, by does also work...give it a medium slap on the side, sometimes unjams the scanner light.
5. Super last resort, power down over night, it almost always works the next day. (could be that lock up is heat related to scan lamp, dont know but just a guess).
Excellent scanner, so worth the effort to try these fixes.
May 22, 2009 | Office Equipment & Supplies
Scanner is locked
Pls try locking and unlocking when power is off. S. Mohan
Feb 05, 2009 | Visioneer OneTouch 8600 Flatbed Scanner
VISIONEER FLATBED 8600 SCANNER
http://scanner-drivers.com/companies/1122.htm
try the thrid one down is this your scanner driver
riz.
Nov 11, 2007 | Visioneer OneTouch 8600 Flatbed Scanner
Visioneer OneTouch 8600 Flatbed Scanner Logo
136 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
TomHighRidge
Level 1 Expert
Mark Gough
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
