Question about Kenmore 63252 Microwave Oven
Grinding noise from turning platter mechanism - Kenmore #63252
I have the 63252 model. It makes a horrible griding noise as the platter turns. It's enough to set my teeth on edge! Any ideas how this can be fixed? My husband is pretty handy with most things but is uncertain where to start with a microwave. Thanks.
  • Kenmore Master
  • 9,098 Answers
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Posted on Sep 25, 2008
I have the 63252 model....When the microwave is turned on to cook, it runs, there is no heat.... does this microwave have fuses of any kind....
Posted on Feb 26, 2009
Why does my Kenmore model 721.63352300 turn on when door is opened ?
The most likely cause is a defective door switch, there are usually a few to protect critical area's of the microwave oven, if you have a digital meter I can walk you through the testing stage.
Sep 02, 2012 | Kenmore 63252 Microwave Oven
Our Kenmore microwave turns on, makes noise but has no heat. Any suggestions?
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 30, 2010 | Kenmore 63252 Microwave Oven
63252 / 63259 1200 Watts Microwave Oven: Turns on but,wont heat up...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hhgds
May 07, 2010 | Kenmore 63252 Microwave Oven
Purchased microwave in 2005, just stopped heating and now its making a loud noise
if the loud noise is like a vibrating noise then it sounds like the high voltage diode.
Mar 23, 2010 | Kenmore 63252 Microwave Oven
Kenmore 63252 / 63259 makes buzzing noise during use from control panel side of microwave
transformer probably has a loose fin or 2, it should still work fine but will get louder, I don't think its worth buying a transformer for that mw
Feb 06, 2010 | Kenmore 63252 Microwave Oven
Microwave turntable.
Is that the only thing that doesn't work? If so it could be a coupler or a belt, possibly the motor it self.
Sep 17, 2009 | Kenmore 63252 Microwave Oven
Kenmore microwave model 721-63252301 - no heat turns on - but nothing is getting hot
we are going to try to find a fuse and replace that or just buy a new microwave
thank you
Jun 05, 2009 | Kenmore 63252 Microwave Oven
Your oven may have separate fuses for the magnetron and the electronics so I suggest you pull the plug, remove the back and look for an accessible fuse holder. Allow the unit to stand unplugged for at least several hours before removing the back panel as there are components inside that can carry a nasty charge for hours.
Feb 26, 2009 | Kenmore 63252 Microwave Oven
GE Spacemaker XL 1800 - turntable issues
check capacitor and motor drive of turn table.
Jan 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
The turntable makes grinding niose when engaged
That model number doesn't ring a bell. Is that right? Is it foreign?
Chances are the coupler and/or turntable support will be damaged or warped.
Also on some brands, the "packing" (often a rubber grommet) must be replaced.
Oct 17, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore 63252 Microwave Oven Logo
251 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
