Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Motokrzr The phone is less than a year old and worked fine until a couple months ago and it started losing charge and could only talk for less than 5 minutes before phone went dead. Installed a new battery an it did fine for a month and now will show full charge but phone starts beeping low battery and goes dead within one minute of talking. Is it battery again or maybe something in phone?
  • Anonymous Mar 21, 2014
    MY zte source phone (had it for less than 2 months) was fine until the screen turns off and on.
  • 21 Answers
Well it sounds like a combo of both. Definitly get the battery replaced again. The phone itself probably needs new software. take it your service provider's corp store to get the software updated.
Posted on Sep 24, 2008
Temp on screen rises & flash high temp.
Hallo
The compressor winding's could also be faulty.
regards
May 19, 2016 | Frigidaire Refrigerators
My battery does not hold the charge, i will charge it for 24/hour and it only last 5 minute, why is that, iI buy this product for wife when went to Iraq, and when i talked ton her on the phone three months...
NiCad batteries have this problem when they are recharged frequently after being only partially discharged. This is also the case when the batteries are left in the charger continuously - even if the charger is described as being "automatic". I have old 12v batteries that I have been using for 20 years, but I only charge them for a few hours, and only when they have run down enough to be useless. I prevent leaving them too long in the charger by using a timer that cuts the power to the charger after a couple of hours. A couple of years ago I bought new drills and chargers, and believed that the chargers would be automatic and so could be left plugged in. Those batteries only lasted a couple of years, while the old ones are still going strong. I now use the timer for any of these chargers, automatic or not - but I had to buy new batteries first. good luck, Al K
Jul 29, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
I bought a replacement hp battery for my HP Pavillion zv5000 a year ago. It was working fine for about 6-8 months. Then, it seemed to stopped storing energy even when the charging light stopped and...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Feb 08, 2011 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
My 1996 suzuki bandit will not come on what do I do ive checked the battery and the fuses they are fine? it was working fine until a couple days ago
is the battery more than 12.5 volts if its not its no good, get another battery...if you dont believe me try and push start it with the key on if it starts and runs kind of crappy at first its because the battery needs to be charged up..nothing that a good twenty minute freeway ride should fix up if the battery is less than two years old.
Aug 10, 2010 | 1996 Suzuki GSF 600 S Bandit
Lg prada ke850 black screen
My Phone has done that a couple of times before. It would slowly start turning off more & more often then it wouldn't turn on with the same problem as you.
Turns out it was the battery as it was a couple of Months old & was out of warranty.
Aug 15, 2009 | LG Prada KE850 Cellular Phone
The green is taking over all the color on the tv
March 14, 2009
I have the same TV which had the same issue ( green in picture ) - back on 10/2007. I called Sony. They had their technician replace the optical box ( factory defect ). There was no charge for the repair even though TV was out of first year of warranty. Call Sony.
Sony Repair (866) 282-7412
Mar 12, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Jabra and Krazor problem
on jabra try holding vol butten and talk swich hold it till it blue light stars continue and then try surching in ur phone reply me
May 18, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Phone Not responding
I'd suggest removing the battery and putting both the phone and the battery in the fridge over-night. If it works the next morning, this might suggest a thermal-fault in the memory and I'd advise keeping it in the fridge when you're not using it. Otherwise, you could seek help at your local phone store or you could send a email to sanyo asking for help and alerting them to a possible flaw in the phone.
Hope this helps, TechnoWolfy.
Sep 11, 2006 | Sanyo MM-8300
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
209 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
