Question about Toshiba 2060 Copier
Copies too dark
I have an older Toshiba 2060. The copies come out very dark even with the setting on as light as it will go. I moved the wires cleaners in and out a few times but it did nothing. What else could it be?
Clean optics
Posted on Oct 14, 2008
    An user who is expert in 3 categories / brands.
  • Toshiba Master
  • 1,362 Answers
1-drum needs changing
2-wires needs changing (the cleaning doesn't do anything for it)
3-developper needs changing.
Posted on Sep 23, 2008
  • doctor666 Oct 27, 2010
    i have the same copy machine. it shows a dark line on the side of every copy i already clean it up but it didnt work please help
Toshiba 2060
i would buy new lazor toner 1st cartridge to see if yoru s bad or out
Jan 19, 2008 | Toshiba 2060 Copier
I have black strip running top to bottom of copy. Machine has 65,520 copies on the counter
What type of copier? A professional grade or SOHO AIO? Check the glass where the copies take place, including where ADF copies, make sure there are no debris. If you can look to see if there are any debris or faults in the scanner assembly. If that's ok it could be many things. If it is a higher end copier it could be as simple as dirty corona wires or as bad as a worn drum.
Dec 18, 2009 | Toshiba 2060 Copier
Toshiba 2060 Photocopier prints copies that are a bit too dark.
restart the copier while holding down the "0" and "5" keys. you will now be in service mode. enter "5" and press "start" key a number should show up in the display. this is the exposure value - how dark or light the copies will be. 5 is the automatic exposure setting. around 128 is the normal value. the larger this value the lighter the copies are - the smaller the value the darker the copies.
Enter a new number (exposure value) and press the "interupt" key to save the value. Restart the copier and check what the copies look like. Keep adjusting until it looks good/better.
Mar 26, 2009 | Toshiba 6560 Copier
Have toshiba 2060 copies are coming out with gray and blk stripe
Hello sir; Everything you can clean but drum, that's most sensity part, UNTOUCHABLE , I believed you damaged the drum already, go change one meanwhile change cleaning blade too.
Mar 09, 2009 | Toshiba 2060 Copier
Copies have gray background.
Have you had the optics cleaned resently? If not Iwould start with that and make sure you have the copier unpluged and don't forget to clean the two mirrors under the Black Box/cover. It could also,mean that you need a new OPC drum and blade.. It depends on how maiy copies are on the copier and drum...
Sep 04, 2008 | Toshiba 2060 Copier
Black line at top of copies
You could have a scratch on your drum. If you take a look at it inside the machine, see if it appears on the drum.
Jul 31, 2008 | Toshiba 2060 Copier
Toshiba 2060 Edges of copies cut off
One the cassette drawer, there is a key that indicates the paper size. It is notched in a way to tell the machine what you have loaded. These notches engage a set of switches in the front of the machine, visible when the drawer is pulled out. What happens, is the friont of the drawer moves. It is screwed down in two places I think. Loosen the screws, and align it properly. It should be obvious, because you need to align it with the largest line in the index set. The front drawer plate is adjustable is what I am trying to say. The switches will engage properly, and all should be well!
May 17, 2008 | Toshiba 2060 Copier
hi im jules_09.his there any error code?if no error code try to adjust the voltage on the exposure lamp,if that does not work can you send me a sample print at so i can see the print .
Oct 14, 2007 | Toshiba 2060 Copier
300 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
