Question about GE DSR-2000E
Celestial dvb8800hd unit performed ok for months and now will not go out of standby mode
  • r_rae Feb 28, 2009
    Our Celestial ddvb8800HD set top box worked well for months, now won't work at all, it just keeps going into standby mode. We have lost the installation instructions and we are not able to get it up and going.
    Jo
Problem solved by looking past the inseparable remote control and indexing the channel button on the unit. Fiddling with remotes can be a real waste of time.
Posted on Sep 25, 2008
What does it mean when your tv states standby and you cannot turn it on or off with the remote control?
How to Fix a Sony Plasma TV With a Standby Problem ...
smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
A standby mode problem on your plasma TV can result in the TV being stuck instandby mode, ... You can troubleshoot a standby mode error by performing a power cycle or restoring the TV to its factory settings. ... Turn the television on. ... What Does It Mean When My Rumor Touch Says the Camera Is in Standby Mode?
tv on standby mode cant get it off - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-1676193/standby-mode.html
Dec 27, 2015 | Televison & Video
Code ck sr tuner no sound
Hello
So many improper commands send to the unit may make its system and memmory to be confused, and will not operate properly. Just reset the unit to factory settings, and try.
To reset the unit to factory default settings, so the following
[1] Press STANDBY/ON on the front panel to set this unit to standby mode.
[2] Press and hold TONE CONTROL and then press STANDBY/ON to turn on this unit. The advanced setup menu appears, in the front panel display.
[3] Press PROGRAM buttons to select PRESET.
[4] Press STRAIGHT repeatedly to select RESET.
[5] Press STANDBY/ON to confirm your selection and set this unit to the standby mode.
This procedure completely resets all parameters of this unit including SET MENU parameters. However the advanced setup menu parameters will not be effected. The intial factory paramenters will be activated next time when you turn on this unit. To cancel initilization procedure at any time without making any changes, press STRAIGHT repetedely ot select CANCEL and then press STANDBY/ON.OK.
Apr 03, 2011 | Yamaha RX-V463 Receiver
I have one Amp;SR4003.if i on the amp;its showing standby light only.which stage defective.pls give me ans; Regards ...
hi,
check the power supply voltages 5v, +-15v. also check the power on relay driver side. also check is there is any dry soldering in power supply stage. check the output amplifiers is there is any transistor faulty. for any further assistance feel free to contact through fixya.
ok
Dec 23, 2010 | Marantz SR4003 Receiver
Celestial HD Digital Television Receiver DVB8800HD
It appears that the default output is set to component video by the manufacturer.
connect it to a suitable TV and change the output to composite and you'll be able to use it.
Jul 25, 2008 | Televison & Video
Normally, there are 2 ways to hook these devices up. One is the component cable that has 3 colors, red white and yellow. these color codes match an aux. input on the TV (or vid1 or vid2) You need to change the TV input to whichever you used by the remote or maybe under Ch2 (4,3,2,vid2, vid1, aux,111,110,etc) The other way is to use the round 4-5 pin S-video instead of the yellow jack, that is self explanetory. The 3rd way and this depends on your TV and receiver is to use the HDMI, composite or DVI cable connection. These are only for Hi def players and will be either a large multi-pinned computer type plug, 5 colored/lead "octopus" cable, or a smaller D shaped high density cable with the row of contacts inside the plug. In any case you need to tell the TV which input you are using.
Once you get the TV to show a picture of the receiver, then you autoprogram the receiver with the remote under setup or other menu.
Jul 24, 2008 | Televison & Video
Celestial split system air conditioner
I am a repair man and have had this problem quite a few times, check that the remote is set to heat and 30 degrees.usually a symbol like the sun,very similar to cool easy to mix up.If the a/c is set to heat the indoor fan will not start till outdoor unit has heated coil.
Jul 16, 2008 | Heating & Cooling
Celestial tv no remote
We have a Celestial TV and the remote has broken - just keep the tv on standby and when you want to turn it on hit one of the volume buttons.
Any ideas on where i could get a new remote - Do you know who the manufacturers of Celestial are?
Jun 28, 2008 | Televison & Video
Stanby mode
Goto control panel, performance and Maintenance, Power options, Power options property, hibernate tab, enable,apply, advanced tab, select how you want to stand-by or hibernate unit, apply.
Mar 17, 2008 | Toshiba Satellite A205-S4617 Notebook
GE DSR-2000E Logo
863 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
