Hi There, Mine is Windows Xp.I use Nero 8.But,I don't understand why Nero StartSmart doesn't open,after display of the splash screen!!! Please Help Me!!!!!
basically you need the direct 9ocx on your computer. Go to google type in "direct 9oc x" free downloads will pop up on the screen. ONLY DOWNLOADED CORRECTLY IF IT ASKS TO RESTART YOUR COMPUTER. then the program will run correctly!!
this is a 2002 laptop, 7 years or more old, are the ide controllers for the hard drive on the...
(More)
this is a 2002 laptop, 7 years or more old, are the ide controllers for the hard drive on the motherboard on a attached printed corcuit board[pcb] or are they built into the 20gb hard drive which came with the laptop and should the cmos battery be 7.4 volts as new cause the cmos clock is not keeping time and when i checked cmos battery the voltage was 3.4 volts. With this ambios and intel 815em chipset i am told that the 20gb hard drive is the largest hard drive i can use with this motherboard, is this correct,please advise on these issues.
Has anybody configured Reliance Datacard - USB on ubuntu 9.04? Kindly give me step by step procedure...
(More)
Has anybody configured Reliance Datacard - USB on ubuntu 9.04? Kindly give me step by step procedure for configuration? Regards, Moiz
How can I program the percentage keys minus from the subtotal? It works when I'm ringing up 5 of the...
(More)
How can I program the percentage keys minus from the subtotal? It works when I'm ringing up 5 of the same items, when I pressed 5 different plu's, it's only taking percentage off the last item.
