Question about V, Inc. VIZIO RP56 Rear Projection Television
Black box on TV Screen.
We have an older tv that works perfectly except when "The Today Show" is on. As soon as the program begins at 7:00 a.m., the screen of our tv gets a large black box on it covering almost the entire screen. The audio still works. When "The Today Show" is over, the black box goes away. Sometimes there is jibberish that is typed at the top of the box. What could this be? M
  • 2 more comments
  • Anonymous Dec 28, 2008
    Same thing occurs on my Vizio TV when ESPN Sportscenter is on. Any thoughts?
    Same thing occurs on my Vizion TV when ESPN is on???
  • Anonymous Feb 21, 2009
    same thing is happening on our television during sportscenter.
  • ed1die Mar 15, 2009
    I have the same problem. The only thing that I've tried that "fixes" it is turning it on and off. ...I'm sure that is not the best fix for the problem, but is a temporary fix.
3 Suggested Answers
mbelectronic
  • 147 Answers
SOURCE: Black Screen, Audio only , TV will not turn off
back light out,panel defective.no fuse will correct your problem.panel is bad.
Posted on Aug 19, 2009
Testimonial: "Excellent in help..not the answer I wanted to hear, but on the money. Thanks MB electronics"
  • 84 Answers
SOURCE: i had a vizio 42in plasma repaired at a tv shop
Your plasma set basically had the gas in it escape. Its pretty much worthless at this point. I would definitly take it up with the repair company and demand a replacement tv.
Posted on Jan 07, 2010
I have a Hisense 50M700UW TV. It works perfectly except for one problem. When we try to watch netflix through out Fetch TV box the sound comes out as a high frequency unintelligible mess.
You cannot hot swap HDMI connections. First thing to try is to power off and unplug all the devices from everything. Then make the connections to the Fetch and the Television, Then power to the Fetch, then the television, then turn on the Fetch, then the television. There is also a chance that the HDMI cable is an older one and needs to be replaced.
Feb 17, 2017 | Hisense Televison & Video
Why does the screen shut down after 1 sec while sound continues
It sounds like bad luck to me. You cannot change any settings on a TV by connecting a computer to it. In theory you can damage any monitor by setting the screen resolution of the computer higher than the monitors maximum res. The Sharp 26" has a resolution of 1366 x 768 (1080i) so (again in theory and I have never seen it happen) if you set the output to 1920 x 1024 (HD - 1080p) it can kill the screen. Perhaps this is what has happened. You will need to take it to a Sharp service centre.
May 29, 2014 | Sharp LC-26SD1E 26 in. LCD Television
Picture Size
Keep in mind that not all programs and show are in widescreen format. When set to normal, you will get those black bars on the sides because the program is sized for the older TV's. Some TV's will have a zoom option, but that will cut off some of the top and the bottom of your picture.
Until everything goes widescreen, you are stuck in normal with those black bars or widescreen with the fat people.
I hate distortion in my TV image, so I am perfectly fine with my TV on normal.
Good luck.
Jul 14, 2010 | Philips Magnavox 42MF521D/37 Television
Blank Screen
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Sep 18, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
My Sharpe Aquos TV screen stays black even when switched on!
Call up Sharp, if you are part of the AQUOS Advantage Program, you get FREE in home service along with the repairs for it.
They'll give you a case number, set you up with a technician and BAM!
I called on a Wednesday and got an appt for that Saturday for the technician to come to my house.
I doubted Sharp alot less after that.
Aug 28, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Bad/No reception problem on older tube tv worked good yesterday
have your tuner check for any cold solder on pins.
Jul 29, 2009 | Televison & Video
Everything on the TV works EXCEPT live TV.
Please clarify a few things. Are you using cable TV, satellite TV or a TV antenna? If cable, are you using a set top box (and is it powered on) or does the TV convert the cable info. If satellite, is the set top box powered on? If off the air (antenna TV), can the TV receive the new digital signals and if not, do you have a digital converter box between the antenna and the TV?
Jun 04, 2009 | Toshiba REGZA 47HL167 TV
Screen goes black tv stays on. Turn off and on and TV's fine.
Mar 20, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
My tv is on but the screen is black except for spuratic flashes
i have the same problem, yesterday my tv stops, today I was on the internet trying to find something , I find a Phone number so you can call and explain what is your problem . It works. 1 800 726-4405 or a web page akaiusa.com try it.
Jul 05, 2007 | iLO V27DMBX Television
Vcr freeze frames tv programs when turned on
No nO NO the cable out from the cable box goes to the input of the VCR and the VCR output goes to the TV connection. Good Luck
Jun 05, 2007 | Panasonic PV-V4525 VHS VCR
Televison & Video Logo
231 people viewed this question
Top V, Inc. Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
rostit
Are you a V, Inc. Televison and Video Expert? Answer questions, earn points and help others
