Question about Toshiba 2060 Copier
Toshiba 2060 problam marca disposer leno comop resolverlo.
  • Cynthia Heimsoth
    Cynthia Heimsoth May 11, 2010
    I'm not quite sure I understand the question. If something is full and needs to be emptied, you will need the help of a Toshiba technician (sorry!) because for the most part the things that are full will make a mess if you take them out wrong.
  • 4 Answers
Vacuum the cleaning unit, clean the toner deposit of used toner, check in the cleaning unit that the screw the remove the used toner to the deposit move to the front and rear free, when the deposit of the used toner is full this screw push a switch to prompt the indicator on the machine toner collection box is full.
Posted on Sep 07, 2009
  • 92 Answers
Bota la botella que esta jenna de toner cuando avre la puerta y ponle una nueva
Posted on Jun 28, 2009
My toshiba 2060 copier easy printing but print paper some line missing please or broken,please solved my prob.
if white lines appear in your toshiba 2060 inaccuracies.
almbres replace the corona charging and transfer, do not forget to check the development unit if turevelador is too old replace
Feb 25, 2015 | Toshiba 2060 Copier
How do I clear the 'dispose of used toner' error message?
Clean well the toner box or better replace with a new toner box.
Sep 24, 2014 | Toshiba Dp3580 Dp2570 Dp2460 3560 2060...
Please, I bought a used toshiba 2060 copier, if I put it on this is what showed on the screen "SLUIT ZIJKLEP BENEDEN" could you please tell me what it means. Again could you show me how to change th
OOOOH NOOOO! You wasted your money sorry to say. The 2060 is an analog that is obsolete, a good majority of the parts in that machine are unavailable. I would cut your losses.
Jan 22, 2013 | Toshiba 2060 Copier
Partlist to toshiba 2060 copir
Toshiab 2060 copir Adjust commant guid
Apr 13, 2011 | Toshiba 2060 Copier
My company keeps their copier till it absolutely dies. The top lid/cover needs to be replaced. Where can I find this replacement part?
Depending on what part is bad or broken, you can get your parts from precisionroller.com
Over to the upper right is a search box. Just put in toshiba 2060 platen cover and you will get the cover and the cushion. If you Hinge is broken which is more common just search for Toshiba 2060 Hinge and you will find those.
Good Luck and Thank You for using Fixya.
Sep 02, 2010 | Toshiba 2060 Copier
Can you get an adaptor for a usb port to print from your computer? Also does this scan from computer? Renee' Weiss 865-680-5564 realtyplus.renee@live.com
If you are refering to a Toshiba 2060 being able to print or scan....the answer is no. Toshiba 2060 is an analog copier.
Oct 13, 2009 | Toshiba 2060 Copier
Toshiba 2060 problem with casette
If the cassette makes a popping noise when first inserted (as it tries to lift paper to feed rollers) then the lift motor drive case is cracked / damaged....one of the gears may be also damaged.
Sep 09, 2009 | Toshiba 2060 Copier
How to change developer on Toshiba 2060 copier?
Changing the developer is a procedure for service technicians to do.  You might want to ask that question on copytechnet.com.  There are Toshiba service technicians on that can help you with that.
Sep 13, 2008 | Toshiba 2060 Copier
135 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
