Television fuse is exploid when turn the power
  • Themba1 Dec 08, 2008
    fuse exploid when turn power on
    Sergeant:
  • 300 Answers
Replace the fuse.
azkeyz@fixya.com
Electronic Engineer
Wizard Division
Posted on Sep 23, 2008
Tip
How to root a mytouch slide 3 g
Following these steps from beginging to end will allow you to full obtain root and flash a new rom from begining to end. Follow each step and you will be good.<br /><br />Easy root guide for the MyTouch slide currently any version downloads at bottom<br />Make sure before starting that the device has atleast 50% battery charge.<br />Go to C drive on pc and make a new folder we will call root<br />Copy then all the files from the zip into that folder.<br />__________________________________________________ _________<br />not required but you should also copy a rom that you want to use the the root of the sdcard on the device too then I have included teamfenix 1.7.1 as is a stable 2.2 android rom but you can use anyone you want.<br />__________________________________________________ _________<br />First we will need to get some files to the device would be easiest with a following settings already done:<br />settings &gt; applications &gt; development &gt; USB debugging (check mark here)<br />settings &gt; connect to pc &gt; charge only<br />settings &gt; wireless & networks &gt; wifi unchecked (important)<br />settings &gt; sound & display &gt; screen timeout &gt; never<br />Now connect device<br />Then start the command prompt and uses these commands to move the files we will need<br />cd C:\root<br />myroot (just allow to continue we covered the steps in it already)<br />Will take a few minutes for that to copy everything over to the places on the phone where we need them. will look like is frozen on ESPRIMG.zip that is normal don't interupt it just let it go.<br />when done we are now ready to actually get root and allow phone to let us get a recovery on there we can use with a few more commands<br /><br />commands_______ things in () don't run just memos<br />adb shell<br />(should now see a $)<br />cd /sqlite_stmt_journals<br />chmod 0755 exploid<br />./exploid <br />(will have initated the loop hole to get root)<br />(at this time go to settings and turn wifi on and then back off before continuing)<br />./exploid<br />---The password is : secretlol<br />(You should now have a # instead of a $)<br />cd /data/local<br />chmod 04755 *<br />/data/local/flash_image misc /data/local/mtd0.img<br />__________________________________________________ _____________<br />ok now we are set to apply the engineering build to get a custom rom<br />Turn off the device<br />Press and hold volume down and then power up and hold both<br />let go when see the 3 skateboarding androids<br />give the phone a minute then will read the moded file on card<br />when is ready press volume up to apply this update<br />--- This will take a while just let it run<br />WAIT - when done it will ask you to reboot DON'T<br />press volume down for no<br />then back on bootloader screen press volume down once to highlight recovery and select with power to boot recovery<br />on the recovery you will have a device with a triangle<br />hold volume up and power for a second together<br />volume down and power to select for apply update.zip<br />and you will then be loaded into the clockwork recovery and will beable to flash the rom of your choosing from sd card.<br />You can use touch pad not to scroll down and select install zip from sd<br />select choose zip from sdcard<br />find your rom and apply<br />You are now rooted enjoy<br /><br />needed files - <a href="http://www.4shared.com/file/J6i52nwy/slideroot.html">http://www.4shared.com/file/J6i52nwy/slideroot.html</a>
on May 21, 2011 | Cell Phones
Why is my oil filter keep exploiding off???
might be wrong filter. check the one you took off.
ACDelco pf47 Fram 3387
Mar 15, 2013 | 2000 Pontiac Sunfire
I believe my tv was involved in a power surge. red/green blinks
Hello:
U just may of blown fuses on the power supply of the television if you are sure it was a surge. If u can open the unit check all fuses on the power supply for open coniditions. If the future is a good Ideal to use a surge proctector as this will protect your equipment. Make sure power is off and remove AC power to check fuses. Sometimes just removing AC power for a least 2mins will reset the unit.
Jul 02, 2010 | Panasonic PT-50LCX64 50" Rear Projection...
Oki television does not turn on
Hello.
Yes it is possible that something blew the fuse. If you have the fuse replaced, and it blow's again, then something in the power supply is shorted, causing the fuse to blow. Your best bet is bring it to a shop that gives free estimates. Just make sure that it is a reliable shop. Hope this helps. Ron
Sep 08, 2009 | Televison & Video
Rca L32WD22 won't turn on...is there a fuse? If
Hello
did you see the standby light? if no you have problem in main power section maybe the fuse is blown you can locate the fuse at the power main board, or if the standby light is light up the problem is the inverter power supply and this section is need to diagnose to find the defective parts...
Angel
Thanks...
Aug 02, 2009 | Hyundai HLT-3272 32 in. LCD Television
Pioneer 50 inch projection tv won't turn on
I only fine 5 fuse where is the 6 fuse locate? Please help I found the 5 on the power board... is the 6 fuse somewhere else not with the power board?
Mar 15, 2009 | Pioneer SD-P50A3Q 50" Rear Projection...
MY will do not turn on. When I MAIN POWER TURN
take off the lower rear panel and check the fuses ther is about 6 fuses to check. make sure it's unpluged first.
Feb 17, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Television has no power
check the fuse. The person i got mine from said it was dead. i took it home opened the back and the fuse is very obvious replaced it with a slo-blo fuse and its back to normal!
Dec 15, 2007 | Panasonic CT-32SL14 32" TV
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
