Dishwashers Logo
Posted on Sep 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My dishwasher completed a wash today but when I turned it on to do a second wash it will not come on. There is no problem with the power supply as the on light is green.
Anonymous
Level 3:
  • Master 706 Answers
  • Posted on Sep 23, 2008
Anonymous
Master
Level 3:
Answers
706
Questions
0
Helped
313272
Points
1939
Try unplugging the power cord or switching off the circuit breaker that feeds power to it for a few minutes and see if that clears the control logic after reapplying power.
1helpful
LG dishwasher LD1419W2 which would not fill -error code IE. I replaced the inlet hose complete. Now it has the error code FE and the water overflows onto the floor when in wash cycle. Peter
Try resetting by:
turn off dishwasher
trip circuit breaker to remove all power to unit
wait 30 seconds
restore power
start dishwasher
the drain pump should start and drain all water then start a cycle. Good luck
tip
How to troubleshoot a Dishwasher when problems developed
A dishwasher can make life easier—it reduces the hassle of hand-washing and keep your kitchen countertops and sink free from the clutter of dirty dishes—but if your dishwasher stops working properly, don’t panic. There are several things you can do to get it working properly once more.
Following are the preliminary steps to take before tackling common dishwasher problems. After you've looked over these points, be sure to follow the various links to dealing with specific dishwasher repairs.
1) Unplug the appliance from its electrical receptacle or shut off the circuit that powers it.
2) Turn off the water supply valve that routes to the dishwasher beneath the sink before disconnecting or working on the dishwasher’s water supply.
3) Don’t work inside the dishwasher immediately following a wash cycle; various parts, especially the electric dryer element at the bottom, may be too hot to handle .
Once you’ve completed these preliminary steps, you’re ready to tackle the problem at hand.
on Sep 03, 2010 • Dishwashers
KitchenAid KUDS30FXSS Dishwasher won't complete cycle
Press the Cancel/ Drain cycle for a few seconds. The dishwasher should reset itself. See if this makes any difference. Also first turn the mains power to dishwasher off and back on.
Kenmore dishwasher water inlet valve replacement
Turn off power to dishwasher at the breaker or fuse panel.Turn off water supply usually found under sink. Remove the front kick panel and remove water supply line from the valve,remove clamp to hose on dishwasher and remove hose. Remove electrical connectors from the inlet valve and remove screws holding valve to cabinet . Reverse steps to install. Slowly turn on water and listen and look for leaks if all is well turn on the power and start washing.
The GE Profile Dishwasher will not allow me to start without the heated drying light coming on. I want to wash without this headed drying at the end of the wash. When I try to turn it off it turns the...
Try pressing the "Start/Reset" pad hold it for 5 seconds to reset the dishwasher and wait 2 minutes. If the problem persists, reset (reboot) the dishwasher by turning off power to the unit at the house circuit breaker/fuse box for 30 seconds. Or if its pluged in below the sink like mine unplug and plug back in. Restore power and the dishwasher should function normally.
The Drying light flashes and the unit beeps about once per second. At the same time the unit acts like it is washing (sounds of water washing insiide. The bottom is oompletely full of water.
so its beeping and flashing once per second correct this beeping and flashing is an error code that your unit is giving blinking lights or beeping sounds may indicate a problem with the dishwasher caused by power surges. To correct the problem, try pressing the "Start/Reset" pad to reset the dishwasher. If the problem persists, reset (reboot) the control by turning off the circuit breaker supplying the dishwasher for 30 seconds. Turn the circuit breaker back on and the dishwasher should function normally if you still have the flashing and beeping message me back Im going through the error code book as I type this if it still persists after you turned off the power then back on message me back with the number of beeps within 60 seconds as well as the number of flashing lights for instance if it does it every second or once every 5 seconds also if you have any further questions message me back them as well and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situaitons Thanks Rick
Item: Whirlpool Ultra Dishwasher Age: 3 yrs Problem: Not enough water to effectively wash the dishes. State: When the dishwasher is started, the fill valve opens as normal. Only about 1/2 the amount of...
Larry,
The float is generally for overflow conditions and will interrupt power to the fill valve solenoid.
If you are not filling completely in the time allowed by the timer, it is most likely a flow restriction in the water supply. Barring other obvious restrictions, the fill valve has filter screens on the inlet side of the fill valve, which is generally the cause of your symptoms. Be careful if you attempt to clean the screens, as the fill valves are very sensitive to debris, and can become stuck open if sediment gets past the screen. I usually replace the fill valve to avoid future problems.
Hope this helps.
2helpful
Dishwasher starts for seconds but, then shuts off
Check that water supply is available and that water inlet valve is operational. Filling unit is usually the first step of any wash program and dishwasher is shutting down because float valve is not actuated.
Top Dishwashers Experts
Mike Cairns
Mike Cairns
