Question about Alpine Air XL-15 Air Purifier
Crackling sound Mine crackles continuously. Changing the settings doesn't make a difference. It's like a rapid fire click-click-click. I cleaned the ceramic plate, but it made no difference. What causes that crackling?
  • 368 Answers
You need to look inside (through the front grill) with the lights turned off, and try to spot the sparking/arcing high-voltage - - what you're likely hearing is a spark where high-voltage is grounding-out due to a fault in the wire insulation or some other insulating structure.
Once you isolate where in the machine it's arcing, you may be able to determine where it is and whether or not it's within your skills to fix it. If it's an XL-15 as indicated by this category, it's no longer in warranty (no longer even supported by the manufacturer, for that matter, so it will be up to you to determine how much you want to work with high-voltage electricity.
If you can find the spark, you might be able to report back here for more detailed advice. Hope this helps.
Posted on Dec 23, 2008
Can I still use the air purifier if I put clean filters even if light is on red light wont go off
Mine had a latch on the back top with a label, " pull up to clean if crackling". I pulled it up and observed a wiper sliding up the big wire inside. I did it up and down several times and that fixed mine.
Jun 13, 2014 | Ionic Pro 901P2RIP04 Air Purifier
Crackles even after blades are cleaned
To stop the crackling sound, you need to remove all of the dust particles from the wire in the back. Sometimes when the unit is extremely dirty you can see sparks emanating from the wire, this is what causes the crackling sound. The unit has a built in cleaner you can lift up and down to perform this task, located on the top, but this doesn't work extremely well.
I usually take a can of compressed air and blow as much of the dust I can off the wire and all surrounding internal areas as I can. To do this, approach the unit from the front, and turn the blade door slightly so the wire can be seen. This along with a thorough cleaning of the blades should eliminate the crackling noise. Of course, make sure the device is unplugged before performing any cleaning.
Oct 19, 2011 | Ionic Pro TURBO Air Purifier
Unit will sometimes make a crackling noise.
Mine does it too, I finally just tried something else when I was cleaning the blades. I took some alcohol on a qtip and with the blades out of the machine I wiped up and down the line wires that are inside that go from the top to the bottom, and also the little balls that are on the bottom of the wires that slide when you turn your unit upside down. It seems to work, I do it every time I clean the blades. scribner062
May 22, 2010 | Sharper Image Ionic Breeze Quadra Air...
CONSTANT CRACKLING SOUND FROM CLASSIC LIVING AIR PURIFIER
Check the plates for cracks and make sure the metal contacts are making a good connection with the metal grid on the plates. Either problem will cause the crackling problem
Dec 17, 2009 | Ecoquest Living Air Classic Air Purifier
My Ionic Pro Turbo air purifier is blowing air in intervals of 30 seconds, blows for 30 seconds then stops for 10 sec. then repeats. Is this normal or do I have a defective unit? Thanks, Jerry
Have you cleaned the unit good and made sure that there is nothing crossing the grid wires? It sounds as if it is cutting off and resetting for some reason. Mine runs continuously. I take an air compressor and blow mine out every time I clean it. Also, on some models, you have to hold the on button down for several seconds to reset it after cleaning. Hope this helps.
Jul 03, 2009 | Ionic Pro FULL-SIZE Air Purifier
My pureion makes a crackling/ticking sound when running;
Its just a wear in the ozone plastic its normal after continued use
Mar 22, 2009 | Brookstone Pure-Ion UV Air Purifier
Environcare unit is not crackling.
Check the connections to the air cells (precipitators) and be sure you have a good connection - make sure none of the cell plates are touching each other
Mar 07, 2009 | Honeywell Air Purifiers
No clean air smell/crackling & static
I usually take a can of compressed air and blow as much of the dust I can off the wire and all surrounding internal areas as I can. This along with a thorough cleaning of the blades should eliminate the crackling noise. Of course, make sure the device is unplugged before performing any cleaning.
Not sure about the smell though. Mine has started to smell a little strange and I haven't figured out how to fix that problem.
Oct 01, 2008 | Ionic Pro TURBO Air Purifier
I need to buy one filter
we are also expierencing the same crackling problem. This machine is only a year old.....
anyone find anyway to resolve the crackling? I have not contacted Brookstone, but it doesn't sound too promising anyway.
These air purifiers are not cheap and they should back up their products.
May 17, 2008 | Brookstone Pure-Ion (506840) Air Purifier
Alpine Air XL-15 Air Purifier Logo
556 people viewed this question
Top Alpine Air Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Tom Chichester
Are you an Alpine Air Air Purifier Expert? Answer questions, earn points and help others
